Question about Digidesign Mbox 2 Pro FireWire Audio/MIDI Interface Sound Card
Im not abl to record my vocals,and i also get a staticky sound when i arm a track for recording.
    Master:
  • 515 Answers
Did you check whether the microphone is working OK with a tight and clean connection to your device and without a close source of magnetic field? What is the setting of your audio device on your machine? Are you in the central of the microphone's sensitive area? Other sound device connecting to your sound card? Did you try to update the driver of your sound card or try a new card?
Posted on Jul 30, 2010
I have a standard DP 02 (non cf) and I want to add vocal tracks to a previously recorded song (tracks 1 and 2) and I don't get any sound from my mic. The mic/line/guitar switch is set to mic/line but the...
you have to make sure the song tracks(1 &2 ) are not armed. then you can assign your vocal to any of the other tracks. after you do this , make sure you arm the track. you should be able to hear your mike.
Apr 09, 2011 | Tascam Dp-02cf Digital 8-track Recorder
I am trying to record in multi track mode-want to know how to record for example vocals on track one then without erasing the vocals add for example harmony or guitar so i get two things on one track. At...
How multitrack recording works is assigning each recording to a different track. A way around this is to record the vocals to track one, then your harmony to track two. Save that as a single recording, or mixdown, then open that saved mixdown to track one. You may need to be connected to a computer to do this.
I use the same technique when using Cool Edit Pro (outdated, yes, but I've been using it for 4 years, and I know most of the ins and outs), especially on the guitar tracks, where for studio sound, you've gotta use 4 total tracks. Putting two tracks together frees up your processor, and uses less in the way of effects, as well.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
Feb 07, 2011 | Samson Technology Zoom H4n Handy Recorder
Good morning I have Cubase SX version 1.01. lately when I record vocals to a track. Im noticing that the Vocals are not in sync with the music. one is playing slower than the other track.. the slower is...
I don't 100% understand why Cubase does this. I'm assuming it's a memory (RAM) problem. If you record loud and clear anough you can just drag the tracks to where they're meant to be afterwards because you can see where they go relative to the other tracks
Aug 20, 2010 | Steinberg Cubase SX3
Im gettin only one side when i record a vocal wit mixcraft 3
Make sure your recording onto a Mono track in your software, don't choose stereo when creating the track.
Feb 20, 2010 | Samson C01U USB Condenser Microphone...
Recording vocals while the music tack is playing simultaniously
it's not supported on that or any earlier sony software that I know of. have you tried running the program twice (simultaniously) and playing on one while recording on the other then mixing the tracks together after??
Apr 26, 2009 | Sony Sound Forge Audio Studio 9
Tascam DP-02cf
You've got two inputs on the DP-02 so you can record two sources at once.
Depending on how you want the electric guitar recorded (mic the amp, or direct line in) you can in the first case plug your guitar mic into one of the mic inputs on DP02 and plug your vocal mic into the other mic input. You also have the option of plugging the guitar directly into the DP02 (using the hi-z input - I believe it is labelled 'guitar' or something on the DP02. I any event I believe it's the one on the left). This way you only need one mic for use recording the vocal part.
To avoid any 'bleed' between channels you can use the headphones while recording this way and you'll avoid having the unamplified guitar sound coming through over the vocal mic.
Once you have the mics or guitar and mic plugged into two inputs, you need to assign the inputs to a channel (track) to record on. You do this by pressing the select button for the input and then pressing the select button for the track where you want to record the input. Do this for both inputs so that they are recording on different tracks. Then arm the tracks for recording by pressing the record button for each track and the lighted buttons will flash above each armed track. Then just press play and record and you'll be recording. You can go back and redo it as many times as you like and record over what is there, or preserve a take and assign a new track (or tracks) for another take. You've got 8 to play with.
Hope this helps.
bd.
Sep 01, 2008 | Tascam 2488 Portastudio Multitrack...
Vocal effects on Tascam 2488 MK 2 portable studio
Hi again,
The easiest way to record using an external Lexicon effects unit (without an external mixer) is to connect your mic onto one of the 2488's inputs and assign that input to a channel strip (track). You should have the 2488 sends (output) going to the Lexicon's inputs. Then connect the Lexicon outputs back into another set of inputs on your 2488 and assign those inputs to two empty channel strips (tracks).
Then you will have to take that channel that has your mic input assigned to it and press send and set the levels there to send the signal out the sends (to the Lexicon).
Now you have a channel strip assigned to the mic input which contains your dry signal, and you have the two inputs returning from the Lexicon which contains your wet or effected signal.
You then have some options. You can control the amount of effected signal you hear while recording by adjusting the faders of the two wet tracks and you can either record the dry signal or the wet signal (or both) onto separate tracks.
Typically when recording the singer will want to hear an effect (say reverb) on his voice, but the engineer wants to record only the dry track at recording time (because effects can always be added later, but they can't be taken out). To accomplish this you would use the setup above, but only arm the mic input track for recording. In this way the singer hears the reverb, but only the dry vocals get recorded and the engineer can add reverb to that track again later as desired (and mix it back with the dry vocal etc).
On the other hand if you want to record only the effected signal you would simply arm the two channels to which the inputs coming back from your Lexicon are assigned for recording. This will get you a recording of the effected signal only.
Hope this helps you do what you are trying to do.
Cheers.
bd.
Aug 30, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam Us144 and Sonar3 problem!!!!
Try this experiment:  Record a click track on track #1.  Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks!  You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
Apr 06, 2008 | Tascam US-144 Sound Card
Delayed vocal
If you're recording to an audio program on your computer (e.g., Cubase), there typically is a slight delay in the tracks you record with the first one (such as a slight delay in the vocal when layering over the guitar track). ou can change the delay in the "Preferences" for the audio card in your computer or you can remove the delay manually.. I do the latter. I record using the Audacity 1.3.3. program on a Mac G4. I find that get a 0.3 second delay in tracks layered onto the first track. So, after I record a track, I cut the first 0.3 seconds froom the beginning of the track (I give myself at least 10 seconds of "dead air" at the start. and keep playing the tracks until they're synchronized. Takes a good ear, but really is the best way to synchronize the tracks.
Nov 10, 2007 | Alesis Multimix 8 USB 8-Channel Mixer...
Digidesign Mbox 2 Pro FireWire Audio/MIDI Interface Sound Card Logo
Top Digidesign Computers & Internet Experts
Marvin
Marvin
ali_zulfikar
ali_zulfikar
Zhenya Ogorodnikov
Are you a Digidesign Computer and Internet Expert? Answer questions, earn points and help others
