Question about Logitech Webcam
The people who im chatting with cant see me on there end but the computer has acknowdleged the webacam
  • Logitech Master
  • 3,015 Answers
The webcam software is probably not configured to the chat program
First of all - if the webcam has a built-in mic make sure it is set as the default mic on your computer
Plug in the webcam
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
YAHOO MESSENGER
Plug in your webcam and visit this site - Hit 'Allow' in the top window and check your cam in the left hand panel.
Do not proceed if the camera fails to work here, but concentrate on your webcam software / drivers
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to Yahoo Messenger 10.
COMPATIBILITY WITH YAHOO MESSENGER
You MUST use Internet Explorer to visit this page, with your webcam plugged in, to check compatibility and automatically download the latest webcam control. Make sure your webcam broadcasts on this page before moving on
http://help.yahoo.com/l/us/yahoo/messenger/messenger10/webcam/mstacamtest.html
CONFIGURE SOFTWARE
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the Yahoo software may have difficulty in locating it. Mine, I just unplug it from the USB and plug it back in, if yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Of all the chat programs, Yahoo is the most painful software to set up but if you follow these instructions you should be ok.
INTERNET CONNECTION
Webcam connected
Open messenger - on top toolbar. Left click ( > ) Messenger > Preferences > Connection - Select 'no proxies' or 'connect direct to the internet' depending on the version of messenger you have
make sure your internet connection and country are correct in the lower two boxes > Apply > OK
TESTING
> Messenger > My webcam - the warning panel will launch, click 'OK' and your webcam will start. You should be rewarded at this stage with your happy smiling face.
SET WEBCAM DEFAULT
With webcam still running > Messenger > Preferences > Webcam Broadcast > Camera Source - set your webcam as default using dropbox. > Camera Settings - adjust settings to suit. > Apply > OK
Take a note of any additional software, if you have multiple choice for Camera Source, you may wish to uninstall any redundant webcam software later to prevent conflicts
AUDIO
Open Video and Voice - run through your default equipment and make a test call - click OK
PERMISSION OPTIONS
> Messenger > Preferences > Webcam - make your default equipment selections and who you will allow to view you > Apply > OK
IN USE
When you are both on line and wish to show your webcam > Actions > 'Invite to view my webcam'.
Messenger 10:- > Actions > More Actions > invite to view my webcam. This will launch an invitation on your contacts screen when they 'Accept' your webcam broadcast will start- There can be considerable time lag ( +1 minute) before they see you, so don't be too impatient ( You can check the status on the bottom left of your webcam panel. You can 'drag and drop' the frame to a convenient location by grabbing the top border.
Your contacts may need to configure their connection the same as INTERNET CONNECTION above (Ignoring webcam connected) if they get a "webcam not connected" message
Sometimes you may have to broadcast the 'small image' option from the 'Webcam' menu on the top of your image frames. This happens when one of you is down on resources -its like sending a large photo by email - its quicker if you cut the size down
you can zoom up to 200% from the same menu when the webcam picture comes through
Use the 'Always on top' option from the 'webcam' menu - or your image will disappear under the message window when you type a message
WINDOWS LIVE MESSENGER
Test your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
If it fails to work here concentrate on your webcam drivers and software before moving forward.
Set your webcam mic (if it has one as default)
Vista -
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - (if not - make sure the webcam is set as default - restart MSN)
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
SKYPE
Not working ? - troubleshoot your drivers and software - get your cam working before moving on
Working OK ?
CONFIGURE TO SKYPE
Connect webcam
Its good practice to disconnect and re-connect your webcam before you start (To reboot the webcam software) - if you have been using it elsewhere the SKYPE software may have difficulty in locating it, even if you exited the previous program correctly.
Start Skype.
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make a free test call
Click 'Save'
In the navigation pane of the Skype Options window, click Video Settings.
This will launch your webcam
Adjust quality of picture in 'Settings'
Check the correct webcam is shown as default
Click Save
Test your webcam by making a Skype test call.
For more information about how to configure Skype Messenger, please visit the following Skype Web site:
http://support.skype.com (http://support.skype.com)
Posted on Aug 01, 2010
Cant see IM's in yahoo messenger chat windows,,and I sure as HECK cant reach anyone at Yahoo to help me
according to http://downrightnow.com/yahoomail yahoo mail is currently down.
Mar 01, 2011 | Yahoo Messenger
When i do a video call i cant see the person i'm chattng? how can i fix it?
The other person you are chatting with needs to open their video at their end. If you can see yourself but cannot see who you are chatting with, try letting them call you using the "Video Call" option in the chat box.
Oct 27, 2010 | Skype IM
GE EasyCam Pro Webcam is zoomed in really close and cant figure out how to zoom it out
Hi. I think every hardware like this webcam has a software for testing the functionalities, and for this webcam you can look on the list of programs installed on your computer and one of them is for your webcam, then from there you can access the settings for your webcam to adjust the zoom utility on this sofware or if could not find a specific software for that webacam on your computer, you could try going to your control panel and access the printers and cameras icon there you could also adjust the functionalities for your webcam. Hope this helps
May 18, 2010 | Computers & Internet
My chat always appears online even though im
Is this with facebook? I am having the same issues as well. Also with the Feeds not showing properly. Currently, the website is undergoing maintenance so we need to wait until it works again.
Alternatively, try switching from different browsers.
Nov 27, 2009 | Computers & Internet
Facebook chat keeps sayin im offline and wont load up how do i solve this problem
THE CHAT SAY IM OFFLINE AND IM NOT...ALSO I CAN SEE PEOPLE MESSAGES BUT THEY CANT SEE MINES
Sep 30, 2009 | Facebook Social Network
Play game everquest 2 i cant get my voice chat in game to work
The problem seems to be on Sonys end. Lots of people having this problem since the update on the 16th.
Jun 18, 2009 | Webroot Spy Sweeper (spysweeper) for PC
Hello I have a gigaware webacam and when I video chat its really dark and the person cant see my face. how do i change the brightness?
In cam software control panel.No control panel download one at gigaware web site.It will allow you to ajust contrast brightness etc.HAPPY HOLIDAYS AND PLEASE VOTE IF THIS IS HELPFUL.richardm69
Dec 21, 2008 | Radio Shack VGA PC Camera Webcam
Logitech Webcam Logo
87 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
