Question about Whirlpool Washing Machines
I am getting a fault code f and h
I am getting a code f and h. I know it has something to do with adding a garment,but what part am I looking for to replace it? Also when ever the washer is on I hear a humming sound.
    President:
  • 1,382 Answers
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Posted on Jul 30, 2010
If you are sewing on a pocket do you need a different machine
Hello, Susan -
From my sewing experience, no.
You do not indicate whether you are re-attaching a pocket to a garment . . . a pocket which has been accidentally ripped, whether you are adding a pocket to an already existing garment, or whether you are constructing a garment from scratch and are sewing a pocket into or onto a garment, following the pattern insructions.
You also do not indicate whether it is a patch pocket, a slash pocket, or a side-seam pocket.
Best wishes.
May 21, 2018 | Sewing Machines
Why won't it start?
The first thing you might check is to see if there is a problem with the door switch. It lets the washer know that the door is closed so water doesn't spill out. Visually check to see if it looks damaged in any way or if something may have gotten jammed or gunk built up. We have a top load whirlpool that got detergent spilled in the door switch area and I had to clean it out. It worked after that.
Oct 30, 2015 | Whirlpool duet Washing Machines
Haier He2 add garment
could you pls write your question in english? did you read what you write? do you understand that? nobody else does...
Sep 10, 2014 | Haier Washing Machines
Stirling XQG65-908E E11 error clothes stuck in machine. Machine is lock and clothes are inside
Buttons:
Pre-Wash = K1
Delay = K2
Temp = K3
Spin Speed = K4
Add Garment = K5
Extra Rinse = K6 1. Press K3, K5, K3, K5 in 30 seconds after power on to enter serve mode(txx selection mode). The display will show t01.
2. Press K1 or K2, it will change from t01 to t12.
3. Press "start/pause" key to enter txx measure mode. Run txx after"start/pause" key. You can go back to txx selection mode if press "start/pause"key.
b. t02:Show fault code test
Press K1, K2 can see all record fault code EXX after enter t02. You can cleanupthe fault code per hold K2 for 3 seconds. If error code 11 does not go away after doing the above 3 times, then theremay be something wrong with the inlet valve, drain pump or PCB.
Jan 16, 2011 | Washing Machines
Pushed pause. Added garment. Washer will not start again.
possible you have not held "start" button down for the required 5 sedonds to restart cycle??
May 16, 2009 | Kenmore Elite 45986 Front Load Washer
Add garment light stays on after garments are added
It appears your timer/main controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Feb 21, 2009 | Kenmore Oasis 27042 Top Load Washer
I have a Whirlpool Duet Sport, brand new. It keeps asking to add a garment when the washer is jam-packed with clothes. Is it a malfunction, does the "add a garment" light ever shut off?
the add a garment light will stay on through most of 1st wash this lets you know that if you forgot something it can still be added ..if not already overloaded..by pressing pause the door will unlock and allow something to be added ..yes it's normal
Aug 10, 2008 | Whirlpool Washing Machines
Won't restart or clear off
try unplugging for a few min adn replug see igf that clears the computer, you didinbt by chance force the door open to addd a garment didi you??? if so the door lock has probalby beed compromised
Apr 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
