I need to know how to download a Windows XP recovery disk on a CD. I'm currently on Windows 7 right now but my Windows XP laptop just got the blue screen of death and I need to know how to EASILY download a recovery disk for my laptop. The laptop is also 32 bit and it's an HP Pavilion
  • Deeznutz805 Jul 30, 2010
    It says I can't download it because I'm on a 64 bit computer
    F10 opens the BIOS. First of all my friend(s) would need to have windows XP. and second what are the chances they would have the disk. please be realistic.
  • 4,924 Answers
If you already have windows 7 on it ...you probably do not have the partition for recovery anymore...but if you will go to this location I will link you here ...you will be able to download a good and genuine windows XP ///with cd key ...The format will be an image file ..that you can burn on a cd with Nero ...just buy click double on the file (with the blank in and Nero installed into the computer ) or ..just use another Iso burner ...(image file burner)
For to make it easy for you I will link in order all the programs you will need to reinstall the laptop ..
First you need a torrent download-er to be able to download the windows xp image file ..
http://www.utorrent.com/
just download and install it ..and you will be asked for it to open the torrent file I will link here ...(the windows itself)
http://thepiratebay.org/torrent/5388204/Windows_Xp_Genuine
this one is the windows itself...you just have to click on download this torrent ..and open with the program above ...
After the download is finished ...(you will be notified by a baloon in the right corner)
you will need Nero to be able to burn a boot-able disk ..
Here is the best Nero I ever worked with ..simple and easy to follow ..just install it and when it asks insert the cd key in the notepad file ..for to be registered ..
http://www.mediafire.com/file/yznzmdonjgm/Nero 7.rar
If you follo wmy instructions ...and download the windows...and when you open it ..insert a blank cd ..and double click on it ..it will open the file with Nero automatically ..and start burning it on the disk ...When it will be finished..you will have a Genuine ..windows Xp bootable disk ..Be sure you note down the Cd key of the windows itself..it is in the folder ..cause without it ,,the disk is not functional ..
The only step ypu have to do before installing the laptop ...is to download the drivers for all the devices you have ..
Here I will link the Hp support site ..., and all you have to do is to go there ..select drivers download...and your model exactly ...and the operation system ...(xp in our case) ,,there will be all the drivers you will need after ...installation process ..
http://h20180.www2.hp.com/apps/Nav?h_pagetype=s-001&h_lang=en&h_cc=us&h_product=82710&h_client=S-A-R163-1&h_page=hpcom&lang=en&cc=us
This will be the most accurate way to end up with a clean installation and have no problems further ..but there is a way to contact the same HP forum I linked above ..and see if they provide recovery Cd-es ..but will not be that fast or ..free..
Posted on Jul 30, 2010
  • 11,800 Answers
HP Pavilion systems don't have a recovery disk, they have a hidden partition that acts as that.
To access and launch it: turn on the computer; when the initial blue HP screen appears Press the "F10" key, a Recovery menu will appear; click on "NEXT", click on "YES" .
Your system will now launch the recovery process.
If you have formatted the entire hard disk, (or replace it) then this is gone.  In that case either download a copy of of XP ( - http://www.tipandtrick.net/2008/download-unmodified-original-windows-xp-with-sp3-integrated-full-retail-and-vl-install-cd-iso-image-from-msdntechnet-plus-via-http-or-torrent/ -  or search one in Torrent) or borrow a XP disk from a friend and do a Repair install.
  • Azrael SRL Jul 30, 2010
     OK, you are using an laptop that is older than 4 years;  in that case press F11. If this also doesn't work you can order a recovery disk directly from HP.
    But are you telling me that none of your friends have a single XP install disk? Really, none?  I have 4, 2 bought as OEM and the rest from retail.
    Novelist:
  • 87 Answers
You have two options here.
Microsoft offers a downloadable tool for repairing operating systems, however it is for use on a floppy disc. This works great for desktop computers with floppy drives as well as older laptops. But most newer laptops do not have floppy drives. If you have an external or internal floppy drive for your laptop this is the best option. You can download the utility for windows directly from microsoft here:
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=E8FE6868-6E4F-471C-B455-BD5AFEE126D8
If you do not have a floppy drive bay then you need to get a hold of a windows operating system installation CD. You can run a repair-install from the installation CD which will reinstall all of the windows system files without harming any of your data or other software. (while a repair install should work this way, it may not always so I would recommend backing up your computer anyways before attempting a repair install).
