Question about Samsung SCX 4200 All-In-One Laser Printer
How to remove scanner error problem - Samsung SCX 4200 All-In-One Laser Printer
  • 360 Answers
Change scanner cable
Posted on Aug 14, 2010
My printer is Hp Laserjet P2055d fail to work error 52 occur and display scanner error whwat can I do?
The laser scanner speed is incorrect. X description: 1 = Scanner startup error 2 = Scanner rotation error
Probably Resolution : 1. Press GO.
The page containing the error will automatically be reprinted.
2. Turn the printer off and then on.
3. Re-seat cables to the laser/ scanner and engine controller.
4. Replace the laser/scanner.
I might as well tell you before hand, I'm Not sure if yours can be repaired but on older models I have repaired them by opening the laser/scanner assembly and removing the little circuit board with the motor and chrome spinning shaft. If you can remove the chrome piece from the motor you do so and then place a very tiny drop of synthetic oil down the shaft, install the chrome piece and spin a few time by hand and put everything back together. You can download the service manual by doing a google search. Look for instructions for removing the laser/scanner.
Apr 21, 2016 | HP LaserJet P2055d Laser Printer
Hplaserjet3005 52.00 error what could be the problem ?
52.00 ERROR A scanner motor error has occurred. Scanner motor rotation is verified at the initialization of a print job.
1. Verify that the scanner motor connector
and the ribbon cable from the ECU are
firmly seated on the laser/scanner assembly.
2. Verify that the scanner motor connector
is firmly seated in connector J402 on the ECU. You might have to remove the main cooling fan to see this connection.
3. Verify that the ribbon cable installed in
connector J403 on the ECU is fully seated. You must remove the ECU in order to verify this connection.
4. If the message persists, replace the laser/scanner assembly.
Sep 09, 2015 | Office Equipment & Supplies
Error 51.23 after paper jam
**Yellow laser scanner error, replace scanner assem..For tech guys: Remove scanner assembly, remove cover,check for yellow scanner motor rotation. if its hard or struck, gently remove engine motor,lubricate the shaft fix it back & verify rotation, how ever entire unit opened clean all reflector glasses with ear buds gently, fix the unit back properly.(out of four screws, factory wont fit one or two screws for alignment match, same way fix the screws, don't inter change). check for print if its rectified. process end..or else replace scanner assm..
Dec 21, 2011 | HP LaserJet CM1015 All-In-One Printer
Hp laserjet m1522nf 52 scanner error
Step 1.Switch on the machine observe Optical scanner assm moving forward & reverse for checking home position? remove flat bed glass,clean it especially at black band area, fix it and check..Step 2. Switch off the machine, remove power cable, remove left side door,dis connect Scanner cable(connector J4) on formatter, switch on the machine, check if same error? replace formatter assm..if different error replace optical scanner(CCD) assm..
Sep 20, 2011 | HP LaserJet M1522n MultiFunction Printer
The printer is showing error 51 and not printing
Control Panel message
51 PRINTER ERROR
Description
Beam error
Action
Laser scanner cable connectors are faulty or laser scanner assembly is defective Most likly it is the laser/scanner assembly. The motor is probably not spinning at the right speed. You would need to find an old hp 4 no longer working and switch the laser/scanner. It is the "black box" located under the top cover. You would need to remove the right side cover, the top cover, the left side cover and the output assembly. Remove all the cables from the scanner retaining clips. Remove the three cables plugged into the scanner and remove the four screws attaching the scanner to the frame. When replacing the scanner make sure the shutter control arm on the left front side of the scanner is attached correctly so that the shutter closes when the toner cartiridge is removed. You could first try to remove the 3 connnectors and reset them.
Nov 17, 2010 | HP LaserJet 4 plus Printer
2600 printer error 51023
51.20 Error
51.21 Error
51.22 Error
51.23 Error
The device has experienced an internal
hardware error.
51.20 Error-black scanner error
51.21 Error-cyan scanner error
51.22 Error-magenta scanner error
51.23 Error-yellow scanner error
Turn off the power by using the power
switch, wait at least 30 seconds, and then
turn on the power and wait for the device to
initialize.
If a surge protector is being used, remove
it. Plug the device directly into the wall
socket. Use the power switch to turn the
device on.
Laser scanners are not replaceable.
Replace the engine.
Nov 12, 2010 | HP Color LaserJet 2600n Printer
Error no is 51.22
go to this link, and read page 12 .. your error is listed as
http://www.partshere.com/Models/Q6455A/CLJ_2600nTroubleshooting.pdf
51.20 Error
51.21 Error
51.22 Error
51.23 Error
hardware error.
initialize.
device on.
Replace the engine
please post positive feedback for me
Oct 17, 2010 | HP Color LaserJet 2600n Printer
HP 1005 Scanner error 6
dear Sirs i have HP 1005 did't work and have this message Scanner Scanner error 6
please if you can help me
Sep 07, 2009 | HP LaserJet M1005 Printer
Error 8 in scanner i40
Error 8 = Face up light check failure.
Check Top Lamp is lighting up and not Flickering.
Check connections to Ballast (Inverter) and Lamp.
Jun 30, 2009 | Kodak i40 Path-Through Scanner
Hp 3055 laserjet scanner problem
When powered on printer 3055 it gives error on control panel that
"Scanner error 6 Trun off and then on "
after several restart printer gives the same error
what will be the problem
Dec 20, 2007 | HP LaserJet 3055 All-In-One Printer
Samsung SCX 4200 All-In-One Laser Printer Logo
70 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
