Hi, I have a LG LH-T3602ME dvd reciever and the DVD player doesn't work,just feeds in then rejects the DVD . When the DVD feeds in but the drive motor doesn't spin , I disconnect the motor and checked with a 3v supply it spinns ok, Any answers???
  • indulgenc120 Aug 02, 2010
    Jul 31, 2010 - Hi,
    The in/out motor works,
    The one motor that runs the Disc doesn't , I have pulled the dvd player apart and disconnect the dvd spin motor and put 3v on it and comfirmed that it's ok, but this motor (drive) doesn't spin when the dvd goes in so the DVD is ejected.
    Can anyone tell me if this unit may have a common problem with this DVD player part.?
  • 677 Answers
Hi,when a DVD player doesn't Spin after checking the the motor that works fine,you will need to check the ribbon of the DVD player that makes the lens work if it's working properly.
After checking the ribborn of the DVD player, if it's fine that means the DVD drive mechanism consist of the motor, ribborn, etc will need to be replaced .
When you replace the all mechanism,it will work properly again.
Take care.
Posted on Aug 02, 2010
    Brigadier General:
  • 3,917 Answers
Hi
There three motors in the dvd compact.One motor moves the lens. The other motor runs cd/dvd disc. The last motor is the one which moves the tray in and out, check this motor/replace it and also there is a rubber may be its broken. Take the 3 screws off the back and open it up. There is a little rubber belt in front. This was disconnected from the gear.
http://electronics.howstuffworks.com/dvd6.htm
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 30, 2010
  • indulgenc120 Jul 31, 2010
    The one motor that runs the Disc doesn't , I have pulled the dvd player apart and disconnect the dvd spin motor and put 3v on it and comfirmed that it's ok, but this motor doesn't spin when the dvd goes in ???
LG CD/DVD Reciever unresponsive.
A lot of different equipment including but not limited to TV sets, computer towers you name it has this issue.
What I suspect is that if the unit has to be turned on several times before it works you have bad filter caps in the units power supply---standby supplies are on 7/24 if the unit is plugged in.
Look in the units power supply for puffed up caps that look like these.
Apr 03, 2012 | LG Televison & Video
DVD PLAYER MULTI REGION CODES
you can change your dvd region code but i advise you not to change it instead use a software . here is the link for the software to download :- http://www.4shared.com/file/19492658/43612f11/DVD_Ghost.html?s=1
if it doesn't work then contact me ok.
Jun 28, 2008 | Televison & Video
Tip
LG LH-D6235 DVD Region Free Fix
LG LH-D6235 DVD Home Theater Region Free Fix
Would you like to make your LG LH-D6235 DVD Home Theater Region Free?
Follow these steps:
  1. Press the Pause button on your remote control
  2. Using your remote control enter the code 3, 1, 4, 1, 5 and 9 (If your unit does not enter the following mode which enables you to enter a region code, repeat steps 1 and 2. You may need to enter these codes in a shorter time span for them to work.)
  3. Press the 0 button on your remote control for Region free, 1 for Region 1 or 2 for Region 2.
  4. Press the Pause button on your remote control
  5. Power off your player and wait a few seconds
  6. Power on your player
I hope that helps.
____________________________________________________________________
Download LG LH-D6235 Home Cinema System Manual
on Jul 14, 2010 | Televison & Video
Unlock code for LG one box one cinema
is 4 your home code region i know 0 is all in main settings sumware they shoudl show rgion free ok if ot dvd sdont surport it ok usally have to a buy a region free player to play all disk from all ove rthe world ok thx agian nick helpap
Feb 06, 2008 | Audio Players & Recorders
LG DVD player LH-D6230 - displays "dvd error" soon
Eprom corruption. Replace eprom, and edit in mode service.
Jan 07, 2011 | LG Audio Players & Recorders
How to connect dvd player to AV reciever
S-Video is a media type that only carries video. Unfortunately the LG unit was designed only to be a self contained surround sound unit. There are only video outputs to the television on this unit. Because of the unit having surround sound capabilities, LG felt that their wasn't a need for audio output. You would need to buy a new DVD player to allow audio from the DVD to your new Yamaha unit. Good Luck!
Jan 22, 2009 | Audio Players & Recorders
LG LH-W750 dvd player sound only
SOUN problem Zenith XBV343 DVD Player / VCR Combo?
Jan 06, 2009 | LG DN788
53 people viewed this question
 Grubhead
Grubhead
