Question about Acer Aspire 5610-4648 Notebook
Laptop automatically shuts down without manually shutting it off. it went black out even if the charger was on the unit.
    Guru:
  • 1,481 Answers
Check the Hybernate and PowerSetting options...
Posted on Jul 30, 2010
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
NEW HP Spectre 13T-3000, 13.3" Touch will not run with the battery and shuts down randomly
you can use the unit without the battery. Remove the battery, plug in the charger/power supply and turn on the unit and wait for the result. if the problem persist?..... maybe the fault is in CPU fan. check the fan...overheating the processor. Cleaning the heat sync and reapplying silicon compound on CPU's can cure the problem.
Sep 02, 2014 | Computers & Internet
I have a problem with my sony vaio!it seems to crush when i move the charger!its not shutting down but the scen is off and then i have to remove the charger so it shuts down and turn it on again!plus it...
It sounds like a loose connection in the charger cord or the AC jack. If the laptop is pulled by the cord it could have loosened/damaged the AC jack. If you remove the battery and only use the AC cord does the problem change? if you only use the battery and no AC cord does that change the problem? When Power is removed, without a proper shut down, the machine sees it as a crash therefore the disk check and black screen with boot options.
Nov 18, 2012 | Sony VAIO VGNBX740NS5 Notebook
Hp dv1000 does not power up
maby the charger is not compatible with your laptop.
Aug 25, 2012 | HP Pavilion dv1000 Notebook
Charger not shutting off
Some chargers contain a computer chip that automatically shuts off the unit when a battery is fully charged. Other models continue to charge as long as the unit is on. Review the instructions for your particular charger to ascertain whether you'll have to manually turn off your 3-in-1 charger.
Jun 19, 2012 | GPS
Eveytime i charge my laptop, it automatically shut down, reboot and even hang,
Possible cause:
1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution:
First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Jun 04, 2011 | Toshiba Satellite Pro L300 Notebook
Hp nx 6110 was working fine but suddenly it went off and now it does not boot
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Feb 08, 2011 | HP Compaq nx6110 PC Laptop
My Toshiba c650-18k laptop is just 1 month old i was playing on it and when i went to shut down before shutting down it turned off automatically and when i tried tom turn it on it is not turning on.I tried...
It sounds like your charger is not working. If you can check the voltage out of the charger or if there is an indicator on the charger that would be my first place to look. Only do simple checks as the and it should still be under warranty being only a month or two old. If you have another charger that would fit then try swapping it out to get you going in the short run. You can always warranty old charger. Or if you bought it locally consider returning it to the store.
Jan 09, 2018 | Computers & Internet
Computer is frozen
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Jun 10, 2010 | HP Pavilion DV6700T Notebook
Comp shut down
dont even mess with it just send it in you will void the waranty
Nov 03, 2007 | Toshiba Satellite M45-S2692 Notebook
Acer Aspire 5610-4648 Notebook Logo
65 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
