Question about Hobart H600 Stand Mixer
Bowl Lift Nut H 6001
Where can I find a Bowl lift nut
  • Hobart Expert
  • 119 Answers
At your local Hobart office.
www.hobartservice.com Click on "locate an office" and enter your zip.
Posted on Aug 02, 2010
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
Where is the adjusting screw on my ksmc5os?
I am not sure but I believe your mixer is smiler to the K-5A, if it is you have to remove the pedestal base(4 screws on underside of mixer) in the hollow upright support you should be able to see the bowl lift linkage. Adjust the nut an the bottom of the linkage to adjust bowl hight.
Aug 19, 2014 | KitchenAid KSMC50S Commercial Stand Mixer
Hi, I have a used Hobart A200T and the bowl yoke piece moves up and down slightly, even under a light load. It makes an annoying clanking noise. It's as if a spring somewhere is looser than it should be....
You may be correct about a loose spring. Check this:
Carefully lay the mixer on its back side to access the bottom of the mixer. Remove the cover screen covering the opening in the bottom of the mixer. Using an extension and appropriate socket, be sure the nut of the bowl lift rod is snug, slightly compressing the spring of the bowl lift rod.
Jan 26, 2011 | Hobart A200 Stand Mixer
The lever to adjust bowl height will not move.
most of the times it is because of build up between lift handle and pedestle case use wd-40 and even some heat from a torch to help loosen up stuck handle. also wd-40 the ways on the mixer ped. where the bowl yoke is
Dec 15, 2009 | Hobart A200 Stand Mixer
Bowl lift on H660T will not raise bowl. The pinion gear turns the threaded rod, however; the screw just turns in the threaded block on the bowl yolk, without raising the bowl
The brass nut threads are worn.You have to remove the bowl yolk from the slides to get to the nut.I'm a hobart tech and repair these units often,any questions let me know----Tony.
Nov 23, 2009 | Hobart Food Mixers
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Hobart Mixer bowl won't go up
If the worm screw is turning but not lifting the bowl, the bowl lift nut is stripped.
H600 part number is 24198.
To change it, you need to undo the screws down the right side yoke slide to release the yoke. You will need to lift the yoke to reach some of them. If you have some wood place it under the yoke and over the legs to protect the paint. On top of the yoke are two blots holding the keeper plate over the nut. One is the stop screw for bowl height. Don't loose this setting. remove the slide, edge the yoke forward a bit to free the worm. Run the old nut down the worm and off the bottom. When you run the new nut on, all the excess grease and metal shavings will start to build up. Clean as you go, or better still, brush with solvent or similar to clean the worm threads . relubricate, run the nut up above the yoke, reload the yoke and attach keeper plate, reload slide.
To adjust slide, snug screw near bottom keeping slide close to yoke, run yoke to top and tighten top screw just enough to hold slide in place, lower yoke to bottom, gently tap top of slide in a 1/16" and tighten top screw. Run yoke to top of slide. It should start to bind slightly in the last 2 inches of travel, which will stop the bowl from dropping in use. Tighten remaining screws.
May 13, 2009 | Hobart H600 Stand Mixer
The adjustment screw fell off
There is no adjustment screw. That should be all the way up so that it will compress the spring and lock the lift lever un the up position. You will need to put the spring, washer and then the Nylock nut back on, I use a standard socket with some paper wadded in the bottom and over one side to hold the nut it it while I screw it back on.
Nov 02, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Hobart H600 Stand Mixer Logo
108 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
