Question about Sony TA-N9000ES 5-Channel Amplifier
Accidentally plug 110v dryer into 220v. it wont start anymore..what's wrong?
  • Sony Master
  • 17,130 Answers
The dryer would have burned off the coils as the voltage is double of the operating voltage that was designed. ALl what can be done is to open and find out the break in the heater resisitor winding . These wires act a fuse and would have just burned out and lost the connection. find it out by a continuity test and connect at this point by joining , twisting. Now test the continuity and test on the 110 volt. it must work hope fully if the motor has not burnt out too. Hope you try. Good day..
Posted on Jul 31, 2010
What is required to use it as far as electrical outlet.
Dryers come in both 110V and 220V.
If you plug a 220V dryer into a 110V socket, it will run very slow.
If you plug a 110V dryer into a 220V socket, it will burn up.
If you can find a 220V extension cord, then you should be able to use it.
Mar 08, 2015 | Dryers
I accidentally plugged in my pulmoneb in a 220v outlet
plugging a 110v device into a 220v outlet is not likely, as the plugs are a different configuration. In the event that you somehow managed to do that, your device is probably fried, as that would be to much voltage. Hate to say it; but you are probably gonna need a new one
Nov 27, 2012 | DeVilbiss PulmoNeb Compressor Nebulizer...
I accidentally plugged in my 110v portable sewing machine to a 220v outlet and it sparked
You have damaged your machine. Place it into the bin and go buy new.... or maybe if you are lucky you can find someone who can fix it.
Nov 25, 2012 | Sewing Machines
Can I plug GE dryer GTDP250EMWW directly to 220v? the manual says that the power rating of this model is 110/220v.
If the dryer is electric and bought in the United States then you can plug it in. The 110/220 power rating basically means that some parts if the dryer use 110v. All 220v is is 2 110v independent circuits sharing the same common ground.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 06, 2012 | GE Dryers
I want to put machine in my house but need 110 motor instead of 220. nothing wrong with motor or control box
I'm assuming that you brought a vacuum cleaner from a country that uses 220V to a country that uses 110V.
You either have to change the motor to a 110V motor, or find a way of plugging the cleaner into a 220V supply.
You could contact the manufacturer and ask them if they have a 110V replacement motor for your model. (Safety warning... it will take double the electrical current, which will cause four times the heating in the cable; this could be dangerous.)
A better solution would be to have an electrician fit a 220V outlet in your house. The pin arrangement will be different to prevent 110V deviced being plugged in to it. You'll have to cut the existing plug and replace it with the correct one for that voltage for your country. (I have used a British 'Dyson' in this way, plugged in to a tumble-dryer outlet; I use a GFI for extra safety.)
Jan 19, 2011 | Vacuums
My 110v humidifier plug into 220v
it would not be worth fixing. all electronics would be fried
Oct 05, 2009 | Humidifiers
WA71N2 plugged to 220V should be 110V
The Fuse for these model is 110V - 250V, so definitely the machine will still light up for a moment then black out. So if you accidentally plugged it to 220V (if it is 110V) you have to change the whole PCB. Electric current are distributed by PCB which only handles 110V.
I suggest when you change the PCB try to change also the Fuse to 110V only so that next time if by accident it was plugged to 220V you just have to change the Fuse not the PCB.
I
Jul 09, 2008 | Samsung WE356A5W Washer/Dryer Laundry...
Sony TA-N9000ES 5-Channel Amplifier Logo
114 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
