Question about LG LMV1630 Convection/Microwave Oven
I don't know if it is the microwave that blowing the circuit, but that is what my brother said. It blows the circuit sometimes when they use it. Model# MS-104yc 1.5KW or maybe the combination of the air conditioner that he was using and the microwave.
    Problem Solver:
  • 9 Answers
Are you referring to tripping the breaker? The microwave runs on 110 volts, and if you are referring to a central HVAC unit, it runs on 220. No way the one could blow the other, unless you are referring to a window unit. If it is tripping the breaker, you could start by replacing the breaker (can buy at Home Depot or Lowes), and if it still continues to trip the breaker, then it is more than likely the capacitor.
Posted on Jul 30, 2010
MAGIC CHEF MODL MCO160UQ KEEPS BLOWING THE FUSE INSIDE THE MICROWAVE
CHECK THE FUSE CORRECT AMPS OTHER WISE BLOWS THE FUSE AND CHECK ANY SHORT CIRCUIT IS THERE
Jan 08, 2014 | Magic Chef 1.6 Cu Ft Over the Range...
Microwave Dead
Having 20 year experience fixing microwaves i know that when the fuse goes that if you can't find a melted wire or overheated components on the circuit board that the high voltage capacitor at the back needs to be replaced. Sometimes you have to replace the magnetron too. You can replace the door switches if you like, microswitches are inexpensive but would only be bad if arced inside so bad that you read over 1 ohm.
Nov 25, 2013 | Microwave Ovens
Blowing breaker microwave intermittent
The microwave only draws a lot of current when cooking and on, you may have either a bad breaker or another item on that same circuit causing this, Fridge?
Dec 21, 2012 | Microwave Ovens
I have a kitchen aid microwave and have had it repaired at a autherized sevice center and it had a blown fuse. Now I have another fuse that has blown. It does it when the door opens and then blows leaving...
When the fuse blows in the microwave oven, it is often caused by a bad door switch. Sometimes food build up will clog it, or becomes defective, the only way to fix it is have it replaced.
Mar 30, 2011 | KitchenAid KCMS145J Microwave Oven
GE Model# jvm1850sm1ss microwave has lost all power. The light bulb was not secured in its mount as it should be. When I took off the bottom panel the light moved, touched other metal and caused a small...
Sorry, when you do not unplug the machine before removing the buulb the wires at the bottom of the bulb twist together and blow up the main circuit board. The fuse will not respond fast enough to save the board, the traces that blow off of the board were never meant to carry that kind of amperage and they blow off before the fuse can respond. ALWAYS unplug a microwave to replace the bulb. I have seen a lot of units damaged that way. Need either a new circuit bosrd, or someone to repair the blown traces on that one and test it. Sometimes it damages other parts on the board and you cant turn the light on or off, sometimes always on. New board time, But $$$$
Oct 18, 2017 | Microwave Ovens
Hi, When my GE jvm1650bb microwave starts, it begins to work and then blows the fuse in the house. Does this every time, the circut is not overloaded. Is their a part that went bad that I can replace?
Try your oven on another circuit in your house. It is curious that your oven doesn't blow its own fuse before the house one. If it doesn't blow the fuse in the "new" circuit, check to see what is really on the kitchen circuit. It might, in fact, be overloaded. Good luck.
Nov 28, 2009 | GE JVM1650 1000 Watts Microwave Oven
Microwave blows fuse when turn on
If it is blowing an internal fuse it could be a lot of things.
-short in the motor
-short in one of the other components
- gunk/dust could be causing a short
If it is your house circuit breaker/fuse then either the microwave draws too much current/amps for the circuit and you should try another circuit or you already have too many things/appliances plugged into the same circuit (not necessarily the same outlet) and need to unplug one or more of them so that the 'fuse' doesn't blow.
Kugellager
Nov 07, 2009 | Sharp R-1460 Microwave Oven
No power braker ok
There is an internal fuse on most microwaves, it will "Blow" if the door interlock switches are not happy, sometimes the fuse just blows, like some circuit breakers do.. get a few extra, replace it and see what happens..if it doesn't blow again, you're most likely ok, if not, there are more causes for the internal fuse to blow, beyond the interlocks, it's not going to be cheap.
Oct 25, 2009 | Maytag Microwave Ovens
Microwave fuse blowing???
You really need to check that circuit for ground and neutral faults before using it again.
Aug 29, 2009 | Panasonic NN-H275 Microwave Oven
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LG LMV1630 Convection/Microwave Oven Logo
118 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
