Question about Frigidaire ATF6000ES Front Load Washer
I have a washer model number LTF7000ES front load washer Avanti 2006 it now reads error and will not work at all?
jsrock516
  • 5911 Answers
SOURCE: F20 Error Message
"F20" is a water inlet problem. This indicates you have insufficient water supply for the washer. Whirlpool is the manufacturer of your washer and they recommend that you unplug the washer and check the following:
1. Check water faucets to ensure they are completely turned on.
2. Check the inlet hose screens where they connect to the washer. The screens can clog with sediment over time and require cleaning. This can be a problem if you live in an area with well water and/or hard water.
3. Ensure the inlet hoses are in good shape and are not kinked.
If you check all the common sense items first and the problem still persists, you need to check the water inlet valve. To access, you will need to remove the top panel of the washer by removing the three screws that hold it in place. Once the screws are removed, the panel slides back, then off. The water inlet valve is located in the left-rear of the washer just prior to the dispenser. Double the electrical connectors to make sure they are not corroded and double check the hoses that run from the inlet valve to ensure they are not kinked. A resistance check of the water inlet solenoids (with the connectors removed) should read about 800 ohms. If the solenoid readings are abnormal, replace the valve.
Please post back if you have questions or require further assistance. I hope you find this information helpful.
Posted on Jun 12, 2008
jyackle5
  • 8197 Answers
SOURCE: error code f24
F24 indicates a water temperature sensor error. If during the wash cycle in the water-heating step, the water temperature sensor (NTC) value is out of range the F24 error code will display.
Possible causes:
  • Too cold of water or hot water is turned off
  • Temperature sensor failure or loose connection
  • Control board failure
Posted on Dec 18, 2008
SOURCE: Avanti W852 Parts??
It's going to be hard finding parts for this machine because I have one as well. You can search the internet or call the company. The last time I had problems with my machine the company told me they stop making parts for this particular brand. Don't give up looking for parts, maybe someone else sells the parts for this washer. Good Luck!
Posted on Mar 11, 2009
SOURCE: Frigidaire Front Load Washer won't Spin
i fixed mine about 5 times and its always some thing diffrent.
try buyng the inexpencive parts first and leave for last the electronic control panel.
it could be that your washing a smaller amount than the recomended.
Take it to a profesional. dont do like me a DIY guy. Some times i need to take pictures when taking the monster appart and then because they are somany screws missing duct tape, rope or hangerwire becomes usefull.
All mechanics are wise guys you and me are thevictims.
Posted on Dec 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: model: wfw9500tw01 f35 error
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
How to fix error2 on my avanti w892f washer?
manufactor manual first if doesn't help then google it on appliance parts site
May 26, 2014 | Avanti W892F Front Load Washer
Avanti very noisy while spinning
what is your model number is then we can get started then okay
Oct 01, 2012 | Avanti Top Load Washer W797
Avanti w1092f front load washer leaking water from the botton
Look under and around the door and drum seals for debris. Had a coin in the seal once, took it out leak stopped.
Nov 27, 2011 | Avanti W1092F Front Load Washer
I need to replace the boot seal on my Avanti front loading washing machine W1092F but the machine has been discontinued. I've called Sears, Home Depot, etc and no one has this part. Help!
FixYa is sorry but this Forum does not supply parts, part numbers, prices or other details direct; it's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web. Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained on many makes and models, probably over many years ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make model number) washer spares' and you may be presented with a number of sources from which you can order.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jul 08, 2011 | Avanti Washing Machines
Replace chuck absorber
why would you want to absorb chuck anyway shirley says hes a good guy lol
Jul 28, 2010 | Avanti W1092F Front Load Washer
I HAVE A ERROR CODE READS F-24 WHATS THEN PROBLEM
Whats Brand and Model number? need that to know whats we dealing with.
Nov 06, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Affinity LTF7000ES door not staying locked
unplug the washer and wait 5 minutes before plugging it in again!
this resets the system. If this does not work then you may have a faulty door lock, latch, or switch!
An need hands on service on location
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 31, 2008 | Frigidaire Affinity ATF7000E Front Load...
Error E7
Please update latest bios in your machine.
Sep 16, 2007 | Avanti W1092F Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
