Question about Tippmann 98 Custom Act Paintball Gun
Air hose problems
The air hose came unattached from the chamber. i placed it back and now when the co2 container is attached it makes the sound of air escaping what is the problem and how do i fix it?
    Novelist:
    Scholar:
  • 111 Answers
You've either stretched the hose at the end, it has a tear, or it burst earlier. If you have any spare length you can trim the end and reattach it.
Likely though it's just barely long enough so you just need to pick up another one from your local paintball store or airsmith and pop that ****** on and you're back in business!
Play hard, play safe, play with honor!
8^)
Posted on Jan 04, 2011
Need to remove valve cover on 2000 Camry Toyota
For the four cylinder engine:
  1. Remove and label all electrical wiring, connectors and vacuum hoses necessary to gain removal clearance.
  2. Remove the spark plug wires. Disconnect the PCV hose.
  3. Remove the four nuts and grommets located on top of the cylinder head cover.
  1. Remove the cylinder head cover and the cover gasket from the cylinder head.
  2. Discard the gasket and replace with a new one.
To install:
  1. With a wire brush or gasket scraper, remove all the old gasket material from the cylinder head and the cylinder head cover gasket surfaces.
  2. When the cylinder head surfaces are free and clean, apply beads of sealant to the cylinder head in the locations shown in the accompanying illustrations.
  3. Install the new cylinder head gasket in the cover. Make sure that the gasket seats evenly.
  4. Place the cylinder head cover with the gasket onto the cylinder head.
  5. Install the four grommets and nuts. Uniformly tighten the nuts in several passes to 17 ft. lbs. (23 Nm).
  6. Connect the PCV hose. Connect all removed vacuum hoses, connectors and electrical wiring. Connect the negative battery cable.
  7. Start the engine and inspect for oil leaks.
  8. Repair any leaks as necessary.
For the V-6 (3.0L) engine:
  1. Drain and recycle the engine coolant.
  2. Disconnect the radiator inlet hose.
  3. Disconnect the throttle and accelerator cables.
  4. Remove the air cleaner cap assembly.
  5. Remove the V-bank cover. Use a hexagon wrench to loosen the nuts.
  6. Label and remove all emission control valve hoses. Disconnect any wiring interfering with the valve cover removal.
  7. Remove the air intake chamber. This will gain you access to the back valve cover.
  8. Disconnect the engine wire from the left hand side, No. 3 timing belt cover, rear side and right hand side. Most of the wiring is secured by nuts and or bolts to the body of the vehicle.
  9. Remove the ignition coils, make sure the place them in order on a table so not to mix them up.
  10. Remove the 8 bolts retaining the valve covers and gasket.
  11. Clean the mating area of the valve cover and cylinder heads well. If necessary, scrape any left gasket from either surface.
  12. Apply seal packing to the cylinder heads and place new gaskets into position.
  13. Attach the valve covers. Uniformly tighten the bolts in several passes to 69 inch lbs. (8 Nm).
  14. Install the spark plugs in their proper locations, then place the ignition coils into place and secure.
  15. Attach all engine wiring be sure to secure each harness properly.
  16. Install the air intake chamber. Refer to Fuel System .
  17. Attach all emission hoses and wiring.
  18. Attach the V-bank cover.
Apr 15, 2014 | 2000 Toyota Camry
LINCOLN ERROR CODE 2197 02 sensor signal stuck lean bank 2, sensor 1
The gas smell should resolve itself when you get the O2 sensor changed or find the cause for the lean condition. What is happening with the gas smell is the system is trying to add gas to solve the lean condition
There are many ways to look at this. Since 1 cylinder has not been blamed for the problem, the O2 sensor averages the exhaust to determine rich and lean mixtures. If extra air is seeping into the exhaust either after the combustion(exhaust manifold) or before combustion(Intake manifold) the resulting exhaust will contain more air in the mix and be classified as "Lean".
Your engine may have different features depending on the Year, Model, and engine size, v-6 or v-8. There are air venting devices in the Intake Manifold that may be the cause of the problems too.
These parts are the ISC solenoid and the Manifold Runners. Modern Intake manifolds have 2 chambers with the runners changing the chambers. If the runners are dirty, they can stick. One chamber can provide more air than the other and it will cause an imbalance, misfire, and incorrect fuelmix.
There are operating PODs which can work by Vacuum or Electric and they can become inoperative or unattached and fail to move the Manifold runner. These smaller parts are less expensive than the runners and could be all you need. Sometimes the plastic clips attaching the PODs to the runners breaks.
The people who see the most Lincolns to work on are usually Lincoln or Ford dealers. This does not mean a Private garage can not do a competent repair for a lower price. Sometimes Ford parts are cheaper and interchangeable with Lincoln.
It may be worth it to just change the O2 sensor to see if it is accurate or not. Then if the problem goes away, you have saved a big repair bill.
Please rate my info.
Jan 14, 2013 | Cars & Trucks
Engine missis at 2-2 half rpm under load.
Ok, if the car is misfiring it probably has a bad air/fuel mixture which can cause fouled spark plugs. The causes of a bad air/fuel mixture would could be a bad oxygen sensors or a bad engine coolant temp sensor. But that car is known for having bad head gaskets. What is probably happening is coolant and/or oil is leaking into the combustion chamber. you can check under the cars engine, where the head meets the block, for oil or coolant leaks where they attach. Or check the coolant for CO2 with a CO2 tester (found at auto parts store) and check for low oil. If it tests positive for CO2 in the coolant then its a blown head gasket. once you get the problem fixed you will probably need new spark plugs and possibly a catalytic converter (the longer it misfires, the more fuel will be burned on the cat filter and it will enventually melt)
May 03, 2011 | 1997 Subaru Impreza
How do i hook up the upholstery cleaner attachment up and use it?
