Question about Dell Wireless Keyboard Optical Mouse w0147
I have brought my wireless keyboard and mouse to India with my laptop - they worked fine in the UK but on arrival here I can't make them 'talk' to each other at all! Have replaced the batteries and the green lights are on, so what shoudl I do?
    Problem Solver:
  • 7 Answers
Hi, two points of failure that I can see on your issue. First could be the BT software, 2nd could be the BT card which is a hardware issue. My first suggestion is to go to Control Panel, then Add/Remove Programs, look for and application named SetPoint then remove it. Most likely you're probably using a DELL computer, if so go to http://www.support.dell.com/ go to Drivers and Downloads choose your correct Computer model maybe laptop or pc; then choose your correct Operating system and platform if its 32 bit or 64 bit. Next update your Chipset driver, System Utilities - Notebook System for laptops and Dell System software for pc, then update your Input device driver - Bluetooth Wireless Keyboard and mouse Bundle, then update your Quickset under Applications and Synaptics driver under Input device drivers if it's a laptop you have, after doing everything restart your pc. If all is done correctly and still won't work work contact the manufacturer to replace your Bluetooth card since it's already a hardware failure. Thanks and have a nice day! =)
Posted on Jul 30, 2010
Wireless keyboard and mouse works fine with computer but when I attempt to use it on the f1dh104l switch it does not recognize the mouse or keyboard. it is a dell e6400 laptop that i'm attempting to...
the problem is that most Wireless Keyboard and Mice combos use Composite USB, the KVM however is expecting one signal on each entry port (one for mouse, and one for Keyboard).
replace yoru wireless Combo for a standard Keyboard and Mouse to make this work.
A work around would be using a MS Wireless Mouse and a different brand of Wireless Keyboard using both Wireless receivers and plug them into different ports on the KVM
Jun 05, 2011 | Computers & Internet
Working with the mouse to play just solitaire is super hard can I just buy a wireless keyboard and mouse for it
Yes. I would recommend using A simple USB wireless or wired keyboard mouse combo.
Any USB keyboard or mouse should work just fine.
Have Fun
Jan 26, 2011 | Sylvania G-Netbook
My wireless keyboard has stopped working
theres a grey reset button on the upper left side on bck of keyboard... problem is i dont remember how to sync it to the reciever??? im having same problem lol
Apr 10, 2010 | Logitech Wireless Access Duo Optical...
New keyboard and mouse no cd rom in box (logitech wave)
www.logitech,co,uk enter your specs and download updates
Nov 14, 2009 | Logitech Wireless Access Duo Optical...
Wireless Mouse on a laptop with built inTouchpad on the keyboard
No need to disable the touchpad they should both work at the same time. Have you tried both the mice on another PC?. The first mouse should have the correct software already installed but you will most probably need to install software for the microsoft mouse. I hope you have tried resetting by hitting the button on the receiver then while its flashing the button on bottom of the mouse? If all this fails do have any other USB devices you can test on laptop?......good luck
PS I hope its not the batteries
Oct 31, 2009 | Microsoft Wireless Notebook Optical Mouse...
I have a dell wireless mouse and it used to connect with my computer and work fine. I've had it almost a year but now it will not connect to my dell laptop. The light on my laptop and on the mouse will...
Most wireless keyboards and mice have their own wireless receivers (one that should be connected to the computer). The wireless receiver usually has a connect button that you need to press in order for you to connect the keyboard or the mouse. Try holding down the connect button on the receiver and on the keyboard at the same time for five seconds and release them both after five minutes.
If that work, do the same for the mouse.
Hope this helps and have a great day!
Jul 06, 2009 | Dell Wireless Keyboard Optical Mouse w0147
USB wireless keyboard doesn't work
You need to unload the USB drivers for the keyboard and let windows find them again at restart. How does a novice do this? It's not hard. Go to Start, Control Panel, System, Hardware, Device Manager, Keyboards. Right click on this and select uninstall. Reboot your machine. If the drivers are not corrupted they should load fine, if they are corrupted then Windows will ask for the original operating system disk.
All this assumes that your keyboards are electronically working. This last holiday season alot of people brought in their Logitech - Target specials that no longer worked. Seems that if you insert the batteries backwards once the keyboard no longer operates (mouse OK). Never checked in to it too deep.
Good Luck
Mar 19, 2009 | Acer Aspire 5100 Notebook
Logitech Wireless CE 0682 Keyboard won't work but mouse does
did this come with software
and you might need to do a uninstall reinstall
if it worked on same pc before it should work now.
if you have a reset button on transmitter try resetting it.
Dec 30, 2008 | Logitech 967437-0403 Keyboard
Installing my wireless keyboard and mouse
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Feb 20, 2008 | Micro Innovations KB985W Keyboard
Dell Wireless Keyboard Optical Mouse w0147 Logo
130 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
