Question about LG Dryers
Dryer wont heat replaced the ignighter and still cant get dryer to heat lg 5988w
  • LG Master
  • 8,220 Answers
Posted on Jul 30, 2010
How do I light the pilot light on my LG 5988w dryer
It may have an igniter rather than a pilot light
Jan 23, 2017 | LG Dryers
How do you remove the back off a LG Model # 5988W dryer
The belt gets replaced from the front of the unit, you have to remove the top, and front bulkhead first.
Dec 19, 2014 | LG Tromm Front Load Washer And Dryer Set
Wont heat checked thermo fuse and ignighter both ok
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 31, 2011 | Roper RGX4634KQ Gas Dryer
My problem is when i start my dryer it ignights and runs till it heats up and the the flame goes out till it cools off and then ignights and so on
Hi- Sound like the high temp. thermostat is tripping. You may try running it without the vent attached and see if it will run that way. I have had this happen when the vent is too obstructed and the heat cant get out fast enough. Otherwise have someone out to look at it. Hope that helps a little.
Sep 24, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer wont heat up. It runs fine but no heat. Replaced the Thermal fuse"flat white with 2 wire terminals.
gas or electric ok gas replace gas coils check glow bar ignighter,check thermostates,,,,,,electric check power to both sides of wall outlet you need 220 volts and it will start and timer will advance on 110 vts second check second fuse looks like a thermostate normally located at top of heater coil call if you need to http://www.washerwizzards.com
Dec 24, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The heating element wont heat up. I've already checked the obvious solution, the dryer vent is clear of lent. Is there a fuse that I can replace?
yes there is need to check the thermal fuse first then the high limit thermostat. then the heating element
Nov 05, 2009 | Kenmore 63942 Dryer
Dryer won't heat up. Replaced ignighter, still
I would suspect faulty gas valve coils. These electrical coils are right above the gas valves and when energized these solenoids open the gas valves to permit gas flow to the burner. It's recommended that if any are suspected of being faulty that both (all) be replaced at the same time. Really sorry for your trouble and I hope this helped. Best wishes.
Sep 11, 2009 | Kenmore Elite HE4 Electric Dryer
Front load gas dryer lg model dlg 5988w does not heat
This can obviously be several things, but I would first check the small safety thermostat. On the gas models, there is a small pin sticking out of it which can be pushed back in to reset it. It is located on the heater housing and is only about the size of a dime, with two wires on it. This will trip out easily if your vent was not clean, or is long or restricted in some ways (like using flex ducting)
If you need more help getting to it, let me know and I'll give you more instructions.
Dec 22, 2008 | LG DLG5932W Gas Dryer
Burner wont light
there is a heat sensor with a little window mounted on the side of the round tube it maybe bad it closes when the ignt glows red
Jan 01, 2008 | Whirlpool LGR8648 Gas Dryer
Dryers Logo
54 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
