Question about Dishwashers
LG Dishwasher - LD1415T1 - ERROR CODE: OE. Ive cleared the filters and still not working?
    President:
  • 1,382 Answers
"OE" indicates outlet error in your dishwasher. Check that you can hear water pumping first if not check your drain lines for obstruction.
Thank you !!
Posted on Jul 30, 2010
OE ERROR CODE
The manufacturer has assigned the OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Jul 08, 2014 | LG Dishwashers
What is Oe error lg model lds5540st
The OE error or fault code to indicate that the washing machine is not draining properly. Check to be sure the drain hose isn't clogged or kinked. If that checks out, check to see if the drain pump or drain pump filter are clogged. Sometimes objects that are put into the washing machine, for example combs, money, hair pins, etc. end up in the filter. Finally, if the drain line is clear and the pump seems to be clear and functioning properly, you may need to replace the drain pump assembly.
Jul 04, 2014 | LG LDF7561ST
Error Code OE
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
May 02, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Oe code
1st) Blocked drain hose 2nd) Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction) 3rd)Failing drain motor.
Gool Luck!
Apr 01, 2009 | LG Dishwashers
LG dishwasher Model: LDS5811ST getting error code: 0E
OE is a drainage problem...check for twist or obstruction in drain hose .. make sure filter screen is clear... Hope this helps..
Sep 17, 2008 | LG Dishwashers
Lg - LDS5811ST Dishwasher OE Error Code
hi
May 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LD-14AW1 keeps coming up with OE error code
Good Luck!!!
Oct 28, 2006 | LG 24 in. LD-12BS6 Stainless Steel...
Dishwashers Logo
553 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