First the bag assembly and head (or hose) must be removed. The hose fits onto the motor outlet in place of the bag. You will see a small arrow on the motor end of the hose. Line the arrow up with the "bump" on the metal fan housing and turn it clockwise to snap it in place. Be sure it is fully in place, or the motor will not run. Your attachment box contains an air intake guard which goes on the front in place of the head. Remember - the motor also will not run with the fan exposed. Turn the motor on and blow any dust out of the hose before putting the spray gun on the end of the hose. To make foam, the small foam screen must be attached to the spray gun outlet.
Feb 08, 2011 | Kirby Ultimate G Bagged Upright Vacuum
1993 jeep grand cherokee havc code 06
Chrysler & Jeep Cooling System & HVAC Service: Every car make has its quirks, and Chrysler and Jeep vehicles are no exception. In researching this article, we found several examples of heater problems in these vehicles that seem to be fairly common.
On 2001 and 2002 Sebring Sedan, Sebring Convertible and Stratus Sedan, plus 1993 to 2002 Chrysler Concorde, LHS, New Yorker and 300M, Eagle Vision and Dodge Intrepid models with V6 engines, customers may complain their engine is overheating, or the heater is putting out little or no heat.
Chrysler Technical Service Bulletin 07-002-02 says the problem can be caused by a low coolant level in the cooling system. On these vehicles, air trapped inside the cooling system can displace coolant when the system is refilled. The radiator and coolant reservoir may appear to be full, but there still may be air inside the heater core and heater hoses. This will create a low coolant level that may lead to overheating and low heater output. The bulletin provides a special fill procedure to eliminate the trapped air so the cooling system can be completely filled.
The procedure goes as follows:
1. Obtain Chrysler special tool 8195 (Cooling System Filling Aid). The tool looks like a funnel and attaches onto the filler neck (just as a regular pressure cap does). But it also has a hose clip.
2. Attach the filling aid tool to the cooling system filler neck. Use the clip to pinch off the overflow hose attached to the fill neck. Attach a 4-6' long 1/4" ID clear hose to the bleed valve. Put the end of the hose into a clean container (to prevent coolant from spilling onto the accessory drive belts).
3. Open the cooling system air bleed valve before any coolant is added. If you do not do this, air can remain trapped inside the system and you won't get all the air out. On 1998 and later models with 2.7L engine, the valve is located on the water outlet connector at the front of the engine. On 3.2L and 3.5L engines, the valve is located on the lower intake manifold, left of center under the upper intake manifold. On 1993-'97 models with 3.3L and 3.5L engines, the valve is on the thermostat housing.
4. Pour a 50/50 mixture of coolant and water into the large side of the filling aid funnel. Use distilled, deionized or reverse-osmosis purified water, not ordinary tap water, which may contain salt or minerals that could contaminate the coolant.
5. Slowly fill the cooling system through the large side of the filling aid. Watch the hose connected to the bleed valve. When a steady stream of coolant comes out of the hose, close the bleed valve and continue filling to the top of the filling aid.
6. On 1993-'97 models, place a small, clean container below the end of the overflow hose. Then remove the clip from the overflow hose. Any excess coolant in the filling aid will now drain into the overflow section of the coolant bottle or into the container.
7. On 1993-'97 models, remove the reservoir and recycle the excess coolant.
8. Remove the filling aid from the fill neck. Make sure the filler neck and cap are clean, then replace the pressure cap on the coolant bottle.
Note: 1998 and later coolant bottles have two chambers. Coolant will normally only be in the inboard (smaller) of the two. The outboard chamber is only to recover coolant in the event of an overheat and should normally be empty - except for the coolant drained from the filling aid. This coolant will be drawn back into the pressurized side of the cooling system over time.
Hope helps.
Jan 12, 2011 | 1993 Jeep Grand Cherokee
Envirovac kicks debris back at my feet and is loud
It's clogged!
Many so-called "environmentally friendly" vacuum cleaners have multiple stage filters; the usual configuration is a standard filter followed by a HEPA filter or equivalent. Standard filters can be a paper bag or a bagless, removable container.
From time to time, the secondary filter will get clogged, so it doesn't matter whether you change the bag or empty the container, performance will not improve.
If you have access to compressed air, try removing the secondary filter and blowing it clean with a high pressure air nozzle. If that doesn't work, check the hose to make sure it's clear. If you are using a rug beater attachment, make sure it has not clogged at its inlet.
Sep 06, 2009 | Eureka High Filtration s Mighty Mite...
My hose tools wont pick up. when hose tools unattached suction is fine and will **** my hand fiercely, but once tool attached no suction..... how am i gonna pick up cat hair from seats now?! its a dyson...
I have a DC04 and the hose tools are a open hole.The only reason they want pick up is they are blocked.If you say they are sucking your hand when not attached.Make sure the hose is not blocked by taking off the cover at the front.Allso check the cylinder rubber seal is sealing the dust container.Thats the only problem i had with mine.Good luck.
Jul 31, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
Water fill does not shut off
problem caan be the pressure switch. to test it, put on a length of hose, set machine going and use your mouth to pressurize the hose and water should stop. if it doesn't then pressure switch is faulty.
also the pressure switch hose goes to an air chamber and this can be clogged with gunge
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Put together
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5.
Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator:
Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI
See Fig's. 1 & 2
of the rail first)
screws at the rear)
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
6. Installation of C02 Regulator: Attach the CO2 Regulator to
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
LL'N TAP ACCESSORIES (included with this unit)
Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Tippmann 98 Custom Act Paintball Gun Logo
83 people viewed this question
Top Tippmann Sport & Outdoor - Others Experts
spank61
Tom Chichester
Are you a Tippmann Sport and Outdoor - Other Expert? Answer questions, earn points and help others
