Question about Dell 1201MP Projector
I have Dell 1200MP projector. I forgot the password entered in it. My projector is showing vertically upside down image. To change the settings it requires password. How to remove it? Please help.
Marrie
  • 563 Answers
SOURCE: nec vt 675 projector
Hi there
Simply go into the menu and flip it back in the subfolder that will either read Mirror or Horisontal / Vertical Positioning
Posted on Apr 10, 2008
  • 8 Answers
SOURCE: Vertical lines on projected image from a Dell Data Projector. White vertical lines are appearing at even spacing across the width of the image projected. At a loss to how to fix this. Any ideas as to
that is due to lcd filter units , try to align, precision work
Posted on May 25, 2009
  • 105 Answers
SOURCE: lcd projector projects images upside down???
if you go through the projectors setup menu you will find the option to invert / flip and rotate image adjust as required
REgards Al "alastech"
Posted on May 29, 2009
projdoc
  • 2237 Answers
SOURCE: dell 5100mp dlp projector - white vertical lines evenly spaced
clock and phase are off. go into menu and reset the settings to factory default.
Posted on Sep 02, 2009
son-of-EP101
  • 24 Answers
SOURCE: my projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Posted on Apr 12, 2010
Projector screen upside down
Check the settings for image alignment. You may have to look for the vertical and horizontal image settings.
This could be because the default is table mount and you may have mounted on ceiling.
Aug 26, 2014 | Panasonic VIERA Televison & Video
Image Upside-down
i think you should enter the setting mode and check their for image flip settings or something.
Apr 12, 2010 | Office Equipment & Supplies
The Infocus logo image is up-side-down even without connecting to the computer.
Many projectors allow you to vertically flip the image for mounting the projectors upside down. Each projector is different in how to change that setting, so I would look in your owners manual.
Mar 11, 2010 | InFocus IN36 Projector
Picture is upside down
Mar 09, 2010 | NEC MultiSync LT84 Multimedia Projector
Mounting the Projector from the Ceiling
Projectors, in general want to project the bottom of the image 1 foot above the lens at a typical range. When mounted upside down, they project the top of the image 1 foot below the center of the lens. If you don't want to turn the projector over, you'll have to change the angle and probably go to the extreme on the keystone correction.
Aug 05, 2009 | Dell 1200MP DLP Projector
Why is image upside down? the image appears inverted on the board
You need to set up the image using the menu. Press menu button on the remote then use the arrows to go down the list until you come to "mirror". Now press the enter button on the remote several times to cycle the orientation of the image (on some remotes you may have to use the right arrow button instead of the enter button). The projector will remember this setting next time it is switched on. These options are there for people who use ceiling mountings that hold the projector upside down.
Jul 10, 2009 | Epson EMP-S3L LCD Projector
1200MP DELL Projector flickering problem
You should not try it for yourself, Call a Professional instead.
Jun 26, 2008 | Dell 1200MP DLP Projector
Dell 1200mp
Hi jezzwhizz
You'll see that at the back of your Projector there is 2 VGA ports 1 in (normally blue) and 1 out ( normally grey ).
You are most probably using the grey one , switch it to blue.
May 06, 2008 | Dell 1200MP DLP Projector
DELL 1200MP projector problem
I don't know that particular model, but usually these are hung u pside down and the projector can flip the image. That should take care of it. Also, depending upon the angle to the screen, you may need to adjust the "keystone" as well. That will allow the final picture to be square as if the projector was at the correct angle.
Dan
Apr 17, 2008 | Dell 1200MP DLP Projector
Dell 1201MP Projector Logo
213 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
