Question about GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0
COMPRESSOR DON'T TURN ON - GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0
  • 478 Answers
You'll need to check the breaker to the unit to make sure you have power. If so, then remove the cover where your electical wiring enters the unit. There is a contactor that should be humming if it is recieveing a call from the indoor unit. If not, check the wires going to the unit for any damage. If you find the contactor you can manually press it in to check to see if it runs, if so, then it is a problem in the control wiring. or the control board inside is not sending the voltage out. You'll need a volt meeter to test this.
Posted on Jul 30, 2010
My access don't work I the ac compressor dnt turn
the compressor protected by a pressure switch it only turn on the compressor if there is a pressure on the system if no pressure it means there a leak on the system try to check
Jun 17, 2013 | Cars & Trucks
Compressor wont stop running
Hi pickeringstr
Replace your shut-off switch...it is faulty
Bud
Apr 28, 2013 | Air Tools & Compressors
A/c compressor not activating only when bridged
WELL THIS HAPPENED TO ME IT WORKED WHEN WANTED THEN COMPLETELY STOPPED, SOLUTION DON'T CHANGE THE COMPRESSOR IT WILL JUST DO THE SAME AFTER A TIME JUST GET YOURS RECOILED.
May 09, 2012 | 2007 Nissan Tiida 1.6
Air has started leaking around the plus/minus knob on the front of my "Porter Cable C2002 150 Psi 6 Gal Compressor." As a result it no longer can fill up with air. What can I do to fix it. Jim
They will let air out if you have turned the valve out too far, try turning it clockwise until it stops then open it by turning the other direction two or three full turns.
Don F
Aug 14, 2011 | Porter Cable C2002 150 Psi 6 Gal...
I have a Husky air compressor model WL651004AJ. The problem is that it builds pressure initially up to 75 psi then shuts off. I have to turn off the power switch, wait about 5 minutes, turn the switch back...
It sounds like you need to replace the run capacitor , if yours is weak or defective the motor will overheat. Check "Drillspot" for a replacement. Another major cause of overheating is due to a dirty air filter , you should check it first.
Don F
Aug 12, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have electrical problem with AC compressor Blazer 2002. Don't run.
If the compressor clutch isn't locking and turning the compressor the first thing to check is the refrigerant level. If the system is low on refrigerant a safety switch opens the clutch circuit and prevents the compressor from running. The reason for this is that the lubricant for the compressor travels through the system with the refrigerant, so if the system is low the compressor can be destroyed from lack of lubrication.
Jul 02, 2011 | 2002 Chevrolet Blazer
Turn my roof top ac on , fan runs but when compressor tries to run lights in camper dims 3 to 5 sec. don;t kick breaker off, any ideas?
You need to get a reading on the current draw of the compressor. Use a clamp on ampmeter to do this. Compare your reading with the data plate on the compressor. Your compressor may be getting ready to go out. You can also check the capacitor. If may be getting weak and need replacing. Another idea may be to install a hard start capacitor if the compressor is OK.
Sep 05, 2010 | Dometic Rooftop RV Air Conditioner
3 ton heatpump package unit kicks 100 amp breaker compressor hums and condesor fan doesnt turn
compressor is locked up! check the start relay and the fan motor to see if the shaft wobbles up and down if it don;t! then replace the compressor
Jan 21, 2010 | Heating & Cooling
Air condition don´t start, a honda civic
Air conditioning systems sometimes leak down and won't turn on when the refrigerant levels are too low.
Lift the hood and listen to the A/C compressor while someone inside the car turns it on.
Does the compressor engage for a second or two and then shut off?
If it does....you need to have your system checked for leaks and recharged.
If the compressor never comes on. Look at the A/C compressor relay. It should be under the hood in a little fuse box with other relays and fuses. When you find this relay you need to see if it works. You can buy a replacement relay and swap it or take it to a parts store and have it checked. Relays are 10-30 dollars and you should have three or four relays of the same type so a real cheap test is to swap a identical relay from an electric window or a defroster. You should see them sitting right next to the A/C relay if you have them.
Good luck and be careful!
Dec 11, 2009 | 2003 Honda Civic
GE Quiet-Aire Ductless Split System Air Conditioner AS1CD12AA0/AS0CD12AA0 Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
