Question about Refrigerators
GE TCS18PADBLBS Freezer
My bottom freezer has a drip inside that freezes at the bottm and I have to clean out every 2 weeks or so. Is my  drain line plugged/ clogged? If so where is it located and the best way to unplug/ unclog it?
Thank you
  • Ben Lee Apr 25, 2008
    Will give it a try!  Thank you
  • Anonymous Feb 01, 2009
    The only two panels that look as if they can be removed are located inside the unit. The bottom panel (floor) of the refrigerator compartment is held on with four screws.
    The top panel (ceiling) of the freezer compartment looks like it might come off.
    Those are the only two panels on my unit that appear as if they can be removed. The back (outside rear) of the unit appears to be sealed and so does the inside of the unit except for the two exceptions noted.
    Genius:
  • 1,073 Answers
If the drain line is frozen or clogged then you have to remove the back freezer panel and with a hair dryer at the bttom of the evaperator coil thaw the ice that is built up in the evaperator pan ouce you have it thawed you can pour water into the evaperator pan and it will run into the drainpan if you pour water into the pan and it does not run into the pan keep thawing
Posted on Apr 24, 2008
I have a Roper Frost Free top freezer model Model@RT16DKXXW06 Serial#EB2423742 Type#16ATR92 Mfg 06/92 the pats 6-8 weeks it has been leaking water on the floor I assume from the defrost cycle. What can I...
yes the drain is in the rear of the freezer ..you will need to remove the covers on the bottom and the back to see the drain..remove all the ice buildup on the bottom ..then use hot water to thaw drain...the reason for the line freezing up is freezer is set to cold freezing leftover water from defrost..let me know good luck/joe/
Aug 27, 2010 | Roper Refrigerators
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
The feeder tube for the ice maker freezes and water leaks inside
First we have to determine if the problem is a faulty water valve. Reason: faulty water valve can continue to supply water even after the IM or door dispenser is finished calling for water causing a drip feed freeze up problem, or water overflow condition in the ice maker (IM). Another common cause is unrelated, but caused by a blocked drain line often resulting in thick ice build up on the bottom of the freezer, water dripping onto the floor, or water dripping into the refrigerator (top freezer mount models only) and freezing near the lights or damper ducts after defrost. Fix for this problem is to remove evap panel and clear freezer drain line with hot water or compressed air. If this is not the case, and water is dripping out of IM supply line, remove IM H20 supply line from IM at back of appliance and see if the water seems to drip out, if so, replace the water valve. If water doesn't drip out at all, replace IM, or IM module depending on the model of refrigerator that you have as contacts in the IM are also responsible for calling for H20 supply. You will have no more problems after this.
Jun 17, 2009 | GE GSS20IEP Side by Side Refrigerator
Water drips from bottom of fridge. It happens
look in the bottom of the inside of the freezer, you probably will see ice buildup.You have to clear the drain which is stopped up at the bottom of the panel that covers the freezer evaporator.Every 8 hours the drain receives water from the auto defrost and needs to go in the drain, if drain is stopped up it freezes and eventually runs out the front
Mar 25, 2009 | Hotpoint HSS25GFP Side by Side...
GE Side by Side, water leak inside freezer door
you will need to [possibly replace the solinoid valves on the backdside of the refrigerator
Jan 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is dripping from freezer into refrigerator and freezeing
your drain line in the freezer compartment is clogged up, you have to clear by taking the freezer bottom panels off and then flushing the drain line out with something like a turkey baster.
Jan 25, 2009 | Refrigerators
Frige has water dripping in from freezer
Hi, Check the door seal.
Ice is often caused by warm, moist air getting into the freezer and condensating, then freezing.
Jun 25, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Refrigerator-Freezer top
install a defrost drain tube heater call sears for a part number have the model handy befor calling
Apr 21, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
Refrigerators Logo
670 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