Your laptop will no longer experience the BSOD issue.
please rate my solution
  • Nick Jul 30, 2010
    So are you running Windows XP 64-bit?
    The solution above only works for Windows XP 32-bit.
    You need to download the file and create the floppy disc on a computer running a 32-bit version of the windows operating system.
  • Nick Jul 31, 2010
    You need to download and create the windows XP repair disc using a 32-bit computer. Because of the way a 64-bit computer works it will not be able to correctly write a bootable 32-bit disc. You could use a computer with any 32-bit windows operating system to do this, but sadly this is the only realistic option if you do not have an attainable Windows XP 32-bit install disc to run a repair install.
    There are some other ways I can help you trouble shoot and resolve the BSOD if you would like and are unable to make the repair disc work out.
    Guru:
  • 632 Answers
There are no legal ways to download disks, However you can go to warez-bb.org and search for ISO there and burn ISO to disk using Magic ISO or something like that and use that disk but you must use your own cd key Not stolen or copied keys
    Master:
  • 515 Answers
You may have a CD from HP with Windows XP OS. Boot your computer with it and create a recovery disk if you like. If you don't have the CD, there might be a hiddle volume on your hard disk with the restoration files of your Operating System. Tell me your model number and I will check whether there is a hiddle volume for you. If you contact HP, they might send you a new CD if you provide them the model number of the computer.
    Genius:
  • 1,478 Answers
Place a CD in your cd ROM drive. Click on the "Download a Windows XP recovery disk from Microsoft" link. Click "Download." Then click "Save." Find your CD ROM drive on the menu and click "OK."
Remove the CD when the Windows XP recovery disk download is complete, and place it in the laptop on which you need to use it.
Take care.
    can you please provide me a link to what you said
Forgot Sony Vaio password
I met the same difficulty for the previous period,and I know the easy an effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other unlocked computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope it can help you soon.
Jul 25, 2012 | Sony Computers & Internet
Tip
How to Recover eMachines Notebook Windows Password
eMachines, as a brand-name laptop, is attractive to many netbooks users. We also call it as Acer eMachines for its developing history. We often receive letters from eMachine notebooks users on Acer eMachines password reset for forgotten eMachine administrator password. How to remove eMachines password or change eMachine password if I forgot Windows 7, XP, Vista password? Now, begin discuss the ways to unlock eMachine password.
1. Reset eMachines administrator password with other admin account
This means that we still can login our computer by accounts with administrative rights or privileges. Please never forget the default administrator, it may help much!
eMachines XP password reset from Safe Mode
A. Switch on eMachine Windows XP laptop and keep pressing F8.
B. Opt for "Safe Mode" and press "Enter" key at the Advanced Boot Option windows.
C. At login screen, choose the Administrator account and keep "Password" column blank (or input the changed password if the default Administrator account password has been changed before).
D. Start - Control Panel - User Accounts - select the account needed to change password - Change the password.
E. Input a new password, confirm the password again and then complete
Acer eMachine password removal on XP.
eMachines password recovery on Windows 7
We can recover forgotten password with built-in admin account:
A. Power on Acer eMachine computer and press the key: F8.
B. At the Windows - Advanced Boot Options, select "Safe Mode with Command Prompt" and press Enter to confirm. Then PC starts Windows.
C. Choose the Administrator account shown on the account screen, and then login windows - Administrator: cmd.exe. Input command: net user Lily abcd and Enter to confirm (Lily is the account needed to break password; abcd is the new password for the account).
D. After command finished, we can restart eMachine Win 7 laptop and login with account - Lily, password - abcd.
2. Break eMachines password with only guest account
We know that the guest account can not do more operations on a security PC. So, we have to refer to other way to retrieve the admin account for further operations.
Bypass eMachines password with recovery disks created before lost eMachine password
When input an incorrect password at the login screen, click "Reset Windows Password" and insert the eMachine password reset disk. The Password Reset Wizard will lead us create a new password to remove forgotten eMachines Windows 7 password.
Retrieve eMachine Windows password by DIY a password reset disk after forgotten
It is considered as the most instantly and easiest way to recover lost eMachine password. A .iso file, bootable CD/DVD/USB disk and accessible PC will solve problem within minutes without special techniques for a green hand on PC.
We can get the .iso file from many Windows password recovery programs. Just take one of the most popular tool - Ainorsoft Windows Password Recovery as example.
