Question about Durabrand W375-K Clock Radio
How do you set the durabrand CR502 alarm clock
Need instructions setting sharp alarm clock SPC293
hi cheryl.
this is all i could find,if this does not work go to the link and the bottom.
How to set time on sharp alarm clock? Change switch to BUZZER. 3.) Press and hold the ALARM button on top of the clock. 4.) Press HOUR button until desired hour is displayed.12 Feb 2013
Sharp Alarm Clock Inustructions by Matt Boysen on Prezi
https://prezi.com/vgxxmjfbc1ya/sharp-alarm-clock-inustructions/ Search for: How to set time on sharp alarm clock?
instructions setting sharp alarm clock SPC293 Google Search
Nov 05, 2017 | Sharp Audio Players & Recorders
Set time on alarm clock nlc695 nelsonic
Hi Joe.
this is all i could find.
How to set Nelsonic alarm clock? Press and hold the ALARM BUTTON to enter ALARM SETTING MODE. While still holding the ALARM BUTTON down, press and hold the HOUR and MINUTE BUTTONS until you see the time you want on your LCD DISPLAY. Release the TIME BUTTON and the Alarm Clock Radio will return to NORMAL TIME MODE.
USER GUIDE Alarm Clock Radio - Jazwares
jazwares.com/assets/pdf/userguides/13500_wwe_alarm_clock_radio.pdf Search for: How to set Nelsonic alarm clock?
or go to this link might help you.
how to Set time on alarm clock nlc695 nelsonic Google Search
Nov 04, 2017 | Audio Players & Recorders
I just got a Memorex Digital CD Alarm Clock with no manul the modle number is MC 7101. I'm not able to set the clock or alarm. I just need the instructions.
To set the clock:
1. With the power off, press the TIME button; the time will blink.
2. Press the MINUTE button to set the present minute and the HOUR button to set the present hour.
Make sure to set the correct AM/PM setting.
3 Press the TIME button (or wait approx. 15 seconds) and the time will be set.
To set or reset alarm time:
1. With the power off, press the desired ALARM, Press and hold the desired ALARM 1 or ALARM 2 button; the alarm time will blink. The Alarm 1 or Alarm 2 time and settings will appear.
Press the MINUTE button to set the alarm.
2. Press and hold the desired ALARM 1 or ALARM 2button; the alarm time will blink.
Press the MINUTE button to set the alarm minute and the HOUR button to set the alarm hour. Make sure
to set AM/PM setting. Press the ALARM 1 or ALARM 2button again (or wait approx. 15 seconds).
3. Repeatedly press the ALARM 1 or ALARM 2 button to select alarm off, alarm on, for buzzer, radio or CD.
If you needed the manual it could be downloaded:
http://www.retrevo.com/support/Memorex-MC7101-Clock-Radios-manual/id/1081dj880/t/2/
Thanks.
gylacz
Aug 01, 2011 | Memorex MC7101 Clock Radio
Radio of Durabrand Clock Radio WA-211C plays every hour on the ho
Thank you very much for your reply; I think I may have solved the problem by changing the Time settings to 24 Hour, rather than a.m. / p/m. I did this yesterday evening and the radio didn't come on every hour for a few seconds as it had been doing so I'm hoping this solves the problem, although there doesn't seem to be a logical reason why it should! I haven't yet tried setting the alarm function, so I can't be 100% certain that the problem has gone but I am hopeful.
On the basis that I had tried everything else, this seemed to be the only (last) possibility available; once again thank you very much for your reply - I don't know whether this solution is helpful to you.
Barry Sykes
Dec 29, 2008 | Durabrand W375-K Clock Radio
Durabrand CD Home System Model # HM3817DT - suffix no: E1/M1
if i turn my cd home system of i will have problems so it can turn on back. what can i do
Sep 01, 2008 | Durabrand STS92 System
Durabrand CD Home Music Sysem
This sounds too simple to fix your problem but on mine you push alarm clock once for on and again for off. Hope that helps.
Sep 01, 2008 | Durabrand Anti-Skip CD-895 Personal CD...
Durabrand hm3817dt alarm
I just bought the system yesterday and the same thing happened to me. I didn't realize the alarm was set and it kep going off at midnight. I think I just solved the problem. While the unit is off, press the standby button then the alarm button and wait for the alarm symbol to go away. This should do it.
I have another problem. Every time I turn the unit on, it comes on at about an 18 sound level waking everybody up. This happens even if the radio has been playing on low before turning it off.
Any solution to this problem would be appreciated.
David.
vikdave2006@yahoo.com
Jul 12, 2008 | Audio Players & Recorders
Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Jan 01, 2008 | Timex Nature Sounds LED Clock Radio
Durabrand W375-K Clock Radio Logo
352 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
