Question about Cell Phones
Test mode on screen - Cell Phones
When i on my phone the test mode written appeared and then phone again become off.
Posted on Oct 18, 2010
How to turn of field test mode on my zte z958
Field Test Mode: What it is and How To Enable it on Your Phone
www.ubersignal.com/field-test-mode
  1. Cached
  2. Similar
Most phones have a setting we call Field Test Mode that can show you useful information about your phone, including the signal strength in decibels. ... The iPhone has a hidden built-in Field Test Mode app. .... My Home; My Vehicle; My Work ...
Field Test Mode for iPhone and Android - RepeaterStore
https://www.repeaterstore.com/pages/field-test-mode
  1. Cached
  2. Similar
Your phone can tell you exactly how strong its signal is, in decibels, by entering Field Test Mode. How to enter Field Test Mode varies from phone to phone, but it ...
Finding Your Phone's Signal Strength Reading (Field Test Mode ...
support.weboost.com/.../206521937-Finding-Your-Phone-s-Signal-Strength-Reading-...
  1. Cached
  2. Similar
7 days ago - Finding Your Phone's Signal Strength Reading (Field Test Mode) ... My phone's 3 bars may well represent a stronger signal than your phone's ...
[PDF]Cellular Phone Field Test Modes - wpsantennas.com
www.wpsantennas.com/pdf/testmode/fieldtestmodes.pdf
  1. Cached
  2. Similar
Dial *3001#12345#* and press the Call button. This will launch the Field Test Mode app and where the bars/dots were in the top left corner of the screen, you'll now see "< Back to iPhone". Hold down the power button until you see "Slide to Power Off", then release it. field test mode on my zte z958 Google Search
Dec 13, 2016 | ZTE Cell Phones
Tip
SERVICE MODE AND POWER FL PANEL CIRCUIT
1. Main Functions
• Diag
Performs unit test of devices installed on the board.
• Display Error Log
Error log is displayed. Displayed contents can also be saved in an USB memory device.
• Factory Initialize
Restores the unit to its factory settings.
• Network
Checks the wired network connection.
• Version Up Not used.
• System Information
Displays the system information of the unit.
Displays information such as the software version, drive information, etc.
• EMC Test Mode Not used.
• Drive
Write drive OP data and check drive.
2. Menu Tree
3. Service Mode Menu (Top Menu)
This is the top menu of service mode.
Each function is accessed from this screen.
Operation:
[1] Moves to Diag screen
[2] Moves to Log screen
[3] Moves to Factory Initialize screen
[4] Moves to Network screen
[5] Moves to Version Up (DISC version update) screen (Not used)
[6] Moves to System Information screen
[7] Moves to EMC test mode screen (Not used)
[8] Moves to Drive screen
[9] Moves to HDD mode (Not used)
[UP]/[DOWN] Moves the cursor [ ENTER] Moves to the screen of the item selected with the cursor.
FOR MORE CHECK THE LINK ...
Electronics Equipment Repair Center
on Feb 14, 2015 | Sony Televison & Video
Tip
Field Test
The test mode display is activated through the test mode command: <b>*3001#12345#</b>. Once you enter this command, you are given a list of options, including 'Field Test'. Select Field Test and then hit 'Enabled'. You must power down the phone and power it up again to get out of the test mode menu. The test mode screens may vary somewhat between different firmware versions and providers.<br /> Once you power up the phone you are given a new menu choice at location 10 called 'Field Test'. There are several different test mode screens. Type in a test number to get the screen listed below. Alternatively you may use the arrow buttons to move between the 199 different field test screens. Entering test number '0' will disable the test mode, but will still allow you to access the test menu.<br /> If you are using the field test mode and are unsure what the screens mean then hold down the # key for about four seconds to get a brief description of the screen. Repeat holding the # key to return to the test mode values. <b>Thanks to L. Tee for this tip</b><br /> If you would like to see what is behind the test mode screen then keyguard the phone, wait until the 'press unlock and then *' screen disappears, and then press one of the numeric keys to see the regular screen. <b>Thanks to L. Tee for this tip</b><br /> Note: If you make or receive calls while in test mode, you may not be able to change the speaker volume. To turn off the field test mode you can select field test '0' or enter a few digits and then clear these digits.
on Jun 19, 2011 | Cell Phones
Total counter not function
try in test mode d 203 in to 1 to 0
Feb 08, 2014 | Toshiba E-Studio 2040c Copier
Tip
Test Mode Information for tdMA models
Enter <b>*3001#12345#</b> and select <i>Field Test</i> (menu option 9 on a 6160), followed by one of three options: <i>Enabled</i>, <i>Enabled+lights</i>, or <i>Disabled</i>. Once selected you must power down the phone and power it up again. To get out of test mode re-enter <b>*3001#12345#</b>, <i>Field Test</i>, <i>Disabled</i> and then power down the phone. Once you power up the phone you may automatically enter field test mode, screen 01 AND/OR you are given a new menu choice of Field Test.<br /> To turn on field test mode select the menu option of Field Test and enter a number between 1 and 7. To turn off field test mode enter number '0'. There are a total of 7 different test mode screens on tdMA models and they may vary somewhat between the different Nokia models. Use the arrow buttons to move between field test screens.
I dialed ##8378<SEND>, then clicked
Typing ##8378 Send brings up the phone test screen. When you select #2 (Field Test) and then select OEM monitor and select "enable" the phone resets and enters test mode.
In test mode you can press the volume up button to bring up the test menu. You can navigate this menu using the 1 and 3 keys on the number pad.
The most notable screen in test mode is found by pressing 3 until you reach SHDR protocol monitor will bring up the screen that displays real time reception and transmission information.
Other screens display other system information, but I caution against "playing around" with these menus too much.
To temporarily hide the test mode screen you can press the volume keys again. To take the phone out of test mode completely follow these steps:
1. dial ##test or ##8378 and press send 2. select 2 (field test) 3. scroll down to and select 10 (OEM monitor) 4. scroll down and select Monitor DISABLE 5. the phone will reset and return to normal mode.
Feb 13, 2011 | Casio G''zOne Type S Cellular Phone
Nokia 1600 stuck in test mode. unable to use.
This problem could only be solved by the nokia care centre.
1.This problem is happened due to chip failure, that leads to the displaying of text "test mode".
2.This chip is too small,so only nokia care centre can fix this problem.
May 25, 2009 | Nokia 1100
Internal diagnostic mode
To enter Test Selection mode from Customer mode and display the Test Selection screen:
  1. Select Information -> Troubleshooting -> Service Tools from the Control Panel.
  2. Scroll down to Enter Diagnostics and press the OK button.
When the system transitions from Customer mode into Test Selection mode, the initial Control Panel display is the Test Selection screen as follows
Dec 31, 2007 | Xerox Phaser 8500/DN Printer
Test Mode problem with Moto Rzr V3M
to get out of test mofe do this hit clr and the top left button right by the screen and then hit #073887 and turn it off
Aug 17, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Cell Phones Logo
135 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