A. Download the suitable Ainorsoft Windows Password Recovery program and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible computer;
B. Boot the burned CD/DVD or USB Flash Drive from the PC password locked;
C. Reset the new eMachines password.
Ainorsoft Windows Password Recovery tool concludes Basic, Enhance and Corporation versions. The Basic is opted for Windows 7, XP, Vista, 2008, 2003,etc. CD/DVD disk suits for it! The Enhance version can be used with USB disk for the former OS. While, the Ainorsoft Windows Password Recovery Corporation is designed to Windows 7/Vista/XP/2000/NT/Server 2008/2003/2000 with bootable CD/DVD or USB Flash Drive.
Main methods on eMachine password reset are shared as above. Recover forgotten eMachine laptop password from Safe Mode or unlock eMachines password with password reset disk. Hope the any one help our eMachines computer users!
Article source: http://windowspasswordrecovery.net/article/emachines-password-reset.html
on Jul 08, 2011 | E-Machines eMachines Desktop PC
Tip
How to Reset Gateway Password?
How to reset Gateway laptop password? I forgot my PC password Gateway Windows 7, I want to unlock laptop password urgently! Can you help me recover my lost power on password for Gateway? Now, we together share some ways to remove Gateway admin password.
Optional 1: DIY a CD/DVD/USB password reset disk instantly to recover lost Gateway password
The method is the most effective solution to get out of Windows password problem. It just needs burn an .iso image file to one of these media. Now, take one of most popular Windows Password Recovery tool as example:
A. Download Windows Password Recovery and burn its .iso file into a blank CD/DVD or USB Flash Drive on an accessible PC;
B. Boot the burned CD/DVD or USB Flash Drive from the PC lost password;
C. Reset a new Gateway password.
Whatever for Gateway Windows 7, Vista, XP, Server 2000, Server 2008, etc. the above Ainorsoft Windows Password Recovery has its different versions to suit for these OS.
Optional 2: Gateway password recovery disk helps remove lost laptop password
It is the most convenient way to retrieve Gateway PC password and while, is maybe suitable for little part of computer users. The Gateway recovery disks should be created once our Windows account is created. Also, one account password responds to one password reset disk. Take Gateway Windows 7 as example:
A. Insert a CD/DVD/USB Flash Drive into the driver.
B. Click Start - Control Panel - User Accounts and Family Safety - User Accounts.
C. On the left pane, select "Create a password reset disk" - "Forgotten Password Wizard".
D. Click "Next" and follow the Wizard to create password reset disk.
Now, the Gateway Windows 7 password recovery disk is created. When we need break Gateway Win 7 laptop or notebook password on the login screen and input an incorrect password, click "Reset Windows Password" and insert the password reset disk. The Password Reset Wizard will help you create a new password to override lost Gateway password.
Optional 3: Reset Gateway password by accounts with administrative privileges
Accounts with administrative rights or the default and built-in account can help us to remove Gateway password. Take Gateway Windows XP as example, there is a default Administrator account. We can use it to unlock locked account if this built-in account is still blank or accessible.
A. Press Ctrl+Alt+Del twice when PC starts and then input "Administrator" in the username field and leave the password filed blank at the classic login screen. Press Enter and login PC.
B. Start -> Control Panel -> Administrative Tools -> Computer Management -> Local Users and Groups -> folder Users
C. Right click the account user name which password was lost, and then click Set Password -> Reset password -> keep New Password and Confirm Password blank.
D. Right-click locked account and select Reset password.
E. After finished, restart PC and login.
Optional 4: Ophcrack Windows Password Recovery software
Ophcrack is a free Windows password recovery tool which only works for passwords with less than 14 individual characteristics.
A. Download the Ophcrack LiveCD and burn its .iso file to a CD on an accessible PC.
B. Insert the CD into the locked computer and restart it.
C. When computer starts, we have to press the correct key to enter the boot menu.
D. After select the drive that the CD is in at start menu, do as the following instructions.
If we forgot Gateway laptop password and need Gateway password reset, we can easily reset Windows 7, XP, Vista password on Gateway PC or netbook with the above 4 optional methods.
Source: http://windowspasswordrecovery.net/article/gateway-password-reset.html
on May 06, 2011 | Computers & Internet
I forgot my password for my toshiba laptop
Hi Friend,
You need to download password craker for your password...
