Question about GE GSS25SGMBS Side by Side Refrigerator
Compressor is not running is there a reset switch
Compressor is not running lights are on in fridge so it must be getting power is there a reset switch
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Damage was caused by electrical problems, you can check from Thermostat, whether still working or not. then check the timer on your fridge, the timer's function is to turn off and turn on the compressor, periodically. and do not forget to check the overload / thermal protector and relay (PTC) attached to the compressor.
Posted on Jul 30, 2010
Light on but not cold
We could use a few more details to identify the problem. Does the fridge turn on fine and run (is there a noise at the back?) Does the back get warm at all? Have you defrosted it recently? most similar fridges do not have a resettable "pressure switch". some have a resettable thermal cutout on the compressor, usually on the side. unplug the fridge from power before rooting around the compressor area. Hope this helps - awaiting more info :)
Sep 08, 2007 | Amana ACD2234HRS Side by Side Refrigerator
Refrig won't cool on either freezer or refrig side. Confirmed manual settings & allowed 24 hrs for cooling. Is there a reset switch somewhere other than manual switches inside refrig?
check that the compressor is working by feeling for motor vibrations at the compressor, hot compressor unit or hot fins or back wall of the fridge
if there is not heat then the compressor is not working
call a technician as it could be a start/run capacitor failed or compressor seized
get a quote as some compressor replacements cost as much as a new fridge
check that the utility power is getting to the fridge/freezer
Jul 10, 2016 | Refrigerators
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Amana Regrigerator Stopped Working After Power Supply Loss
unplug it and leave it off for an hour. then plug back in this may reset it. power coming back on can be higher than normal its always best to turn things off so when the power comes back on and you switch it back on its at the correct voltage.
Feb 28, 2018 | Amana Refrigerators
I have a Whirlpool mod. ED5LHEXD00 refrig. I left home for 3 weeks in Dec. with the house temp. set to 50 deg. F. I got home and discovered that the refrig./freezer was at room temp and all the food had...
If Fridge working fine now, the problem may be is Hydro Grid.
When the fridge just start, the compressor is running with high pressure of Freon. If Hydro power has voltage surge or power Off/On ( suddenly ), the compressor should be stuck, the overheat protection switch will actived, than fridge will stop working.
The noice of "click" - properly is overheat switch auto-reset.
May 28, 2017 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Galaxy mini fridge stopped working
The thermostat, which is also an ON_OFF switch has failed (@ 99% probability).
No, the little fridge doesn't have a pressure switch to turn the compressor off when freon is low. And no, auto freon is the wrong kind and it wont work in the little fridge. The freon that your little fridge uses is the stuff that all the fuss has been about (with the ozone layer), so it is not sold to appliance owners but only to licensed techs.
If this is helpful I hope you'll take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Koolatron Mini Fridge Compact Refrigerator
My model rs2555sl samsung fridge does not start up after power outage.
Samsung RS2555Sl suddenly stoped working once the power is switched off, If switched on again, only the Ice making sensor light flickers. If both Pwercool and power freeze buttons are pressed for 12 seconds it stars and running normally. Will it automatically start working if I change the Ice making sensor?
Jul 10, 2009 | Samsung RS2578BB Side by Side Refrigerator
Sub-zero 650 vacuum condenser light keeps comming on
Turn the refrigerator off for a minute to reset the vaccum condenser light.
Jan 29, 2008 | Sub-Zero 650 / O Bottom Freezer...
Fridge powers on but does not cool
Try pressing light blub switch whist doors are open as fan will only start when doorsclosed. If compreesor is running but not chilling it is either the compreesor has gone and wont be pumping or it has lost its refigerant. Hope this helps
Aug 23, 2007 | Frigidaire FRT18B4A Top Freezer...
GE GSS25SGMBS Side by Side Refrigerator Logo
533 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
