Lcd tv model fpe2705 intermitently will not turn on. Need audiovox service center for out of warntee
    Genius:
  • 3,422 Answers
HI,
Can you please give the zipcode of your area so that i can find a service center
Posted on Apr 24, 2008
  • Priya darshan Apr 24, 2008
    Ok,you can contact NEI.
    NEI is a factory authorized
    service center for the following:
    Aiwa,
    Audiovox, Casio, Clarion, Cobra, Craig, Daewoo, Emerson, Fisher, Funai, GE, Goldstar,
    Hitachi, Kamp, Kenwood, Mitsubishi, Philips, Pioneer, RCA, Samsung,
    Sansui, Sanyo, Scott, Sony, Sylvania, Symphonic, Teknika, Toshiba,
    Welbilt, Zenith.
    Contact Us
    Call Toll Free:
    888-634-7278
    Goodluck..
AUDIOVOX fpe3707hr power lights up blue screen but no picture
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 07, 2017 | Audiovox Televison & Video
27 lcd model #fpe2705 no picture only sound
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!@#
Apr 21, 2011 | Audiovox FPE2705 27 in. HDTV-Ready LCD...
Hi my audiovox fpe2705 needs red color in shows only in green an blue thank you
remove back cover then check the CRT tube if there is color red cathode how?by using a wire or test prove connected in ground in your TV very quick if red screen flashes your CRT is good then check your CRT board socket find the driver transistor of red cathode then check it if shorted replace thank you
Mar 05, 2011 | Televison & Video
When I turn on the Audiovox FPE2705, it says the Audiovox logo, but then goes black. It looks like the back light just turns off. I think maybe the inverter or controller is turning the back light off. Is...
Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Otherwise indepth troubleshootong required or you may end up replacing the wrong parts.
Please post back what you find.
Nov 14, 2009 | Audiovox FPE2705 27 in. HDTV-Ready LCD...
I have a Panasonic TX 15LT2 TV, after about 15
the small signal panel needs to be replaced.
[main module]
take you tv to a factory authorized service center..
Nov 09, 2009 | Panasonic TC-22LT1 22 in. LCD EDTV
Audiovox fpe2705 inverter board replacement
You need to verify first that you do have 24vdc feeding the inverter boards, if you do have 24vdc then we can be sure it is the inverter boards. The inverter board will have very small surface mounted fuses, check for that also.
Dec 27, 2008 | Audiovox FPE3206 32 in. LCD Television
Audiovox FPE3206 - Power Light is Blue/ON but Screen is BLACK
I had the same problem, except with a flashlight I could see AUDIOVOX when i turned it on and I could see the video when I put a DVD in. It is hard to see even with a flashlight so you have to look closely. Well, I researched and investigated what might be the problem because I was upset that I had the TV for less than two years. Everyone was saying the inverter was defective. Apparently the inverter is what gives the LCD screen the back light to see the video. So I called audiovox and found that thier part's selection was only a power board and a remote control for this TV. I asked them if they could get me an inverter and they did. With shipping cost it was approximately $150.00. They ensured that I know that there is no refund on this part (which is common for electical parts). So I took a chance on it not being the right part for the problem. I replaced the defective inverter myself and it worked. It solved my problem. The inverter is a circuit board that plugs in and has a few screws to hold it in place. I had to remove the back cover first and a couple of brackets inside the tv to get to the inverter and replace it. There is a quite a few screws so I recommend writing down where each came from for easier reassembly. I hope this helps!
Oct 08, 2008 | Audiovox FPE3206 32 in. LCD Television
NEED A AC POWER ADAPTER
Had same problem. Found brand new power supply that is original part from website below:
http://www.encompassparts.com/products/?PWW302-AD13D-03
It was about $100 w/ shipping. Took about 4 days to receive. TV works again!!
May 28, 2008 | Audiovox FPE3000 30 in. HD-Ready LCD...
Televison & Video Logo
Top Televison & Video Experts
