Question about Whirlpool Washing Machines
I had complain on 28.7.10 then person came on 28.7.10 & saying your washing machine senser gone. we require change this but i have not available. so, i will come tomorrow i.e.29.7.10 but still he is not coming. So, please give me the Pune any authintic service centre no.
  • Whirlpool Master
  • 8,220 Answers
What kind of sensor? I had complain on 28.7.10 - 5938d6c.jpge484d55.jpg Frontloadfbb051f.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jul 30, 2010
Green grease on washing model awm 372 3062 over 10 years old ?
Sorry to say but the water seal between the outer tub and the gearbox has failed and need to be replaced. Not an easy task and should only tackled by an skilled DIY persons. Repair kit and water seals are easily available from the manufacturer. Removing the center nut is a big challenge due to corrosion, soap residue and it requires a special socket.
Dec 28, 2013 | Speed Queen AWN432 Washer
Our front loading washing machine washer got damaged (pen drive got stuck). We complained in July.The machine continued to wash well for another one month. The samsung Customer care staff came on 24/8/10...
Well, if parts are not available, there is little that you can do with that machine. You can try non Samsung, like independent appliance stores, they have parts, often.
Oct 06, 2010 | Samsung Washing Machines
Power not coming, looks like back side bord gone. Its not available in show rooms in Abu Dhabi.
If the board had failed unless someone capable of repairing is not available , you will need to replace the board.
now if the board is also not available then you are stuck but to see if there is competent person to help out.
Ask them to check basically for power section, then the control circuits.
Sep 27, 2010 | Indesit W 83
Is the memory board gone in my electrolux washing
Sad to say, yes "Replace the board". Quote no. on the board as there are newer updates as models change.
May 23, 2010 | Electrolux EW1000i Front Load Washer
Leaking Water & Sqeaking
Main seal has gone bad and needs to be replaced. It might be worth it to you unless you are a mechanical person that you either have a company repair this part or replace the washing machine. The part is fairly cheap but the job is somewhat difficult. You can order the part at repairclinic.com
May 27, 2009 | Washing Machines
Will not agitate or spin
IN MY EXPERIENCE WITH MY INDESIT THAT SHOWED THE SAME PROBLEMS MY ON SWITCH HAD A LIGHT ABOVE THAT FLASHED A REPEATED PATTERN, I RANG THE MANUFACTURERS REPAIRS DEPARTMENT FOR THAT MODEL/BRAND THEY HAPPILY TOLD ME THE FLASH PATTERN FOR EACH FAULT & IT WAS THE TIMER THAT HAD GONE & THE BRUSHES IN THE MOTOR, EACH FLASH PATTERN INDICATED DIFFERENT FAULTS HOW OLD IS IT? DOES IT HAVE A SCART PLUG/USB TYPE SOCKET THAT CAN BE PLUGGED INTO, IF SO IT HAS A FAULT DIAGNOSIS SOCKET, WHICH MEANS A QUALIFIED REPAIR PERSON WILL HAVE THE COMPUTER & PLUG IN REQUIRED TO READ THE FAULT & REPAIR VERY QUICKLY, LOTS OF LOCAL REPAIRERS HAVE THAT EQUIPMENT SO YOU DONT HAVE TO USE THE EXPENSIVE SAY HOTPOINT ENGINEERS TO FIX IT, ITS POSSIBLE TO FIX IT YOURSELF AS I DID ONCE OR TWICE WHEN I HAD THE CORRECT PART NUMBERS OFFLINE..
May 22, 2009 | Washing Machines
Tumble dryer not working
SOUNDS AS THOUGH YOUR HEATER ELEMENT HAS GONE..
IT IS POSSIBLE TO FIX IT YOURSELF BUT VERY COMPLICATED, CALL OUT FROM A REPAIR PERSON IM AFFRAID, COMBI WASHER/DRYERS ARE RENOWNED FOR THIS & ALSO BEARING KITS
May 22, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
20 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
