Question about Garmin Forerunner 205 GPS Receiver
Battery is fully charged on my 205 and yet it turns itself off
My battery is fully charged on my 205 and yet it has started turning itself off while I am out running.
Can it be turn on when the device is attached to the cradle with electric supply?
If so, I think the battey is aged and it cannot be charged to the operating voltage to turn the device on.
A change of battery is required.
I had such a case recently.
Posted on Aug 13, 2010
  • Ama-10 Aug 17, 2011
    I have this problem , my forerunner only have 8 month old
My battery is fully charged on my 205 and yet it has started turning itself off after short time
Posted on Aug 06, 2010
4 Suggested Answers
eagle338
  • 4889 Answers
SOURCE: Garmin C330 Automatically turns itself off
Did you try upgrading the firmware?
Posted on Feb 27, 2008
SQUIRESXX
  • 486 Answers
SOURCE: My Garmin 1350 is fully charged. I used it
the software on garmin 1300 models is atleast 3.6/7 sounds like ur update didnt take, also check in settings see if you have a timer setting for sleep mode/stanby after x time
Posted on Dec 26, 2009
SOURCE: Garmin Forerunner 205 Battery won't charge. A few
Hey everyone. Just called Garmin and got it fixed. Sometimes the forerunner goes into power saver mode and needs to be reset
1. Hook up the usb cable and docking station to the computer.
2. Next, hook up your forerunner to the Docking station - It should pop up saying battery charging in progress
3. Leave it all hooked up and Hold the Mode and Lap/Reset Button together for 15 seconds - screen should go blank.
4. Let both go - should pop back up saying battery charging in progress.
5. Let Charge 20 minutes and it should be good to go.
Hope this helps!!!
Kenny
Posted on Dec 10, 2010
Why my phone keeps restarting
Battery may not be charged enough to run the phone. Keep the phone off and connect it to a charger to fully charge the battery or use an external battery charger.
Be sure the The micro usb connector is fully seated and that the battery is actually charging. A loose connection may appear to start the charging process, but if its loose, it may not be continuing to charge. Check the % progress.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Aug 11, 2014 | Samsung Galaxy S 4 GT-i9500 Smartphone...
The power on the Panasonic Palmcorder IQ PV-A206 turns itself off. I've tried plugging directly and with a fully charged battery, no luck.
please make this test and fix it. God bless you
If the video camera doesn't work, make sure the battery is charged (see The Battery Recharger Fix-It Guide) or replace a battery that won't hold a charge. Make sure the AC adapter is connected properly. Clean any dirty contacts on the battery, charger, and AC adapter with a cotton swab dipped in denatured alcohol. Remove corrosion with a clean pencil eraser, then wipe the area with an artist's brush to remove any debris. Find and test the fuse, if any.
If the power goes off soon after starting, recharge a low battery. Also, turn the video camera power off, then turn it back on and eject the tape. If the problem persists, check the fuse
If the battery won't charge, clean the contacts and fully discharge the battery, then recharge it. If the problem persists, replace the battery
If the video camera works intermittently, remove and reseat the to establish good contact. If necessary replace the fuse
Nov 08, 2013 | Sharp Panasonic Palmcorder Iq Model...
My battery is fully charged but when i turn the camera on it shuts right back off
SOunds like your battery is bad. try discharing it :
  1. Place the battery in your camera until it itself turns off. In this situation, the battery is fully discharged.
  2. Take out your battery and slide it into your battery charger.
  3. Connect your charger with power to fully charge the battery. It is normal for a new battery that battery indicator shows 100% capacity in 10 to 15 minutes. Please keep charging until there is no time left for charging.
  4. Fully charged and fully discharged or "cycled" as much as five times to condition them into performing at full capacity.
Try it and see if it works? If the batteries are not rechargeable then the problem is in the cameras power supply and you need to take it in or replace it.
Jun 13, 2010 | Sanyo VPC-T1060 Digital Camera
Dec 26, 2009 | Garmin nuvi 1350 Car GPS Receiver
Even when the battery is fully charged(3.6v) the player turns off by itself in a few seconds. However, when connected to a PC, it continues playing normally.
Dec 12, 2009 | Transcend T.sonic 610 MP3 Player
Phone turns on and off but wont start
try using ur phone while plugged in charging. if it works thn ur battery defective
Aug 05, 2009 | Nokia 6500 Classic Cellular Phone
Fully charged cellphone battery drains in a few minutes
relpace your mobile battery and avoid overcharging and charging overnight
May 22, 2009 | Motorola Mobility MOTORAZR maxx V6...
Camera turns itself off immediately even though it is fully charged
are you using rechargeable batterys or cheap ones
you have to get batteries specifcly designed for digital cameras or they wont power the camera properly.. try using different batteries !!
May 22, 2009 | Kodak Easyshare V1233 12.1MP Digital...
Motorola slvr unable to power on
wait until the phones battry get fully chrged working with a fully drained battery is bad to phone as wellas battery itself
Dec 04, 2007 | Motorola Mobility SLVR L7 Cellular Phone
Garmin Forerunner 205 GPS Receiver Logo
1,706 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
