Question about Home
I just installed Grohe aquatower 2000 shower panel. there is no hot water.
  • 28 Answers
Before installing, did you check the supply temperature? The mixer won't do any good on your AquaTower if you didn't calibrate the water temperature coming out of the wall first. I suggest you remove the supply line to the unit and measure it with a handheld thermometer (it should read 36 or 38 degrees celcius), then reconnect to the unit and you should be able to make adjustments through the mixer.
Posted on Jul 30, 2010
I have grohe 1000 shower and there is a constant water dripping from the head. What could be the problem
The water shut-off valve is leaking, thus not completely shutting off the water supply to the unit. Need to be repaired/replaced.
Mar 14, 2016 | Grohe Aquatower 1000 Shower System 27 016...
The handle to switch between the overhead showerhead and the handheld wand won't turn.
Look to a small hole on the adjustment handle there should be a small Allen screw. Loosen the Allen screw set the handle to the desired position then tighten the Allen screw.
Jan 29, 2016 | Grohe Aquatower 3000 Shower Tower...
My Grohe Aquatower 3000 shower is wonderful BUT after 5 or 6 minutes, the water starts cooling off. Is there some adjustment to keep the water warmer for 10-15 minutes?
You are lucky that your shower is lasting as long as it does. If you have a standard 40 or 50 gallon water heater, mixed with 30% cold water as it comes out, you can expect about 60 gallons of hot water, give or take a little bit. Each of those showerheads on that Aquatower is rated at 2.5 gpm. Even if you are just using the body sprays, you could be using 10 gallons of water EACH MINUTE. There is really only two things you can do, and that is to raise the temperature of your hot water heater by 5-10 degrees so you are mixing more cold water with the hot. The other thing is to buy a bigger hot water heater, or supplement the one you have with another water heater in series.
May 03, 2011 | Home
Body sprayer shot out when turned on, can I get replacment parts?
yes, but most parts for Grohe have to be ordered so call your local supply house before wasting time driving there.
Oct 25, 2010 | Grohe Aquatower 3000 Shower Tower...
Shower head has little preasure or water volume. is there a flow restrictor that can be removed?
their might be on the handel where the hose meets, but if really low water pressure then maybe more of a problem.
Mar 26, 2010 | Grohe Aquatower 3000 Shower Tower...
I have a shower tower and the water directional knob has become immovable any ideas?
try CLR to lossen it,remove and clean.This is due to calcium build-up. you may have hard water,have your water checked.
Jul 16, 2009 | Grohe Aquatower 3000 Shower Tower...
Dripping shower head
If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
Home Logo
172 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