Windows Password Key 8.0 is considered as the best tool to reset local administrator and user passwords on any Windows system. It creates a password recovery CD/DVD, USB Flash Drive for home, business and enterprise with an extremely competitive price. And most of all, it's the most popular and safe solution for removing your Windows password until now. No need to call a technician, no need to re-install anything, and you certainly don't need to reformat. It works on all and any Windows versions and computers any age
1. 100% recovery rate
2. Very easy to use, with complete screenshots
3. Supports Windows XP, XP+SP2, XP+SP3, 2003, 2000, NT, Windows XP Professional x64 Edition (64-bit), Windows Server 2003 x64 Edition (64-bit) Operating Systems, Windows VISTA, Windows VISTA(64-bit), Windows Server 2008 & Windows 7.
4. Recover or reset all user and administrator passwords
5. Reset passwords with a bootable CD/DVD.
6. Reset passwords with a bootable USB drive.(Windows Password Key 8.0 Professional only).
7. All Windows Workstations supported
8. Support FAT16, FAT32, NTFS, NTFS5 file systems
9. Support RAID/SATA/IDE/ SCSI/SAS drives
10. Supports all Service Packs
Click here for download the password tools...http://www.rosoftdownload.com/download/windows/windows-password-key-pro/
Feb 14, 2011 | Toshiba Satellite M305D Notebook
Tip
Windows 7 Password Hack with Recovery Tool
To hack password in Windows 7 is not so easy than in Windows XP. If you ever forgot Windows 7 password, you may find that many effective Windows password hack solutions used for Windows XP doesn't work for Windows 7 due to its improved security features and you may have to find a new solution for your forgotten Windows 7 password hack.<br /><br /> What you should feel lucky is that <a href="http://www.recoverwindowspassword.com/">Windows password recovery</a> tool can still work for Windows 7. As a matter of fact, most Windows 7 users troubled by lost logon password resort to this kind of software like reliable <b>Windows Password Breaker</b> to solve their problems, because of its 100% recovery rate, easy & safe operation and instant password hack ability. Here we'll discuss 3 common problems you might encounter when hacking Windows 7 password with software.<br /> <b><br />Windows 7 password hack software</b><br /> <br />Today most Windows 7 password hack software on market is available in many versions with a little difference. Users who never notice the difference between each version may choose a wrong version, though there is a comparison table on its official website. Take this hack tool <b>Windows Password Breaker</b> for example, it is available in 3 versions: Standard, Professional and Enterprise. If you want to hack your Windows 7 password with a bootable cd/dvd, you can buy Standard version. If you intend to use a usb flash drive for your Windows 7 password hack as you have no cd/dvd drive, Professional version is right one. Please read the product introduction carefully and get a right version if there are several editions of your target <a href="http://www.recoverwindowspassword.com/windows-7-password-recovery.htm">Windows 7 password recovery</a> tool.<br /> <b><br />Hack tool installation requires administrator password</b><br /> <br />Windows 7 password hack tool need an administrator account to be installed. If you are familiar with computer, you definitely know that there are 3 types of user accounts on Windows 7, including administrator, standard and guest. And only administrator users have rights to download, install or uninstall a program, etc. But if you belong to those who have little computer knowledge, you may not know this. So you may be surprised at why the computer asks you for administrator password when you want to download or install your purchased Windows password hack tool and don't know what to do next. Once you encounter this problem, just download and run the password hack tool in a computer that you can run as administrator.<br /> <br /><img src="admin-to-install.jpg" /><br /> <b><br />Hack Windows 7 password by burning a bootable disk</b><br /> <br />Burn your own <a href="http://www.recoverwindowspassword.com/windows-7-password-hack.htm">Windows 7 password hack</a> bootable disk with hack tool. Majority of Windows password hack tool like <b>Windows Password Breaker</b> is to help users reset Windows 7 password in 3 simple steps: Burn a bootable password recovery CD/DVD, or USB flash drive; Set locked PC booting form burned CD/DVD/USB; Start hacking your Windows 7 Password.<br /> <br /><img src="password-hack.jpg" /><br /> <br />Besides, there is another problem deserves your attention that there is a BIOS password on your computer. A BIOS password can restrict access to your computer BIOS and you will be not able to hack it with this type of software.<br /> <br />When you intent to use software for your forgotten Windows 7 password hack, you'd better be aware of these above problems, and your whole hacking process would be easier.<br />
on Apr 11, 2011 | Computers & Internet
Tip
Toshiba Reset Password for I Forgot Toshiba Laptop Password
"I need Toshiba password reset! How do I reset Toshiba laptop? I would be appreciated if you help me Toshiba password recovery, etc." Well, so frequently to meet these problems in our lives. Today, we together share some ways to reset Toshiba password.
