Question about Apple Power book G4 Refurbished Notebook - PowerPC G4 1.6GHz, 1GB DDR, 100GB HDD, DVDRW, 15.2&
Hi can i plug a magicjack in to a apple ibook G4
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
Yes you can do so.
Posted on Jul 30, 2010
How can i install magic jack on my apple ibook g4
Posted on Oct 02, 2011
4 Suggested Answers
thehumble1
  • 137 Answers
SOURCE: Apple iBook G4 Track Pad (Mouse) not funtioning
I think the first thing you should do is make all updates. I know that in some versions of the iBook G4, the trackpad does not work after installing OS X 10.4 (Tiger) before you do the updates. Update your OS X first. secondly, does the button work? Does the trackpad show up in the System Preferences menu? (under keyboard and mouse). It's very unlikely that the trackpad came unhooked unless someone has opened up your computer. If they have, there is a really good chance that they didn't plug it back in, because it's a hassle and easy to forget.
Posted on Apr 17, 2009
MacApplePi
  • 86 Answers
SOURCE: my apple ibook g4 will not recognize the charger
It takes a lot of force to break a charger connector in the charge socket, so the connector socket in the iBook will probably be damaged and needs replacing. Take it to a reputable repairer, or, if you have the skills, you can fit a replacement DC In Board.
Posted on May 29, 2009
Macs R We
  • 481 Answers
SOURCE: during start up my ibook g4 freezes at the blue
The blue screen marks the start of the login process. If the Mac freezes there, it usually indicates that some third-party System Preference is hanging the boot process. There are several ways to diagnose the problem. The simplest is to hold down the Shift key after hearing the boot chime. This will disable third-party System Preferences and should allow you to come up to the login screen. Then you can review the third-party preferences and go to the website of each of them to make sure you have the most up-to-date version that is compatible with your level of the Mac OS.
Posted on Nov 17, 2009
How can i play candy crush on my apple ibook g4
machine is too old for the required plugins.
Dec 07, 2013 | Apple iBook G4 Mac Notebook
I can not install viber apple ibook g4.when ever i try to down load i am told the application viber can not supported by this architecture
Hi Christy,
Viber appears to work only with OSx 10.7 and up, which is not supported on an iBook.
When they say "viber can not supported by this architecture", they're referring to the iBook not having an Intel processor like the MacBooks do.
Hope this helps!
Aug 19, 2013 | Apple Ibook G4 14", 1.33...
My G4 iBook screen goes dark shortly after I power-up, even If I hit the F2 key, the screen remains dark.
Got the same problem with my ibook G4.
I have research on how to fix it, and found out that most model of G4 has the same problem.
I soon found out the main problem and the solution, it would require some skill in soldering and dis assembling the whole laptop.
Go to this site and hope it will help you just it like it helps me a lot!
http://macintoshhowto.com/hardware/how-do-i-get-my-broken-g4-ibook-fixed.html
Thanks for using Fixya!
Dec 14, 2010 | Apple iBook G4 Mac Notebook
My iBook G4 will not turn on though it has a full battery & is connected to a plug socket also..
There are several models of iBook G4. The following sequence applies to the "14-inch Early 2004."
Remove all peripheral cables. Remove the battery. Reset the power manager by pressing the key combination Control-Option-Shift-
power. Then plug the iBook into AC power and attempt to start it with the power key.
If this procedure does not being it back, invasive diagnostics are required, in which case you should being it to an Apple-Certified tech for repair.
Jan 21, 2010 | Apple iBook G4 Mac Notebook
Extracting hard drive data from inoperable iBook G4 Apple laptop
well there is a solution so first check the type of hard drive in your ibook and check if any of your friends have an ibook, if so replace hard drive with yours and you can extract your data if your hard drive is working.
good luck.
Jan 05, 2010 | Apple iBook G4 Mac Notebook
My laptop ibook G4 power button is not functioning even if press
have you got it plugged in too charger, power button wont function if no charge in battery..... easy to forget when your freaking out about your 3k lap top... goodluck Chas
Jan 31, 2009 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Ibook g4 12" 800mghz freezes alot, especially when bairly moved
Hi Robert
Try a reset of the PMU, instructions here:
http://support.apple.com/kb/HT1431?viewlocale=en_US
All the best
Sean
PiDigital
Dec 30, 2008 | Apple iBook G4 Mac Notebook
Memory upgrade for ibook g4
Hi-
you can check a lot of sites where you can view and check onthe step by step guides how to install or upgrade the memory of your ibook, check this links
http://www.memorystock.com/memory/AppleiBookG412GHzM9419LLAMemory.html
http://www.edgetechcorp.com/memory/apple-ibook-g4-memory.asp
http://www.powerbookmedic.com/Take-Apart-Repair-Manuals-p-1-c-258.html
just select the type of memory card that you are using and it will lead you to a page where you can download a pdf file of the instruction.
Hope this helps, pls rate as fixya if it helps. thanks!!
Jun 26, 2008 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Apple Power book G4 Refurbished Notebook - PowerPC G4  1.6GHz, 1GB DDR, 100GB HDD, DVDRW, 15.2&  Logo
513 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
