My washing machine say's to clean pump. i'v done it. it runs for abit but then it pops up again (clean pump) what is happenning to it can u help
    Brigadier General:
  • 3,917 Answers
Hi
When it's in pump-out (spin), the washer DOES make sounds, there is probably something clogging the hose going to the pump. Pair of panties, children's sock, anything relatively small. This will be BEFORE the pump. You'll have to remove the cabinet from the front (easy job), remove the hose going to the pump, and check it out. There should be a little square door compartment at the bottom front or side of machine. Open it and unscrew the cap of the button trap. Water should come out, inspect for blockage of hair pins, coins or other obsructions.If it is still not pumping clear then there may be more debris further up inside the pump where you can't reach it.Further dismantling may be require of the pump component to get to the blockage.
Or Remove the screws from the bottom front panel.Remove the panel.Unscrew the filter located in the center.Clean the coins/hairpins/screws/lint/etc. etc.
Replace the filter.Replace the lower panel.Resume your wash.
If, when it's in pump-out (spin), the washer just has a faint hum, the pump is probably locked down (pair of panties, children's sock, anything relatively small). Replace the pump.
If, when it's in pump-out (spin), the washer is quiet, the lid switch is broken. Very common problem. Replace the lid switch.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 30, 2010
I have done that twice already drained the washing machine, and it had not worked, everytime I run my washer either the Sud or f35 pop up within the first min... Please help
u may have a bad suds sensor or more likely u have build up of suds u will have to run several washes of water and maybe a solution of vinigar thru the cycle to clean out
Feb 19, 2015 | Kenmore Washing Machines
Our washing machine keeps coming up with a red
Fill the washer up put it in drain and lift the drain hose out of the stand pipe and look at the rate of flow,if the vault is clear the the flow will be strong if not take the pump apart again and see if something else did get caught or check your partial blockage . There is indirectly a relation between door and drain but after resetting to preset even no changes so sharply look to symptoms exactly what is happening, suspected thing i can say in ur machine maybe ur door safety switch is faulty close the door properly........... is that fully electronic instrumentation or electromechanical, and also you may take care of the door gasket while operating.Sometimes if there are things in the pump it can damage the pump so when it is cleaned out the pump is still damaged, if problem still persist you may need a new pump.
Sep 18, 2014 | Washing Machines
The drain pump will not shut off and door remains locked
Clean the drain pump while the machine is off. There is a small door on the bottom front panel of the machine. Open this. You will see a jar cover like thing that you can unscrew. Unscrew this. A lot of water will gush out.... be careful..... Clean this and put the filter and cap back. If same thing happens again when you run the machine, you will have to replace the drain pump. Chances are, you are trying to run a 50 hertz machine on a 60 hertz line.
Jan 10, 2014 | Maytag MHWZ400T Front Load Washer
My washing machine wfs1273bw keeps saying clean pump, how do i do this. I have released the plug on the bottom right corner which lets water out but then it happens again....
Releasing the plug to drain the water won't solve your problem. Your washing machine has a pump that controls the flow of water. There might be an object like coins, or metal from your laundry that may have been included during the washing and is now blocking the pump. Try to unscrew the paddle that rotates during washing. By removing it, you can manually remove any possible obstacle that keeps blocking your pump that causes your washing machine to alert you to clean the pump.
Jul 23, 2011 | Washing Machines
My Whirlpool washing machine WFS1273AW, has been displaying "clean pump" and F02. I have cleaned the pump and even had a repair man change the pump. However the machine won't move beyond the wash cycle and...
The same thing happened to me and it was because there were socks stuck where the drain pipe attaches to the machine. If you tip your machine on its side and pull the black pipe off from the bottom of the drum you can remove anything which is stuck. Then it just clips back on again with a metal clip.
Aug 31, 2010 | Washing Machines
De comes on the front and wont drain wm1814cw
the machine is clogged is th hose kinked,try to push the start buton again,you should hear the pump come on and try to drain.when it stops,push the button again,when the door unlocks take cloths out.And put 1/2c of bleach in drum and let it soak a few hrs.Now start washer no clothes this may do it,after cycle put clothes back in and run clothes through full cycle.When ther done.Put in Draino-Drain opener gell only and let it set over nite,then run heavy duty cycle this well clean washes and clean pump.
Jul 26, 2010 | LG WM1814CW Front Load Washer
It says clean pump on the front of the machine i cleaned it but the same thing happened again please help
I'm not sure what the thing was that happened again, but check the drain line for kinks or obstructions and check out the pump. I know you said that you cleaned the pump, but you really should check it out. Remove the hoses from the pump and use a flashlight to look into the ports on the pump. Check the pump impeller. Make sure there are no missing/broken blades and that the impeller will spin freely. If any blades are missing/broken or if you can't get the impeller to spin freely, then the pump is defective. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 09, 2009 | Washing Machines
Runs for ever to complete cycle and has water standing under the strainer?
LOOKS AS THOUGH HEATER HAS FAILED IT WILL WASH FOR OVER 4 HOURS IF HEATER FAILS IN COLD WATER NOT EXPENSIVE TO REPLACE.
Sep 07, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Hotpoint Washing Machine smells mouldy as has mould
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the hose you see. The white filter cover is right in front. Get yourself a bunch of towels or a good big plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Next: You can use Affresh to clean your front loader. Deposits of soap and other such things can be stuck around the inside tub of your washer. Try this product, it works great on all front loaders. Use hot water with the Affresh pellet with no clothes and run the machine through a cycle. Also helps with any stagnant water smells. Have you cleaned out your pump lately. Put the pellet inside the machine, not in the soap dispenser.
Pl give me a good rating for the free help, thanks.
Jul 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Whirlpool Calypso stops at 26 minutes and throws ob code
The OB indicates and out of balance condition has been detected by the motor control. You say this happens when the washer is empty also. One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 29, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
