Question about LG WM-1832C Front Load Washer
My LG WM1832CW is blinking LE on the readout. what's wrong?
    President:
  • 1,382 Answers
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thank you !!
Posted on Jul 30, 2010
I have a DE code on my LG Wm1832cw front load washer. This happened last weekend, and we found that the small drain hose in the front was clogged so we got the clog out and the washer has worked great all...
IE: Water level (246) was not reached in 8 minutes
UE: Imbalance: Load too, small too large
OE: Drain problem took longer than 10 minutes to drain
FE: Overflow issue drain pump running to comp
PE: pressure sensor (sensor out)
dE: door error. open door. switch is out
LE (with a a slash in the
middle of L. Upside down F) Thermistor out
CE: Over amping Too much soap wrong soap
LE: hall sensor shorted/destroyed from sudslock
bE: Ball sensor loose connection/out of order
EE: eeprom out test mode only
PF: power failure momentary interruption of shocktricity
Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 27, 2011 | LG WM-2277HW Front Load Washer
Yesterday I was doing laundry and getting the kids baths and so I put the cloths in th washer not to many 2 paira of pants and a few shirts. When I walked back by I noticed that it had kicked off! I opened...
Hi my name is Sean, LE is indicating bad motor/stator or weak one. It will be need to be replaced to fix the problem. Let me know if you have any other questions, the smell is coming from wrong type of soap or too much soap.
Sean
Mar 26, 2011 | LG WM-1832C Front Load Washer
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Noisy on spin cycle LG WM1832CW
this is joyce
Go to lg.com and download your manuel put in your model #
thanks
joyce
Feb 07, 2009 | LG WM-1832C Front Load Washer
LG WASHER WM1832CW HAS LE ERROR MESSAGE
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
Jan 15, 2009 | LG WM-2277HW Front Load Washer
LG WM1832CW
hi linda from what you describe? the machine does wash cycle? but won't spin cycle? if the machine is a couple of yrs old ? it may well be the motor that runs machine is in need of some new brushes fitting ? they are not expensive and may be worn too low to activate the higher revolutions needed for spin cycle it is not a difficult job to drop motor off and check/replace if you have a good male/ friend? with elec competence ? have found this problem on other machines and most recent zanusi cost £5 for 2x new brushes as apposed to the £££££s the lady was estimated for a timer ? by plumber so why not check it out b4 you part with money ? best wishes/luck
Oct 16, 2008 | LG WM-2277HW Front Load Washer
LE code flashing
Try replacing the sensor assembly. Part number 6501KW2002A. It is on the stator itself where the 4 wire connector clips to. Only costs $17 + change & shipping. Mine works fine now!
May 07, 2007 | LG WM-1832C Front Load Washer
LG WM-1832C Front Load Washer Logo
784 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
