Question about NEC Lands Phones
Need to know how to cancel the flashing light on the top of my Parracom SV8100 handset
  • 4 Answers
Is it green or red?
Posted on Dec 03, 2010
How do I deregister my cordless Vtech Cs6429 so I can reregister it to work again? After running the battery completely down it's saying to register it but it keeps failing
To deregister all handsets, with all handsets in standby, press and hold the Find Handset button on the base for about 10 seconds (or until the In Use light turns on and flashes). Release the Find Handset button. Then press and release the Find Handset button again while the In Use light is blinking. (You have about 5 seconds.) Wait until the process is complete. You should see the registration message on all handsets.
If the deregistration process fails, you can try resetting the unit from a registered handset. Pick up the registered handset that is on the base. Then press Talk/Flash button and then Off/Cancel buttons. Then try again.
The manual for the additional handset, CS6409, that is available for the CS6429 has the de-registration procedure. That manual is available from the product page: http://www.vtechphones.com/products/product_detail/1604 . Click on the Support & Manuals tab. The direct link to the manual is http://cdn-media.vtechphones.com/media/p/document2/products/%7B9B67F082-6CC0-48CC-B7F2-23C65B10A4F1%7D/CS6409_UM_V3_20141202.pdf .
I hope this helps.
May 03, 2016 | Vtech Lands Phones
How do I get my headset to work on NEC SV8100
to use the headset port you can program a button that toggles between the handset piece and the headset port (under the handset),
assuming that your installer has used standard feature codes, press the following;
? Press Speaker key.
? Dial 751.
? Press an available Function key. (one of your unused 24 buttons)
? Dial 05.
the Function button is now your Headset pickup/release button
Feb 26, 2015 | NEC Lands Phones
My NEC DVL(XD)Z-Y (BK)phone has a red blinking light for reception button. No one knows the mailbox code since the receptionist was replaced. How do I reset code or stop light from fast flashing red?
These instruction are for a Univerge-SV8100
To Delete a Security code, the greeting, messages or recorded name in a personal voicemail box:
1. From any phone with Admin rights (Usually ext 101)
2. Press the message button
3. Enter security code if there is one
4. Dial 72 to access System Admin
5. Press SUBS soft-key (in display)
6. Dial the extension number you want to change
7. Press the available softkey in the display or 7 to delete the security code.
Be careful when you are in the admin part of the programming because you can really mess up the voice mail if you do something wrong. To check what type of phone system you have look for a NEC box in your phone room or server room. The complete PDF is here
http://www.integratelecom.com/resources/Assets/sv8100-admin-inmail-master-11-5-07.pdf
Jan 23, 2015 | NEC Lands Phones
How do I make the green flashing light on the phone go away?
Blinking Light
Two reasons the light on top of your screen might be blinking or on steady.
  • You do not have a voicemail key programmed and the voicemail is alerting you of a new message. Simply dial *8 and check your mailbox.
  • Message waiting has been activated. To cancel:
    • leave handset hung up
    • press call1 key
    • dial 873
    • press speaker key
Blinking light on top of Display NEC Aspire
Nov 13, 2014 | NEC Lands Phones
There is a function key "fwd/dnd" is keep flashing on My Panasonic kx-t7030x phone. How should I cancel for it?thanks!!!
The slow flashing indicates that your phone is currently set for Call Forwarding.
To cancel from this phone, pick up the handset (or use speakerphone), then press this key sequence: [FWD/DND], [0], [#].
The light should turn off, and you should hear a confirmation tone. Once you hear the dial tone again, hang up using the handset or speakerphone button.
Source: page 3-19 (79) of http://www.google.com/url?sa=t&rct=j&q=panasonic%20kx-t7030x&source=web&cd=2&ved=0CFoQFjAB&url=http%3A%2F%2Fpdf.textfiles.com%2Fmanuals%2FTELECOM-F-R%2FPanasonic%2520KX-TA624%2520Users%25203.pdf&ei=ycQCUdf0O5To9gTK_YDQAg&usg=AFQjCNEt0-JdZEhH0WCSSp6Sl7VOmARFbA&bvm=bv.41524429,d.eWU
Nov 04, 2012 | Lands Phones
I was cleaning my phone and I pressed on something and now there is music playing that i can not stop,I don't know how to stop the music,my phone is panasonic KX-T7730
Here are two methods to turn off background music, one of these should work depending on which Panasonic phone system your phone is connected to.
1) With phone idle, press the 1 key on the dial pad (turns off background music when it is on and turns on background music when it is off).
2) With phone idle, press intercom button then dial *751 on the dial pad followed by 0 on the dial pad to turn off background music(confirmation tone will be heard) and end by lifting handset and replacing in cradle. To turn background music on, press intercom button then dial *751 on the dial pad followed by 1 or 2 on the dial pad to select the background music source(confirmation tone will be heard) and end by lifting handset and replacing in cradle.
Feb 05, 2011 | Panasonic KX-T7730 Corded Phone
Red light not flashing on handset
No, that typically is used to notifiy you that you have a voicemail.
It's not an indicator of phone working.
Nov 01, 2009 | Siemens Gigaset 4010s Classic Cordless...
I need to reactivate my uniden cordless phone with remote extra handset. It was on a second phone line in my home, and that phoneline has been cancelled. Now, both units are charged, but and plugged into...
This should get the job done for you!
To re-register DXA14588-2 handsets:
  1. Pick up the handset from the base. Press and hold [find handset] on the base.
  2. While holding [find handset], place the handset in the base. The charge/in use LED on the base begins to flash, indicating the base is registering the handset. Wait for at least five seconds.
  3. Pick up the handset from the base and press [talk/flash]. If the display shows TALK, the handset is registered. If not, place the handset in the base to try again.
  4. Press [end].
  5. Place the next handset in the base and wait for at least five seconds. No need to hold [find handset] this time.
  6. Repeat steps 3 - with any other handsets you have.
Please let me know if you have any further questions.
Good Luck!
Aug 11, 2008 | Lands Phones
Philips SE 435 Handset beeping intermittently
I had this problem, solved it by going to the advanced settings menu and resetting the handset. I guess the handset got out of sync with the base station after I deleted messages... once reset it was fine.
Jan 27, 2008 | Lands Phones
Lands Phones Logo
597 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
