Question about Toro Lawn Mower With Toro Power Tools
Blades stop going even though engine keeps going. Have just spent nearly $500 on getting it fixed but problem has returned Martin
  • 10,865 Answers
Martin. If you just had it fixed for that amount, call the repair store and complain. They should make it right. J.
Posted on Jul 30, 2010
My printer will not print in Windows 8 / 8.1 and even though I have a driver that may work it will not install!
Simple fix... 1St. Give the make and model of printer
Also, you may want to go directly to the printer website for the correct drivers.
Apr 26, 2014 | Microsoft Windows 8.1 - Windows
My Royal Enfield Electra 2009 Classic, Engine Doesn't Stop Even After Turning the Switch/Ignition Off. If I try to stop using the gear then also it keeps going (Ignition Turned Off). After it stop
have a bike electrician check it out
I suspect that there is problem relay/regulator in the charging circuit that is allowing the alternator/generator to keep supplying power to the ignition outside the ignition switch circuit
could be a shorted wire
The dead batteries indicates this by discharging through the same fault.
Dec 31, 2012 | 2010 Enfield Electra Twinspark
John deere LA145 manual
When I start the engine the mower blades start to turn. The blades turn as long as the engine is running. The PTO does not stop the blades from turning even when I stand up off the seat or when I go in reverse. What should I look for to fix this problem. I have a LA145 mower, 48" cut, bought in 2010. Thanks for your time & help.
Aug 02, 2012 | Garden
Won,t move
Check the pump.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 20, 2010 | Husqvarna Zero Turn Mower Z5426
The blades on my hedge trimmer stopped moving even though the engine is running
There is a cable that runs down the shaft and some times when grass gets built up on the head it will overheat and melt the plastic piece that runs the blades. you will have to get a new shaft
Feb 06, 2010 | Garden
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Abs light
It most likely is your ABS control module. You can have it removed/replaced for $500 to $1000. Or---you can go to Vic Rocha on web where he has diagrams for removal, ship it to him, $140 repair including return shipping and you reinstall. This module fails on all cars between 60K and 100k. Mine has been repaired for several weeks and works fine.
Apr 21, 2009 | 1999 Volvo C70
Toro Lawn Mower With Toro Power Tools Logo
99 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