Solution1: Toshiba recovery disks help reset lost password
It only works if we created the recovery disks or CD before we forgot the password. The following listed are the steps to reset disk for Toshiba Windows 7 recovery:
a. Start PC, log on Windows 7 and insert an USB flash drive into the driver.
b. Start -> Control Panel -> User Accounts and Family Safety -> User Accounts -> Create a password reset disk.
c. In welcome screen click "Next" and select the inserted USB flash drive, click "Next".
d. Input the login password in the password field and click "Next". When progress indicator shows 100% complete, click Finish to exit. Remove the USB driver from PC.
The method is similar to create a Toshiba recovery CD. Now, the Toshiba Windows 7 password recovery disk is ok. Put it in a safe place for people may use it to reset your password.
Steps to recover password with created Toshiba password reset disk:
e. Click "Reset Password" in the Windows 7 logon window,
f. Insert the created Toshiba recovery USB disk into the USB driver interface, and click "Reset password" to open Password Reset Wizard. Click "Next" to continue.
g. Choose this USB disk recovery Toshiba from the drop down box. Click "Next" to continue.
h. Input a new password and re-input it again to confirm. Click "Next" and then "Finish" to close the wizard.
Solution2: Reset Toshiba laptop by accounts with administrator rights
If there is default or built-in admin account or other accounts with administrator privileges and rights, we can use it for Toshiba password bypass. Take Toshiba XP recovery as example:
A. Boot system from Safe Mode by pressing F8 when PC stars.
B. Access PC with the available account with administrator rights and privileges.
C. Start - Local Users and Groups - lusrmgr.msc in the Search box - ENTER - Local Users and Groups - choose Users.
D. Right click the account with unlocked password, select Set Password and then input and confirm the new password.
Solution3: Reset Toshiba password with burned ISO image file
We can burn an .iso image file into a bootable USB disk or CD/DVD and reset the forgotten password easily and quickly. Take one of the most popular Windows password reset tool - Ainorsoft Windows Password Recovery as example:
a. Download the program from an accessible PC;
b. Burn its .iso file to a blank CD/DVD or USB disk;
c. Bypass the lost Toshiba password with the burned CD/DVD on the locked PC.
Things will not be tricky if we know the methods for Toshiba password reset once we forgot Toshiba laptop password! Please also remember to share them with your friends!
source: http://windowspasswordrecovery.net/article/toshiba-password-reset.html
on Mar 16, 2011 | Toshiba Satellite Pro L300 Notebook
My daughters computer is a dell latitude D610 notebook running Windows XP.....when powering up XP starts to load and then goes to a blank blue screen....Is there a restore disc or something i can download...
Hi. I provided you a link where to download the restore disk. Once you have downloaded the restore disk, here's the instruction on how to use the disk.
Instruction:
  • Backup all the data you want to keep on an external hard drive, flash drive, or rewritable CD. Resetting your Dell to factory defaults will erase all data currently on your computer.
  • 2
    Insert the Recovery CD into your CD-ROM.
  • 3
    Reboot your computer.
  • 4
    Watch the text in DOS carefully. When prompted to boot from your CD, do so.
  • 5
    Choose System Restore and then follow the instructions presented. Once system recovery beings, it may take a few minutes. Once it's done, your system will reboot again.
  • 6
    Remove the Recovery CD from your CD-ROM and store it carefully. Your system has been reset to the factory default.
  • Nov 09, 2010 | Dell Latitude D610 Notebook
    I am getting a blue screen with error message: stop: 0x000000024 (0x00190203, 0x8A7DC5B8, 0xC0000102, 0x00000000) message I have run many diagnostic tests and all come back normal. it will not start in...
    You cannot see HD because there are no apropriate SATA drivers included in windows XP CD. So you need to create custom windows XP installation CD
    To install windows XP in that laptop u will need to create custom windows XP CD, how will you do that:
    1. Download nlite from http://www.nliteos.com/
    2. Download drivers for that laptop
    3. Download service pack 3 for windows XP
    4. Install nlite for windows XP and run
    5. Follow instructions and include SP3 for XP, all the drivers for laptop and create ISO Image
    6. Burn ISO Image
    7. Install Windows XP
    8. Good Luck
    Nov 25, 2009 | HP Pavilion dv5-1140us Notebook PC
    Dont have adminastrator password to open windows on old laptop
    Don't worry. I know a software called Windows Password Buster could help you reset the password.
    Nov 13, 2009 | Dell Inspiron 1545 Notebook
    Computers & Internet Logo
    Alun Cox
    David Payne
    David Payne
