Question about Sony Computers & Internet
Sony Vaio PCG-9H4L cannot find hard drive
A friend gave me a Sony Vaio PCG-9H4L. When I try to boot it up, it says ''Cannot find hard drive. Confirm if hard drive is correctly connected.'' I have the original system recovery cd, but not having any luck. Any suggestions on how to get this laptop running? FYI: My computer skills are rusty... :)
  • 2,632 Answers
You can try to go to bios pae and check if the system can detect the hard drive.If not you might need to call call Sony to check if the system is still on warranty so that they can replace the hard drive free of cost if not you might need to replace it with a new one
Posted on Jul 30, 2010
Sony Vaio will not power on with hard drive connected
I'd say it's time to do a close inspection of the hard drive connector/adapter, especially if it has any components mounted on it. If you can't see a problem you can fix like a short between two terminals, and you can't get another one, get an external USB drive (preferably the largest flash memory stick you can obtain) and set it up as a Linux bootable volume and use that to run your computer. You will probably have to set the BIOS to boot from a USB volume first.
Jan 07, 2014 | Sony Vaio Pcg-R505Tek...
Hello. I have Sony Vaio PCG-5426. And I can't reinstall windows on that machine. I have out CD-ROM "II FreeCom" and i try to reinstall with that. In BIOS menu I acces for first boot drive...
you shouldn't need to have to press f9 to boot from cd rom if you have it set in the bios as the first boot device , are you sure the copy of windows on cd that you have is bootable. Try booting from the disc on another laptop or pc and see if you can start it
Another option to try is to boot from a usb drive
instructions on how to do that are here
http://www.xtremesystems.org/forums/showthread.php?t=118576
once you have booted to usb you should be able to access the cd rom
depending on what version of windows you are trying to install you will need to run different programs.
you could also install vista or windows 7 to usb drive and install it from that, it is much quicker than installing from cd/dvd you would need to be able to boot from usb to start with though
how to install vista or windows 7 from usb instructions can be found here
http://www.intowindows.com/how-to-install-windows-7vista-from-usb-drive-detailed-100-working-guide/
please vote for me if you found any of this useful
Feb 20, 2011 | Sony VAIO PCG-5212 PCG-5426 PCG-551L...
I need to replace my hard drive in my Viao PCG-GR370 laptop. Is it possible to put in a larger than 30 GB drive?
below is a link for a 320 gig hard drive for your model, i hope this helps
http://www.upgradecomputermemory.com/ram.cfm//memory/s/sony-vaio/sony-notebooks-vaio-pcg-series/VAIO-GR-PCG-GR-Series-Notebook/VAIO-PCG-GR370/320GB-Notebook-Hard-Drive-for-the-Sony-VAIO-PCG-GR370.html
Feb 14, 2011 | Sony VAIO GR370 Notebook
Hello, I have a Sony VAIO PCG-FXA63 that a coworker gave me. It does nothing, no lights, sounds, or noises. AC power supply checks out ok. Tried new battery no difference. Has DC 19.8 voltage at back of DC...
Maybe unit was already trashed when gifted! Could be corrupted cmos, bad hard drive, bad memory, corrupted OS, bad peripheral. Check with your "friend."
Aug 28, 2017 | Sony VAIO FXA63 Notebook
I have a sony vaio pcg. it powers on and does nothing else. the 2 little cooling fans come on but the hard drive doesn't run and screen won't come on. can anyone help me out. thanks
Its possible that you already have a bad hard drive. It may have crashed. Your system will not boot without the hard drive running. The computer will keep on trying to look for the Hard drive that's probably why it looks like its doing nothing. Bring your machine to sony and have them fix it. If you know how to open up your Vaio, try to check the Hard drive connection and see it its loose, if its not loose. its time to replace the hard drive.
I hope this helps. Thanks and have a nice day.
- HotRatchet
Dec 14, 2009 | Sony VAIO PCG-K35 Notebook
Need drivers for sony pcg-7g1m notebook, can any one please help
Drivers for Sony Vaio
You can download the drivers from above link
Regarding the Hidden partition
You can reformat the Vaio back to it's original state by going to All Programs -> Vaio Recovery Tool -> Vaio Recovery Utility and choosing either Recover Drive C:\ only or to recover the whole computer back to factory settings
Oct 05, 2009 | Sony Computers & Internet
My sony vaio freezes at the sony screen during boot
Most likely a hard drive problem but could be a number of things. Try pressing tab or escape when it freezes and see if the screen switches and gives more information. If you are able, remove the hard drive and try booting again. (the cd/dvd drive could also cause this so try removing that if possible)
Jun 17, 2009 | Sony VAIO PCG-K23 Notebook
No boot
check the cd rom again make sure its plugged in ok, ,
with the hard drive you usually can hear it spinning or ticking
before buyin a new hard drive i would try to reinstall windows
Apr 02, 2009 | Sony VAIO Notebook
Sony pcg 9h4l motherboard issue
Try to power off unit and remove the battery. Then press and hold power button for 30seconds.Put the battery back and turn it on. If it turns on turn it back off again and remove the battery. Connect your VAIO using the AC adapter only. If this will not resolve your issue you can check this with SONY or any certified service center.
May 23, 2008 | Sony MBX-49 ASSY Motherboard
Page cannot be displayed
make sure that the password is exactly like it should be.
Jan 08, 2008 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
360 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
