Question about Panasonic Microwave Ovens
National Microwave Oven Model NN5527WF not working. I switched it on as main lights went dim, immediately I heard a short vibration / noise and the oven went dead. I was informed by an electrician that he felt some condensor had burnt out. Help:-(
    President:
  • 2,559 Answers
The problem is that the magtube( Magnitron) has burned out, If you decide on having it replaced, also have them replace the diode as well.
Posted on Jul 30, 2010
Testimonial: "Hi Rockitman187, Thank you very much. I will try out your kind recommendation and get back to you. Thank you. god be with you:-)"
Tip
Troubleshooting Guide
  • Problem: Totally dead oven.
    Possible causes:
    1. No power to outlet (blown fuse or tripped breaker or GFCI).
    2. Blown main fuse - likely due to other problems.
    3. Open thermal protector or thermal fuse.
    4. Defective controller or its power supply.
    5. Clock needs to be set before other functions will operate (some models).
  • Problem: Totally dead oven after repair.
    Possible causes:
    1. Cabinet screws replaced in incorrect location (safety interlock not engaged).
    2. Any number of screwups. :)
  • Problem: No response to any buttons on touchpad.
    Possible causes:
    1. Door is not closed (some models).
    2. You waited to long (open and close door to wake it up).
    3. Controller is confused (pull plug for a minute or two to reset).
    4. Defective interlock switches.
    5. Faulty controller or its power supply.
    6. Touchpad or controller board contaminated by overenthusiastic cleaning.
    7. Defective/damaged touchpad.
  • Problem: Oven runs when door is still open.
    Possible causes:
    1. Damaged interlock assembly.
    2. Cooling fans (only) running due to bad sensor or still warm.
  • Problem: Oven starts on its own as soon as door is closed.
    Possible causes:
    1. Defective triac or relay.
    2. Controller is confused (pull plug for a minute or two to reset).
    3. Defective controller or its power supply.
    4. Touchpad or controller board contaminated by overenthusiastic cleaning.
    5. Defective/damaged touchpad.
  • Problem: Oven works but display is blank.
    Possible causes:
    1. Defective controller or its power supply.
    2. Broken display panel.
    3. Oven needs to be reset (pull plug for a minute or two to reset).
  • Problem: Whacked out controller or incorrect operation.
    Possible causes:
    1. Previous or multipart cook cycle not complete.
    6. Defective sensor (particulalry covection/mirowave combos).
  • Problem: Erratic behavior.
    Possible causes:
    2. Bad connections in controller or microwave generator.
    3. Faulty relay - primary (or HV side, much less commonly used).
    5. Bad contacts/connections on mechanical timers. Intermittent fuse.
    6. Power surge at start of cook cycle confusing controller.
    7. Microwave (RF) leakage into electronics bay.
  • Problem: Some keys on the touchpad do not function or perform the wrong action.
    Possible causes:
    1. Touchpad or controller board contaminated by overenthusiastic cleaning.
    2. Defective/damaged touchpad.
    4. Faulty controller.
  • Problem: Microwave oven does not respond to START button.
    Possible causes:
    1. Defective START button.
    2. Faulty interlock switches.
    3. Door is not securely closed.
    5. You waited too long - open and close door to wake it up!
  • Problem: No heat but otherwise normal operation.
    Possible causes:
    1. Blown fuse in HV transformer primary circuit or HV fuse (if used).
    2. Bad connections (particularly to magnetron filament).
    4. Open HV capacitor, HV diode, HV transformer, or magnetron filament.
    5. Shorted HV diode, HV capacitor (will blow a fuse), or magnetron.
    6. Defective HV relay (not commonly used).
  • Problem: Timer and light work but no heat, cooling fan, or turntable rotation.
    Possible causes:
    1. Defective (lower) door interlock switch or door not closing fully.
    2. Faulty relay or triac.
  • Problem: Fuse blows when closing or opening door:
    Possible causes:
    1. Defective door interlock switch(s).
    2. Interlock switch knocked out of position.
    3. Misaligned door.
  • Problem: Loud hum and/or burning smell when attempting to cook.
    Possible causes:
    1. Shorted HV diode, magnetron.
    2. Burnt carbonized food in or above oven chamber.
    3. Shorted winding in HV transformer.
    4. Frayed insulation on HV wiring.
  • Problem: Arcing in or above oven chamber.
    Possible causes:
    1. Burnt carbonized food deposits.
    2. Exposed sharp metal edges.
  • Problem: Fuse blows when initiating cook cycle.
