Question about Watches
I had my battery replaced in my Casio G Shock DW -6800. Since then the beeps and alarms are not working. Is there some sort of reset button he forgot to press?
  • 1 more comment
  • Anonymous May 09, 2008
    I have a Baby-G Cassio, I also replaced the battery and neither the alarm and the hourly chime bip. Please help. I don't think I broke any parts...
  • bom71 Jun 25, 2008
    Hi there!
    Same problem for me on a gw530, still searching...
  • Anonymous Jan 10, 2009
    I had the battery replaced in my Timex Ironman watch and now the alarm,
    beeps, and chime doesn't work.
There are two internal springs that contact the back cover of the watch through an insulator. The alarm nor chime will work if they were not put into their proper locations or were omitted during reassembly.
Posted on Jul 01, 2008
Also make sure that the back cover is on the correct direction. Mine was rotated 180 degrees and that kept the springs from making contact correctly on the back cover.
Posted on Jul 10, 2008
I changed the batt. in my casio g shock dw 5600e and the screen will not light up.
you had to reset it by shorting it, it is located inside your watch. or push all the buttons at the same time. i hope i had been helped you.
Jul 21, 2011 | Casio DW-5600E-1VCT Wrist Watch
My G-Shock doesn't beep every hour, how do i get it to do that?
To make it beep every hour you must first put it on the alarm mode. Then, press the START-STOP button until a little bell shows up at the left. Hope it helps!
Oct 01, 2010 | Casio G-Shock G2600 watch
Does the g-shock illuminator dw-9052 have the option to light up if you flick your wrist fast...instead of pushing the button ?
I don't think your watch has this sort of option. You can find out yourself by finding CASIO watch manual link in my tips.
Feb 02, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
I've changed my battery on my casio g-shock dw 003 but the illuminator no longer works! why?
Did the same with my DW-003 and thought I'd broken the Illuminator (and the alarm didn't work). Next battery change was via a shop and the illuminator worked again (as did the alarm). This was just a battery cahnge, rather than a repair job - One of those things, I guess
Sep 30, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
( ) Button reference
C __D
6) Hourly Chime (SIG):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Press C to return to Timekeeping mode.
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Shut off hourly alarm on g-shock
Okay I have this module so here goes.
Start from your regular timekeeping mode (use lower left buttin to cycle through until you get to the normal time display).
Press 'mode' button (lower left) once. You are now in alarm mode.
Press lower right button to cycle through the alarm modes. The cycle goes: hourly beep on, timed alarm on, both on, neither on. You will see the corresponding icons (a ripple icon for hourly beep and and a bell icon for the alarm) appearing/disappearing in the top left of your display as you cycle through. So if you are in hourly beep mode now you probably need to press that lower right button 3 times to get to 'neither' alarm being on.
Press lower left button to return to normal display.
Hopefully - enjoy the peace!
Jul 05, 2008 | Casio G-Shock G2600 watch
I had the battery in my Casio G Shock DW 6800 replaced. Since then none of the beeps or alarms have worked. Is there a reset button he didn't press?
There is a reset button inside your watch, but I don't think that is the problem. Most likely, there is a spring that makes contact to the watch and the back of your watch case, and it fell out by the person replacing your battery. I would definitely go back to the place where you had the battery installed, and have them take care of the problem buy ordering you a new spring or have them pay for you to send it to Casio.
Apr 24, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Battery replacement for a G-shock.
The reset trick works with other Casio Alarm Chrono digital watches, such as my old Model W-720, as well. After the new lithium coil cell is installed and secured with the spring clip, the watch may show random segments in the LCD display or may simply be blank. Insert a sewing needle, paper clip, or blade of a small jeweler's screwdriver into the hole on the back of the movement stamped "AC" (All Clear) to momentarily connect the gold plated contact at the bottom of the hole to the stainless steel battery clip. The battery clip in most such Casio watches is connected to the "+" terminal of the coin cell. This will reset the CMOS chip and it should start up with the watch displaying 12:00 and the date at 1-1. Then, use the control buttons to set the time and date in the normal fashion.
Mar 24, 2008 | Casio G-Shock GW300CA-1V Wrist Watch
Watches Logo
728 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
