Question about Frigidaire Electric Dryer
The dryer wont stay going the e68 keeps comeing on
    President:
  • 2,559 Answers
The error is related to a button stuck code but means that the control board is bad and needs replacing.
Posted on Jul 30, 2010
Frigidaire affinity LEQ6000ES2 error code e68...dryer will not start
Good Afternoon David,
I understand that your Frigidaire Affinity dryer, model# LEQ6000ES2, is showing you an error code of E68 and will not start. I also see that you have changed the thermal limiter. Looking at what the E68 error code means, a key or button stuck, there could be something else causing the code to come up. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance, determine what is causing the E68, and repair your dryer. Hope this is helpful.
-Best Regards-
WP
Jul 04, 2014 | Frigidaire Dryers
The dryer keeps shutting down the code E68 flashes on the control board dryer won't shut off, have to turn the breaker off
E68 is a stuck button on the control.
Suggestion:
Take a very hot damp wash cloth and go over the control panel to loosen up the sticky button.
If you are storing detergents on top of machine remove them to prevent sticky buttons.
Service manual download: See page 54
Did this help?
Please rate the answer.
Thanks for using FixYa
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 28, 2011 | Dryers
Have a Frigidaire Gallery Series front loading dryer and it keeps giving me an error(?) code, E68. When I start the dryer, it runs for a couple of minutes and then It starts beeping and flashing this code...
Sorry to read about your problem. this should be your E68 problem
You have a defective button on the control board.
The best thing to do is go into the diagnostic mode.
Turn the dial to Normal. Press and hold the Select and Pause/Cancel keys for 6 seconds, or until the Drying/Cool Down/Press Saver/Clean Lint Filter lights come on.
Then press the Start and Pause/Cancel Buttons 4 seconds. This puts you into the diagnostic mode to check the keys. Now, turn the dial 4 O'clock position, or 75. This will allow you to check all your buttons. As you press each key, it will light all the lights above it. When you press a key and it does nothing or the lights above any certain key stays on without pushing it, this button is stuck. If you can't clear it, you probably have to replace the control board.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Dec 21, 2010 | Frigidaire Dryers
My dryer when to begin to work stop and show E68 the dryer is gallery series thanks for help me
Dec 21, 2010 | Dryers
Light keeps coming on flashing E68
this is a problem with the ground to the heater,and or a problem with a shorted fuse check the wiring to the heater
Jun 09, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer keeps stopping error code e68
E68 error refers to "Current leakage to ground on heater or fuse opened".Problem with the fuse.Try getting it replaced.This can be done by any local repairman.Need not be a technician from Frigidaire,as they charge a lot for servicing. Good luck with the machine.Please do post results and comments.
Apr 12, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My Frigidaire Electric Dryer keeps giving an error code
If your dryer is the same or similar to mine (Model AEQ6000ES2) then error E68 is a stuck key on the keypad. This may be mechanically stuck or the membrane contacts. The simple solution is to replace the keypad.
I found this information by searching for "Frigidaire Model AEQ6000ES2"
Mar 23, 2009 | Frigidaire Electric Dryer
Hi, I am getting an error E68 on my dryer
Hi have you tried putting less into the machine as this could be a simple over weight problem
Oct 27, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire  Electric Dryer Logo
71 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
