Question about HP LaserJet 3390 All-in-One Multifunction Printer
Not pickup for try 2 paper - HP LaserJet 3390 All-in-One Multifunction Printer
  • 52 Answers
Check and make sure paper stop at back of tray is set to letter also check roller making sure right side plastic not broken
Posted on Jul 30, 2010
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
HP M4345MFP paper is sticking together due to static
Have you replaced the pickup rollers yet? The rollers are the most common cause of paper jams and multi-sheet paper feeds. The pickup rollers come in a kit with rollers for tray 1 and tray 2 along with a new transfer roller. The kit is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=302
Look at your pickup rollers, they should have a rough surface almost like a fingerprint, if the surface is smoother then they need to be replaced.
Feb 18, 2013 | HP LaserJet M4345 MultiFunction Printer
HP LJ 2420 wont pickup paper from tray 2
Replace try2 paper pick up roller..
Dec 01, 2011 | HP LaserJet 2420 Printer
No paper pickup problem in system printer (HPLaserjet 3050 models)
open back & side covers.. start diagnosys..
chech paper pickup unit trying to picking up the paper?..if yes.. clean/replace pickup roller..
No. check solonoid acting proprly,,
Paper passing little bit?..if yes..check paper sensor flag strucked?
check transfer roller gear properly engaging with the catride? 1.Replace catridge..2. Transfer roller check..
Good luck..
Sep 05, 2011 | HP LaserJet 3055 All-In-One Printer
HP P3005DN Tray 2 pickup roller does not turn. Hear clicking sound but roller doesn't turn to pickup and feed paper.
Hi
This is a problem with the Pickup roller.
Try to inspect the paper pickup roller, on the right side of the roller you can find a small notch which gets coupled with the shaft it will be broken. You have to replace the roller.
Regards
Jul 15, 2011 | HP LaserJet P3005n Printer
I have a hp laserjet 4250 printer it had a paper jam in tray 2 i have cleared the jam but it keeps saying i still have the jam in tray 2
There is still paper stuck in the printer. try lifting the printer off of tray 2 to inspect it or here it is straight from the service manual...
Jams in tray 2
Table 7-10 Causes of tray 2 jams
Cause Solution
The feed or separation rollers are dirty, worn, or damaged. Clean the rollers. If they are dirty after cleaning, or if they are
worn or damaged, replace the rollers.
The pickup roller is worn or damaged. Replace the pickup roller.
The tray 2 paper pickup assembly drive gears are damaged
or the assembly is defective.
Check the drive gears in the paper pickup drive assembly.
Replace the pickup drive assembly if the gears are
damaged. See Paper-pickup drive assembly.
The tray 2 pickup solenoid (SL101) is damaged. 1 Disconnect the connector for the tray pickup solenoid
from the dc controller PCA (location J92).
2 Measure the resistance between the cable connectors.
3 If the measured resistance is not approximately
160 ohms for the HP LaserJet 4200/4300, or 110 ohms
for the HP LaserJet 4250/4350, replace the tray 2
pickup solenoid.
The tray 2 lifter-drive assembly or the stack position
sensor (PS107) is defective.
Replace the lifter-drive assembly. See Tray 2 lifter-drive
assembly and/or Printer switches and sensors.
The dc controller PCA is defective. Replace the dc controller PCA. See Dc controller PCA.
Dirty, worn, or deformed pick-up roller, cassette separation
roller, and cassette feed roller.
Clean the rollers if they are dirty. Replace any worn or
deformed rollers. The cassette separation roller and the
cassette feed rollare are to be replaced together.
Damaged gears in the cassette pick-up drive unit. Move the gears in the cassette pick up drive unit. If the
gears are not rotating correctly, or are damaged or worn,
replace the cassette pick-up drive unit.
Dec 25, 2010 | HP LaserJet 4250 Printer
HP Laserjet 2430n printer won't see the paper in Tray 2. Continues to give in display paper size *letter and *plain but I set it and it just comes back asking again. When you print it won't pickup from...
Yes I checked the tray throughly. I also changed to paper to legal plain and changed the configuration...still came back on the display panel change paper size...just won't stop asking.
If I put the add-on paper tray 500 sheet that tray works fine.
I was thinking though I might order another paper tray and try it since I replaced the pickup assy and still have problems...what do you think
I also cold reset the printer just in the event something was set wrong...still has problems
Oct 15, 2010 | HP LaserJet 2430tn Printer
I have a HP LaserJet 1320tn, after I changed the cartridge I keep getting paper jams just about where the paper meets the cartridge
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
Jun 29, 2009 | HP LaserJet 1320 Printer
No Paper Pickup error
Check all this ---------
1.check the paper pickup roller may be its not functioning
proper.
2.check the paper pickup sensor(clean this)
3.check the paper pickup tray for proper work.
4.check the gear of paper pickup.
thanks
Mar 20, 2008 | HP LaserJet 3390 All-in-One Multifunction...
Pixma iP4200
These problems cane be caused by a number of things.
1. Dirty or worn pickup rollers. Clean the rollers with alcohol. This can be hard to do because you have to clean the portion of the roller that actually contacts the paper. This will only work if the rollers are slipping on the paper.
2. Object stuck in paper path. Again, can be hard to get rid of depending on how far in it is. It can actually prevent the tray from moving into the pickup position.
3. Broken gear in the paper pickup assembly, or somehow the timing has been changed. The gears in many paper pickup assemblies (or ASF for Auto Sheet Feeder) have to be timed correctly. If someone has pulled a piece of paper out causing the gears to skip a few coggs, the timing can be off and the unit will either not pick up paper or will fire a sheet or two out as soon as it's turned on. Unfortunately this fault would have to be corrected by a service tech who knows how to reset the timing correctly.
Nov 12, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
HP LaserJet 3390 All-in-One Multifunction Printer Logo
111 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