    Possible causes:
    1. Defective interlock switches or misaligned door.
    2. Shorted HV capacitor.
    3. Shorted HV diode.
    4. Shorted magnetron (probably won't blow main fuse but HV fuse if used).
    5. Defective triac.
    6. Old age or power surges.
    7. Defective HV transformer.
    8. Short in wiring due to vibration or poor manufacturing.
  • Problem: Fuse blows when microwave shuts off (during or at end of cook cycle).
    Possible causes:
    1. Defective triac (doesn't turn off properly).
    2. Defective relay.
    3. Shorting wires.
  • Problem: Oven heats on high setting regardless of power setting.
    Possible causes:
    1. Faulty primary relay or triac or HV relay (not commonly used).
    2. Faulty controller.
  • Problem: Oven immediately starts to cook when door is closed.
    Possible causes:
    1. Shorted relay or triac.
  • Problem: Oven heats but power seems low or erratic.
    Possible causes:
    1. Low line voltage.
    2. Magnetron with low emission.
    3. Faulty controller or set for wrong mode.
    4. Stirrer (or turntable) not working.
    5. Intermittent connections to magnetron filament or elsewhere.
    6. Faulty primary relay or triac or HV relay (not commonly used).
  • Problem: Oven heats but shuts off randomly.
    Possible causes:
    1. Overheating due to blocked air vents or inoperative cooling fan.
    2. Overheating due to bad magnetron.
    3. Bad connections in controller or microwave generator.
    4. Faulty interlock switch or marginal door alignment.
    5. Faulty controller.
    6. Overheating due to extremely high line voltage.
    7. Stuck stirrer fan resulting hot spots detected by sensors.
  • Problem: Oven makes (possibly erratic) buzzing noise when heating.
    Possible causes:
    1. Fan blades hitting support or shroud.
    2. Vibrating sheet metal.
    3. Vibrating transformer laminations.
    4. Turntable or stirrer hitting some debris.
  • Problem: Oven light does not work.
    Possible causes:
    1. Burnt out bulb :-).
    2. Bad connections.
  • Problem: Fans or turntables that do not work.
    Possible causes:
    1. Gummed up lubrication or bad motor bearing(s).
    2. Loose or broken belt.
    3. Bad motor.
    4. Bad thermostat.
    5. Bad connections.
on Mar 30, 2008 | Kenmore 80412 Microwave Oven
Panasonic microwave NN-S666BA
No! the main fuse is okay because you would not have any power. I would check all door switches because they control light, fan, and turntable. If you are handy with a meter, set to ohms, disconnect one wire on side of switch, use meter to test, readings should show open/short when pressing the button and releasing it, replace wire to switch and repeat, if you hit one with the same readings pressed in or out, change the switch.
Mar 06, 2012 | Panasonic NN-S666BA Microwave Oven
Microwave MH6140XKQ doesnt want to start
Toss it out. The transformer is likely bad.
Nov 18, 2017 | Whirlpool MH1140XM Microwave Oven
I have a GE Microwave oven model JVM1790SK01. The surface light switch doesn't work - the lamp stays on all the time; won't dim to night light and won't turn off
There are wires going from the main board to the surface lamp and turntable. They are thin orange, yellow and blue wires. I think the surface lamp is yellow and the turntable wires are orange. You should first try taking the bottom cover off. There are about 8 screws under neath and the bottom cover hinges on the back edge, just let it hang. You can now see the wires. Those wires short to the case where they go through from the main board to the lamps or turntable motor. You now have to move them away form the case. Sometimes they get pinched to the metal cabinet by the lamp socket area. Look for signs of pinched wiring there at the lamp socket or where they go through. Move them away, tape up the bad area.
Mar 21, 2011 | GE JVM1790 1000 Watts Convection /...
My oven keeps blowing the main fuse (the one behind the grille). How can I troubleshoot ? I know how to use a AC/DC tester, please advise next step. Thanks
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Went to use microwave and it just went dead. Household power is fine and breakers are good. Replaced main fuse behind switch panel and got power back for clock etc.. When I went to run it again, it went...
short circuit in high tension power supply
DUE TO THE VERY HIGH AND DANGEROUS VOLTAGE 4000( V) IT IS NOT WISE TO FIX IT YOUR SELF UNLESS YOU KNOW WHAT YOU ARE DOING
Apr 26, 2010 | Maytag MMV5100A Microwave Oven
No power
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
We have the full service manual, and I have uploaded it to our site here.
The best place to order Sharp parts is Tritronics at http://www.wehaveparts.com
Once you have it fixed, if you would like for us to replace your display on the control board, we can install a new display tube for $69.95 or a good used one for $54.95 and those totals include return shipping.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 06, 2008 | Sharp R-1480 Microwave Oven
GE Microwave XL 1800
remove top cover of oven , check fuse and control unit, high voltage section and diodes and capacitor and magnetron,
Oct 28, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
233 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
