Question about Cyberhome CH-DVD 300 DVD Player
I have the Cyber home CD/DVD player. I can run CD but can't DVD.It shows a message after inserding a disk "NO DISK". Can anybody help me get any service help in Bangalore?
  • Cyberhome Master
  • 17,130 Answers
There is a possibility that your optical unit is faulty and might need a change. Since the model is not ery familiar you will have to check out with the local service centre the most approved ones in your city Bangalore for a confirmation. If the right model of the optical head is available , get a quote and get it replaced at the service centre so that your risk is low of buying one and finding it faulty if insttalled wrongly. If the new unit does not solve the issue then the main board could have a failure of the processing side. But it will be better that a trial change can confirm the fault before probing further. Hope you try this out. Good day
Posted on Jul 30, 2010
READ CD BUT NOT DVD NO DISK Disply
you need to replace the laser assembly in the drawer laser is going out
Jan 20, 2013 | LG LHT250SC Theater System
A disk is stuck in my blu ray player. I try to open the tray it says opening, then closing then loading, but then says no disk in player. I cannot open the tray at all and the disk icon doesn't show up...
Good day!!!
The problem could be on the DVD player and the lens of it.Please follow the D.I.Y procedures bellow:.
  1. Open the cover of your DVD by unscrewing it.
  2. Clean the DVD lens using CD cleaner.
  3. Try to use other new CD or the one with no scratch.
  4. Put an oil with the moving parts of it specially the side where the disc is stocked.
  5. If the steps # 1 to 3 are not successful.The problem could be on DVD lens.
  6. If the DVD lens is defective you better to buy a new player.Because the lens is expensive and it is not easy to install on DVD player.
Thank you!!!And hope to help you with all the best that I can...just consult or message me for any clarification or query..
and please don't forget to rate me and have testimonial....Thanks a lot..
Sep 12, 2011 | Sony BDP-S300 Blu-Ray Disc Player
I have a Digital Home Theater HT-DS400 Samsung. I have problems in reading a music CD or a DVD. You can read the message "Loading.." for a while and then stops and reads "NO DISC". ...
  • Make sure you have a non home made DVD. Some DVD players will not play DVD'S in certain formats.
  • If you have a normal DVD in the DVD player and are getting "NO Disk" then there is a real good possibility the lens is just so dirty that it is not recognizing your DVD at all. This happens a lot to all disk players that are neglected from the cleaning process. Get a disk player cleaner and run it through a few times until the disk is read again. Sometimes the lens is so dirty you have to try a few times just to get the cleaner disk itself to play just to do the actual cleaning. Make sure to run that cleaner disk through once a week. These disk cleaners "sweep" the lens and work well. You can get one at your local Best Buy for $8usd.
  • The last thing it could be is that somehow the lens has come out of alignment. Just a millimeter out of alignment is all it takes to not be able to read a disk and DVD players get bumped and knocked off the shelf easy. So this can happen often especially with the more smaller travel DVD player.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 23, 2011 | Samsung HT-DS400 System
Won't reconize disk in player
Well here is your resolution for your problem.
As you saying that when you insert any CD or DVD in Player its shows NO DISK.
Well Sometime what happen is if a CD contains are not compatible with Player than it wont work with it.
Or if you had burn that CD or DVD from your personal computer or laptop but it is not burn in proper format than also it wont work in PLAYER.
Well even if CD or DVD is having any scratches on it or it is Used uncounted enumerable times than also sometimes this things happen and it wont work in PLAYER.
Well before Inserting any CD or DVD in Player Just check the above mentioned points.
If everything is ok with the CD or DVD but than also its shows the same problem than get the CD or DVD cleaner liquid spray or even you can use Spirit to clean the CD or DVD and than Insert it.
After doing all this but if its shows no result in it than go to the company dealer and ask him to change the head of the player and you wont face this problem afterward for sure.
if you still have nay quarries regarding the same or any other you may reply me.
Naiven
May 23, 2010 | RCA DRC233N DVD Player
"No Disk" message
Your dvd lense need cleaning .
For that buy lense cleaner disk from nearest computer shop then put that disk into cd/dvd rom then play it then it clean dust from lense then you can use it again .
But if still same issue then you need to replace your dvd lense .
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 24, 2010 | Sony Bravia DAV-HDX265 Theater System
Disk boot failure insert system disk
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
Jun 25, 2009 | ASUS K8V-MX Motherboard
Incorrect disk
it might be the format it was recorded on,does it work on a cd player or your computer,try those and see what happens.
Dec 05, 2008 | Sharp DV-NC55U DVD Player/VCR
Invalid disk message sometimes and machine lock up
coby dvd-233 cd wouldn't spin invalid disc is displayed on the tv please help me solve this problem
Jan 21, 2008 | Coby DVD-233 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
117 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
