Question about Universal Battery Charger Charges Multiple Combination
Rechargable Batteries Battery Charger
How do I know, from the indicators, when the batteries are fully charged??
  • Anonymous Mar 22, 2014
    how do I replace the batteries in a Brookstone Automatic Wine Opener SKU 606638. Charger appears to be working, charge indicator light on opener is lit.
  • 25 Answers
When batteries are placed into the charge mode, the red light will come on.
When fully charged, on those units with a green light, the green light will be an indication that your batteries are charged and if your unit has no green light, the fully charged indication will be when the red light turns iff.
Posted on Apr 24, 2008
  • colliewell Jan 22, 2011
    1 A dynamic liquid crystal display charging status, non-polar adjustment shrapnel, positive and negative auto-conversion, built-in intelligent control circuit, full power 100%, shows full charge, and automatically stops charging, safe, reliable, intelligent dynamic liquid crystal display, accurate to indicate charge status (1 % -100%), so that the process of charging more accurate, more clear, constant current constant voltage charging a revolutionary way to make a more saturated built-in battery charging and high-performance switching power supply, voltage adjust range, AC: 110v-240v uses micro-computer chip control the charging process, fast, efficient, full automatic shutdown
The large screen doesn't work
I don't know what camera you have, so I only can give a general solution.
The most common cause is a battery (batteries) that don't have enough power. Make sure whan you have rechargable batteries, they are fully charged. But after a few years it could look your charger let you know the battery (batteries) are full but in reality they can't be charged to the full capicity.
If you do have a multimeter, you could check the battery.
On the multiemeter the voltage should be a little
(few tenths of a Volt) higher than what is printed on the battery.
If after charging the voltage is a little or even much lower, it should be replaced.
Nov 09, 2013 | Cameras
HELLO: OUR MILWAUKEE 48-59-2401 BATTERY CHARGER IS NOT CHARGING OUR 48-11-2401 BATTERY PACKS. WHEN YOU RUN THE PACK DOWN TO 1 OR 2 LIGHTS & PUT IT IN THE CHARGER BOTH RED & GREEN LIGHTS FLASH....
If both lights are flashing after you put a cool battery on the charger, the battery is bad. It could have a bad, worn or shorted cell or other problems inside and the charge will not charge it as long as it reads it as a bad battery. Rechargable batteries do have a finite life determined mainly by how many times you recharge them.
Jan 20, 2011 | Garden
How to charge kodak c142? is the data cable which is used for copy the pictures to the PC also charge batteries?
I don't believe these batteries with this camera are rechargable. the spec sheet calls for alkaline batteries. Do the batteries in the camera say rechargable on them. There is a Kodak battery charger with batteries , but that is a multipurpose charger for many cameras, and all it does is charg batteries like any other batter charger.
Nov 27, 2010 | Kodak EasyShare C142 Digital Camera
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
How 2 charge a kodak with rechargable batteries!!!
get a charger for the rechargable batteries. Charge the batteries and then put them into the camera. You cant really chare the camera..
May 02, 2009 | Kodak EasyShare C613 Digital Camera
Problem of rechargable battery
The best way to tell if it is a battery problem would be to charge them fully then use the camera and see how long they keep working as compared to what their specs are (probably in your camera info). It is also possible that the charger is at fault, which can be tested by measuring the output of the charger with a meter, or check to make sure the charger is the proper one for those batteries ("quick" chargers may need special batteries, etc.). If your camera can use alkaline batteries of the same type, try new ones and see if it still says "low" -- if so then it could be the camera. Hope this helps. If not, check your camera website and try troubleshooting there.
Oct 23, 2008 | Canon PowerShot A570 IS Digital Camera
Which batteries are the best? Can I use alkaline, lithium or any others with this camera?
Lithium is actually one of the most widely used as it contains a higher charge. As for alkaline batteries they dont hold a high charge and may cause problems with your digital camera.
I hope this has answered your question sufficiently. If you have more questions please post a reply. Thanks.
Sep 22, 2008 | Kodak EasyShare Z712 Digital Camera
BATTERY CHARGER RADIO SHACK DELUXE 10 CELL
I would go to Radio Shack and have them explain the proper charging procedure as well as inquire about the red and green lights as not all chargers go green when fully charged-Normally red indicates a charging action and if a charger has no fully charged light, then a required charge time period is noted in the instructions. Batteries can be ruined by over charging!
Jan 03, 2008 | Energizer Rechargable Battery with Charger
Energizer charger not charging batteries
It is most likely the batteries are no good not the charger
Mar 22, 2017 | Energizer Rechargable Battery with Charger
Universal Battery Charger Charges Multiple Combination Logo
637 people viewed this question
Top Universal Electronics - Others Experts
Are you an Universal Electronics - Other Expert? Answer questions, earn points and help others
