Question about Sport & Outdoor - Others
My 1977 Evinrude 140 HP outboard engine looses power when it hits @4,200 rpm's and goes down to 3,500 then back up to 4,200 and then back down to 3,000 or about there. This would continue if I didn't slow down to 3,000 on my own. It runs fine at @ 3,000 when I slow it down. I have changed all the fuel lines from the fuel tank to the carbs, removed, cleaned out the fuel tank, put new gas and added a can of SeaFoam. I replaced the water seperator filter and cleaned the fuel filter. I feel the fuel pump is operating OK. Any ideas about what could be causing my problem? Could it be a bad power pack or stator? Help!!
  • Tommy Keller Jul 30, 2010
    That sounds a little drastic, when others are telling me it could be a bad fuel pump, stator or power pack. I will run it by my mechanic anyway. Any other suggestions or opinions on my problem?
  • 360 Answers
Hi, this is obviously a stator problem since you have cleaned the fuel filter..
Take care
Posted on Jul 30, 2010
    Mr. Smith-alone,
    I can understand how you can feel this could be a stator problem, but do you think it could be a power pack problem and if not, why not and why do you feel it is a stator problem instead of a power pack problem.
    Smith-alone,
    Did you receive my last communication? I wrote that I can understand why you might think my problen is stator related, but do you think it could be a power pack problem and if not, why not, and why do you think it is a stator problem?
    Brigadier General:
  • 3,917 Answers
Hi
The motor needs to turn 6000 to stay good - any less at full throttle, she's lugging at all throttle settings. Lugging promotes choking. Choked-up cylinders lead to sticky rings, lost compression, and eventually, catastrophic failure. If you're not getting close, consider taking a look at your setup -- whether you have room to raise the motor on the transom, or drop an inch or two prop pitch. A good prop guy can help you look at the machine thoroughly.
Please check the bellow link to go through the discussions there….
http://www.marineengine.com/boat-forum/showthread.php?p=224461
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Getting water in carbs not from fuel tank it happens when I put it in forward it's a 140 evinrude looper
Your engine should be sealed enough to prevent this..unless you have the engine mounted so low it idles under water...???.. There is a seal that goes between the lower cowl pieces and the engine, a seal around the engine cover(cowl)...and seals that surround all wires and cables.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Jul 14, 2017 | Boating
Why does my 1991 60 hp Evinrude outboard alarm sound and motor sputter occasionally?
when the alarm goes off is the engine getting hot, try running it in gear under load while tied up and with the engine cover off see how hot it gets and if the water i circulating all the time , might have cooling problem !
Aug 04, 2014 | Seloc Johnson Evinrude Outboards 1973 to...
My 1977 85 hp Johnson motor will trim up but not down. I traced the wires from the trim switch to the solenoid and all are hot. I replaced the solenoid but it still will not work. I can cross out t
2 solinoides , one for up and one for down !!!! test trim switch then try swopping up solinoide to the down and problem could be solved !? check wires !
Jul 31, 2014 | Sierra Outboard Starter for...
Broak timing chane
you drove car , with it screaming like that. really?
big error that?
if engine (type not stated) is interference engine , they grenade.
that means you bend over the head valves, at least.
post engine full spec
quote: which engine, cant help not knowing the ENGINE !
generation 5 is:
  • 1988-1995: 1.8 L (1,812 cc) 2Y-U I4, 58 kW (79 PS; 78 hp) at 5,000rpm 140 N·m (100 lb·ft) at 3,200rpm
2Y I4, 61 kW (83 PS; 82 hp) at 4,800rpm 140 N·m (100 lb·ft) at 2,800rpm (export markets)[11]
  • 1989-1995: 2.4 L (2,366 cc) 22R-E SOHC EFI I4, 84 kW (114 PS; 113 hp) at 4,600 rpm and 192 N·m (142 lb·ft) at 3,400 rpm
  • 1989-1995: 3.0 L (2,958 cc) 3VZ-E V6, 112 kW (152 PS; 150 hp) at 4,800 rpm
  • 1989-1997: 2.4 L (2,446 cc) 2L diesel I4, 61 kW (83 PS; 82 hp) at 4,200 rpm and 165 N·m (122 lb·ft) at 2,400 rpm[12]
  • 2.8 L (2,779 cc) 3L diesel I4, 67 kW (91 PS; 90 hp) at 4,000 rpm and 188 N·m (139 lb·ft) at 2,400 rpm
Jan 20, 2014 | 1991 Toyota Pickup
What is the problem fault code p1601
Toyota Hilux?
wow no year
, you do make it so hard to answer but is 96+
P1 means factory code, so autozones may fail.
5th generation 1996+
Engines:
my wild guess is the 2.4L due to OBD2 status. only...you need to say..
my motto:
NO YEAR
NO MODEL
No engine size. (or transmission type A/T or M/T?, if that is in question)
NO HELP (or your joy)
No country , too , is a royal pain , all cars are different by country (laws)
Jan 09, 2014 | Toyota Hilux Cars & Trucks
No power at wide open throttle
be looking at emissions controls for leaking hoses open ports etc.. is timing good? out just a bit? look at the advance system under the rotor in the distributor..does this work freely? if not..spray with lubrican just enough to free it up..
Dec 15, 2013 | 1989 Toyota Pickup SR5
Does a 1977 Evinrude 70 horsepower engine hav a charging system?
The 70s Johnson or Evinrude outboards of similar sizes did not have any charging system. I had an old Johnson 50HP (key injection) mounted on an 18Ft Zodiac and I needed to remove and recharge the battery once every couple of weeks. Keep the battery dry and the contacts well greased.
Apr 25, 2011 | Clymer EvinrudeJohnson Outboard Shop...
I am looking for a diagram of a 1977 evinrude 85hp engine - so i can work out how to remove the tilt rams from the engine to check if they are working correctly
Hi there, You can find all parts diagrams for Evinrude engines here: http://epc.brp.com Just ignore the email entry part and go straight to the database. They are listed by Brand, then year, then HP size. I checked for you and it has the 1977 85HP models listed there. Then just find the right subsection of the outboard and it will bring up exploded diagrams for your viewing!
Jun 15, 2009 | Boating
Sport & Outdoor - Others Logo
152 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
