Question about Acer Altos G710 Server
Do not acept more tham four 2 GB ddr2 module
When instal 8 2Gb ddr2 modules of memory do not show all 16Gb allow.
  • 1 more comment
  • nimeshhp Feb 01, 2009
    it is not accepting more than 2 X 1GB of Ram on windows 003 server in Altos G710 server.
  • theswapnil Mar 24, 2009
    do not acept more tham four 1 GB ddr2 ram
  • Francisco Cardoso
    Francisco Cardoso May 11, 2010
    What is the operating system ?
    Windows / Linux ?
    Operating System Architecture ?
    32/64 Bits ?
    Best Regards, Francisco
  • 101 Answers
Your Server model has a limitation of max., memory to 8GB I think .
Posted on May 07, 2008
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
400-MHz DDR2 SDRAM
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
http://support.dell.com/support/edocs/systems/ws470/en/ug_en/about.htm
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
Is there any problem if i install a single 2gb memory at one slot on my acer aspire 4315?
max ram per slot is 1gb, for 2GB total. A 2 GB module will not work
http://www.crucial.com/store/listparts.aspx?model=Aspire%204315
Apr 03, 2010 | Acer Aspire 4315 Notebook
If I unstall DDR400 memory as as follows: DDR1 & DDR3 : 512MB each DDR2 & DDR4 : 256MB each making 1.5 GB in total, will dual channel technology be activated?
Definitely not. Dual channel technology requires that the 2 RAM modules installed in each bank be of the same capacity, data rate, & even better be from the same manufacturer.
Oct 30, 2009 | Gigabyte GA-8I915G Pro Motherboard
How to install memory for T3642 eMachine
eMachines T3642 Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 1.0 GB = 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T3642 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 1.0 GB = 512 MB (removable) + 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
INSTALLATION PROCEDURE
1. Place the computer power switch in the "off " position and disconnect the AC power cord.
2. Remove the computer top cover following the instructions in the model-specific owner manual.
3. Before touching any electronic components, make sure you first touch an unpainted, grounded metal object to discharge any static electricity stored on your clothing or body.
4. Locate the memory expansion sockets on the computer motherboard. If all the sockets are full, remove smaller capacity modules to allow room for higher capacity modules.
5. The ejector tabs shown in the illustration are used to remove a module. By pushing outward on the ejector tabs, the module will pop-up from the socket and it can then be removed.
6. Handle your new module carefully; do not flex or bend the module. Always grasp the module by its edges.
7. For most installations, DDR modules can be installed in any available expansion slot. Other installations may require the memory to be installed in a particular sequence based on the modules capacity. Check your owner manual to determine the correct installation sequence for your configuration.
  • Insert the module into an available expansion socket. Note how the module is keyed to the socket. This ensures the module can be plugged into the socket one way only. Firmly press the module into position, making certain the module is completely seated in the socket. The ejector tabs at each end of the socket will automatically snap into the locked position. Repeat this procedure for any additional modules you are installing. install_ddr.gif 8. Once the module or modules have been installed, the computer top cover can be reinstalled.
    9. Plug in the AC power cord and reinstall any cables disconnected during the installation process.
    10. Turn on the computer and follow the instructions in your computer owner manual that describe the steps necessary to allow your computer to recognize the newly installed memory.
  • Oct 23, 2009 | E-Machines eMachines T3830 PC Desktop
    What is the maximum memory capacity of acer aspire 5600 model
    According to the specs of this laptop model, it supports up to 4 GB of DDR2 533/667 MHz memory using two soDIMM modules. This means that you will have to replace the 512 MB memory module already installed in your laptop, & replace it with 2 soDIMM DDR2 533/667 MHz memory modules, each of 2 GB capacity.
    Jul 14, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
    Dual Channel on an Emachines T5082
    Look closely at the BOLD print
    Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
    Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
    Apr 17, 2009 | E-Machines T5082 PC Desktop
    Memory issues
    CHECK RAM ONE BY ONE, IT MAY BE POSSIBLE THAT THE RAM IS FAULTY
    Nov 09, 2008 | Dell Inspiron 9300 PC Notebook
    RAM NOT DETECTING
    I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
    Jun 25, 2008 | Intel D102GGC2 Motherboard
    Acer Altos G710 Server Logo
    103 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
