P-lock unable to access pin-bought tv second-hand
Called insignia company, they told me they could not unlock p-code. went to insignia web site, entered model number of tv, downloaded free user/manual for the tv, and there was a code in there to reset the pass code and change it. problem fixed. you would think insignia company would have been more helpful to give me guidance.
Posted on Apr 25, 2008
Bought it second hand pin and puk code locked
Please try the Pin code 00000.
You will get the PUK pin from your cellular operator.
Please call the customer support of cellular number and get the PUK code from there.
Mar 22, 2011 | Nokia E63 Cell Phone
The only button on the panel that will light up is the 4 hr delay nothing else happens
This type of diagnosis will require taking voltage readings at the control board with a meter to find the root cause of the failure. Please see the rest of the information provided & the images below for the accessing, testing & replacement instructions.
1). Put the washer into the Diagnostic Test Mode per the Tech Sheet. 2). Did the Right Hand Interface light up? 3). IF the Right Hand Interface did not light up in Step 2 check for 5 VDC on the UIP3 wire connector coming off of the control board to the Right Hand Interface from (Pin 1 to Pin 2) and from (Pin 1 to Pin 3). 4). IF you do not have the 5 VDC then remove the MI3 connector from the Machine Control board. IF the display lights; replace the Motor Control board. IF the display does not light; replace the Machine Control Board. 5). IF you do have the 5 VDC then replace the Right Hand User Interface. 6). IF the Right Hand Interface does light up. Lock the controls by pressing the control lock button for 3 seconds. 7). Once the control has been locked press the power pad. IF the control lock light blinks when the power button is pressed it tells us the power button is sending the output from being pressed to the right hand interface but the right hand interface is not responding and will need to be replaced. 8). IF the control lock light does not blink when the power button is pressed replace the center user interface.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do you reset a pin code for a phillips tv
If you have not set your PIN-code when you first turned on the TV set, you need to do this before you can use the Child lock feature.
If you forget the PIN Code, unplug the AC power cord for 10 seconds to restore the PIN Code to 0000.
If you need to set your PIN Code for the first time, proceed as follows:
  1. Press the ' MENU ' button on the remote control to access the main menu.
  2. Press the cursor up/down to select FEATURES and press OK.
  3. Press the cursor up/down to select Child Lock and press OK.
  4. When the Enter PIN appears on the screen, enter '0000'.
Dec 07, 2010 | Toshiba 26AV502U 26 in. LCD HDTV
Alba hd tv, no remote and the child lock is on just need to bypass it model no lcd3288ohdf
Okay - this is a secret child lock that Alba puts onto their tvs - not the child lock accessible via the menu which is 0000 as default. Basically there is a childlock built into the handset. Basically if you hold the menu exit button for more than 10 seconds the handset locks - all that happens then is when you press buttons you will see the blue panel flash on the tv but nothing works. This lock happens when the remote falls down the side of the settee or your child gets their hands on it!!! To unlock, find the menu button on the right hand side of the TV panel and hold it for 15 seconds and the menu screen will pop up - Really important you hold for 15 seconds before releasing. Then simply press the menu exit button on the remote and 'hey presto' - you have control of your TV again! Kind Regards, BIG BAD JON !!!
Oct 31, 2010 | Televison & Video
Pin number
Pincode will be 12345
Jul 14, 2008 | Nokia N73 Cellular Phone
Locked out
Hold down On screen display button for maybe 10 seconds. This worked with our Tevion tv we bought from Aldi
Jun 13, 2008 | Jensen TS2750J TV
Televison & Video Logo
111 people viewed this question
Top Televison & Video Experts
