Question about Refrigerators
Does my 2002 27ft terry trailer HAVE to be level in order to have the refrigerator start working? its not level right now....just seeing if it works before long term usage...would this make a difference?
  • 4,793 Answers
Just check the door seals to make sure they are tight all round,if the unit is out of square they may not fit tight.....
Posted on Jul 30, 2010
Tail and marker lights not working on trailer circuit, stop and turn signals work fine, 2004 gmc sierra 2500 hd
I would try hooking the trailer up to another vehicle and see if everything works right if everything works on the trailer I would start testing the trailer plug on your truck could be a wire has broken.
Jul 26, 2015 | 2004 GMC Sierra
Does anyone know where I can get an owner's manual for a 1976 Terry travel trailer?
Yeah right. This is antique, approaching historic. If not already there. It's hard to find anything under 82, cars, trucks and such. Let alone a travel trailer. You have a tear it apart and fix as you go trailer. Been there , done that.
Jul 04, 2015 | Cars & Trucks
What do I check to fix my Dometic Americana refrigerator. It won't start using electric or gas.
Fist off before you get crazy replacing things make sure the camper is level when testing this. Gas will not run to it if you are not level. Also make sure the gas is turned on and make sure you have selected automatic or gas only on your fridge. Also give it about an hour before you test the temp. These take a bit longer to start feeling cool. If all of that does not work you will need to check the refrigerant, igniter(for the gas side) and the compressor. Also make sure the fuses are good to go at the main panel and that the breakers are in the "on" position
Sep 11, 2014 | Dometic DM2852 Americana Fridge...
Trailer is plugged in and refrigerator is on auto. Refrigerator works. But when you unplug the trailer the gas side will not light. And when the trailer is plugged in and the refrigerator is set to gas,...
In order for your fridge to work when your trailer is not pluged in you need a 12 volt power source, You might have a bad battery or your positive or negative cables are not connected properly. Or a bad connection in the back of the fridge. Check the fuse?
Sep 29, 2010 | Dometic RM2652 Refrigerator
Need owner's manual on 2004 Terry Quantum Fleetwood Trailer
When I plug my terry I don't get power but I get power from my battery the power source work at the camp site but I'm not getting power can any help me
May 19, 2010 | Electronics - Others
DOMETIC RM 2214 Refrigerator in Travel Trailer will not refrigerate (get cold). Worked perfectly until we recently moved it to a new location. Yes, I've levelled the unit.
Check first if the distance of the fridge to the wall is enough or has similar air circulation as with its previous location. Inspect the coil at the back of the freezer for dirt or ice build up. See if cleaning the unit including the back of the freezer will help.
Aug 22, 2009 | Refrigerators
My fridge is in a pop up tent trailer and exausts out the side. It works fine on electicity but not at all on propane? It is lit and gets hot on the coils, just doesnt cool the fridge. Thanks
Believe it or not those fridges have to be perfectly level to operate on gas. Make sure of this on both axis. Front to rear and left to right.
Aug 21, 2009 | Dometic RM2652 Refrigerator
2003 denali trailer wiring
If your signals & brakes are on 2 different circuits, ( for example a red lens for stop & an Amber for turn.) then you'll need to buy a converter that goes between vehicle & trailer. They're not too expensive at any trailer or RV place. I think some of the autoparts stores stock them now too.
Jun 20, 2008 | 2004 GMC Sierra Denali
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
