Question about Fujitsu FI-4860C2
Fujitsu 4860c scanner error
I am getting error sf 15 sensor error on a Fujitsu 4860c scanner any ideas?
Switched sf1.5 with sf 2 and trouble switched. paper clip was stuck in sf-1.5 and probably shorted it out. thanks.
Posted on Sep 11, 2008
There are 2 sensors on the background unit(Front) SF1.5 and SF 2
Both sensors look like black boxes. SF2 is nearest the reading glass and SF1.5 is below it. Make sure both are clean. There are also tests you can run in test mode to recalibrate the sensors, if that doesn't work you have to replace it.
Posted on Aug 26, 2008
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
Fujitu FI 6670 service manual
Fujitsu has documentation for all of their products on their website.
Here is a list of all the scanner docs:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/docs.html
For the FI-6670 they link to 3 different documents:
Datasheet [587KB]
Getting Started Guide [1.39MB]
Operator's Guide [12.7MB]
Jan 31, 2014 | Fujitsu fi Office Equipment & Supplies
Error code "L"
Is the code display L-6? This error code describes US Sensor Alarm.
You may perform the following steps or may ask your local Fujitsu scanner expert for the disgnosys and replacement of faulty part.
1. Does the same symptom occur after turning OFF and ON the scanner? To check, press power button of the scanner for more than 2 seconds to turn it OFF, and after more than 2 seconds elapse, press the power button to turn the scanner ON.
2. Check the US Sensor operation by conducting Maintenance mode to see if the US sensor works properly. If the error still occurs, confirm that the sensor cable is correctly connected. And then replace the US Sensor FX and US Sensor RV.
Thanks & regards,
ScanCare
Aug 05, 2013 | Fujitsu fi-6130 Flatbed Scanner
I need a solution to u1 error with detail code o5A in fujitsu fi-5900c scanner
Hello Marcus,
In Fujitsu fi-5900c scanner, Error 05a refers to JAM1 Sensor malfunction.You need to clean the two lenses of the JAM1 sensor with a cotton swab. Then check the performance of the sensor and also check sensor cable connections. This error also occurs if Pinch Roller 2 is installed left-right reversal. Check the same too. If the issue still persists, then you may have to replace the sensor.
If the above steps do not help, then you are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Feb 07, 2013 | Fujitsu fi-5900C Pass-Through Scanner
Backend optical error
check on feeder side assembly, there might loos contact on bulb or on bulb controller.
Jun 07, 2010 | Fujitsu fi-4340C Flatbed Scanner
Fujitsu scanner light bar will not return to
When you face such errors, please check if the Scanner panel displays-"E-0" and TWAIN displays- “The running system is abnormal. Please confirm the carrier lock has come off.”
The error is Carrier unit drive alarm. After power-on, carrier unit (FB) moves to home position, that is where the carrier unit locates when home position sensor is turned ON. If the home position sensor is not turned ON after the carrier unit has moved pre-defined steps, this error occurs.
Probable causes:
Defective sensor, motor, or carrier belt.
Also, please check the following:
1. Is there is any abnormal noise from FB motor when this error occurs?
2. Does any foreign object get inside drive unit or carrier unit?
3. Is CR belt tension loose? Loose belt should be tightened.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
Mar 26, 2010 | Fujitsu fi-6130 Flatbed Scanner
DOWNLOAD DRIVERS
Preferably download from Fujitsu here:
Driver Vista :9.18.709
Driver XP :9.18.149
If you still cannot download from website above (reccomended) , alternate download here: download driver for Fujitsu fi-4120C Scanner
Oct 02, 2008 | Fujitsu fi-4120C Path-Through Scanner
Fujitsu FI-4860C2 Logo
512 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
