If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box. http://electronicshelponline.blogspot.com/
Please visit http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us and follow the steps. Contact HP and see if you model is on the affected list, as it could be eligible for a free motherboard replacement to resolve the defective video card issue. If they say no, check out www.hplies.com for other useful information regarding this Globally known issue with nVidia and HP.
try checking if there are plastic locks that prevents from opening the case of your laptop. It may somehow be located on the side or the bottom of the laptop.
Attention: Dont force it to open it may break the lock..
Hi, that sounds like the integerated video graphics is going bad and it's not actually the screen. the zd7000's were known for video graphics failure. there was a lawsuit filed against hp for the zd models about a year ago to get a free motherboard replacement because of the video issue but it's too late to send it in now for the free repair. the zd models don't have a replacable video card in them like most laptops which the only way to fix the problem ould be to purchase another motherboard, you could try ebay but they're not that cheap. Rick
Before you invest any further, try the lcd inverter http://www.laptoprepair101.com/laptop/2007/01/31/replace-screen-inverter-fix-backlight/ I have seen them for real cheap. If you take off your bezel cover underneath the display you'll find the inverter or if necessary you can get a tech to help install. Usually theres a series of beeps when you get a blank screen. Hp pavilion laptops also get hot on the keyboard after a while from long term use and zd 8000 came out about 4 years ago so the display should be a pretty good looking glossy screen. Those are nice laptops to work with by the way.
This is a vertical-deflection problem. Try to adjust the vertical (height and linearity and hold) controls, which should be screwdriver potentiometer controls on the back of the set.
If this does not work, a defective component in the vertical-deflection circuit will need to be repaired.
