Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
Our G-ss-22-KGPA- frige is not cooling neither the freezer of frige part best to replace or fix???
  • Anonymous Mar 23, 2014
    temp in freezer is only 22 and the frige is 41
  • GE Master
  • 8,220 Answers
Posted on Jul 30, 2010
    President:
  • 1,796 Answers
Hi!!
Check
temp. control knobs,
Small fan in freezer
Remove freezer back panel (where the little fan is) and check for iced evaporator coil, if so, unplug unit and use a heat gun or hair dryer to melt ice, make sure the air duct going to the fridge is clear.
If evaporator is not covered w/ice, then you may have a freon leak, Call a Service Center to get a repair estimate and you decide to fix or replace.
Don't forget to rate this post!! Good Luck!
Whirpool gx2fhdxvy04 coils entirely forze over. thawed removed ice cleaned all drains and lines. pluged back in is cooling fine, but compressor has been running now continually all after noon. Freezer 5...
It is normal for the fridge to take a while to recover the cold temps after a manual defrost but if you did not test or replace the 12729128 Defrost Heater and the W10165425 Defrost Thermostat you will need to do the manual defrost again until you do replace, Thanks John Tripp Appliance 911
Feb 17, 2014 | Whirlpool GX2FHDXVY Energy Star 22 Cu. Ft....
Tip
If your refrigerator will not cool but freezer works good
alot of times if your frige is not cooling but the freezer works good most of the time all you need to do is defrost the whole frige for atleast 3 hours if that dont do the trick you may have to replace your thermostat timer that is connected to the dial in top section of the refrigerator sometimes it is turned up to high
on Mar 01, 2010 | Refrigerators
It is not cooling as well as it does usually. The freezer is cooling at frige temperture and the frige side is hardly cooling.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 31, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
I have a ge frige that the freezer works but frige is warm
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 01, 2011 | GE GTL18JBPBS Top Freezer Refrigerator
Refrigerator cool freezer not as cold as it should be
try turning of the frige and let it be of for 1day then put back on and see if will works usally does,if not next usally is the compressor does give enough cold.motherboards dont go bad usally very rare,check all the above before you buy motherboard.please leave comment,vote,note.thankyou
Sep 13, 2009 | GE Energy Star 22.0 Cu. Ft. Side-By-Side...
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Our freezer works fine ....but our frige isnt ..help!!!!!!!!!!
Your automatic defrost system is not working. There is a timer which controls the defrost by turning on the heaters for 18-22 minutes inside the back wall of the freezer section. after the defrost time it returns the system to cooling.
You have one of three items faulty. The timer, the heater or the defrost terminator switch.
Jul 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Ge profile side by side fridge
THIS IS CAUSED MORE COMMONLY BY A FAILURE TO THE MAIN PROCESSING BOARD NOT SENDING PWR TO THE DISPENSER RELY BOARD
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 29, 2008 | GE GSH22JSRSS Stainless Steel Side by Side...
GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Oct 25, 2007 | Refrigerators
GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
192 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
