El sistema de calefaccion de la skoda felicia combi se daƱo como soltarlo del carro para poder reparar el radiador dse la calefaccion?
  • 6 Answers
SOURCE: De Longhi E4 error
Basuda! Sorry! Cheaper to get another one than to fix!
Posted on Nov 14, 2007
Illeagle
  • 525 Answers
SOURCE: aire split tipo pared no tengo el modelo en este momento
No Habla
Posted on Jun 02, 2008
  • 3 Answers
SOURCE: modelo fujitsu asy14rse-w que cae agua por el split
la linia de donde la agua se debe salir a de estar tapada. quitale el cuvertor i mira como esta la line de pvc adentro
Posted on Sep 12, 2008
nblady
  • 206 Answers
SOURCE: Quitar Password de Bios de Pc Dell Optiplex GX100,
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
Posted on Feb 24, 2010
SOURCE: No me Funciona El compresor
Tengo una cosola Trans de consola de 240000 BTU cuando me la istalaron no funcionaba movieron el abanico y funciono.. aparentamente es el abanico. Actualmente esta funcionando. Que debo hacer.
Posted on Oct 31, 2010
Como Reparo un Plasma Panasonic Viera TH-42PD60X no enciende ni el led de Standby
AMIGO YO TE VENDO LA TARJETA DE PODER PARA QUE NO SUFRAS MAS CON ESE APARATO , O TE COMPRO LA PANTALLA PARA EL MIO QUE ESTA QUEBRADA ,
Compro pantalla para PLASMA PANASONIC TH-42PD60X la mia esta rota, o vendo mi plasma para repuestos , tambien vendo una base para este plasma ya que tengo 2 unidades . gracias interesados escribirme a jaimolb@hotmail.com informes tel 0057 3207250204 colombia
Jan 21, 2012 | Cars & Trucks
Que significa chekch
Una señal luminosa "check engine" le está diciendo que la computadora que controla el motor de su auto ha detectado un problema que causa que el vehículo produzca excesivas emisiones. En ocasiones la luz será acompañada por una notoria serie de problemas en la respuesta del carro, como pérdida de poder del motor o dificultades para encender, pero otras veces el vehículo puede operar "normalmente".
Las fallas comunes que pueden causar que se encienda el "check engine" incluyen:
- Falla en componentes del motor como los sensores de oxígeno, temperatura del refrigerante, presión interna (MAP) o de flujo de aire.
- Motor que no enciende debido a fallas en las bujías, cables, componentes del encendido, inyectores de combustible u otras partes del sistema de combustible.
-Fallas en el sistema de control de emisiones como mangueras de vacío rotas o sueltas, el tapón del tanque flojo o desaparecido, o una defectuosa válvula de recirculación de combustible (EGR).
Si se enciende y luego se apaga tras unos instantes, puede ser un problema momentáneo en el sistema. La luz se apaga cuando el problema se detiene, pero la computadora debe haber guardado un código de diagnóstico de problema en su memoria. Si la luz no regresa, puede ignorarla. Sin embargo, si la luz se enciende y apaga intermitentemente, lleve el vehículo para que lo revisen y puedan escanear el computador para determinar que codigos de falla hay almacenados en el.
Suerte (recuerca calificar y comentar esta respuesta).
May 14, 2011 | 2004 Chevrolet Impala
Tengo problemas con un Multifuncional HP Laserjet M1522, por alguna razon empezo marcar ERROR 5 Y NO PUDO INICIALIZARSE el SCANNER , Funciona como impresora pero no como copiadora o Scaner, , parpadea la...
59c05df4-3e41-4402-8674-16fa865682b6.jpg1e27574a-853d-43f0-83e9-639f0eb8015f.jpg6f9cb0d0-efc0-4725-b485-113c15667e78.jpg639e37f6-dbca-4b87-baf4-9919d68a26d4.jpgf319f64c-35bb-4a4d-b11b-3637a94260fd.jpgdf4c7415-80c2-478b-9083-7ef214ae9172.jpg027f0e9b-f662-4bc9-916c-d62c423d9e73.jpga1eea8bc-2311-4ede-b6b1-2b036b38dc64.jpg7ada6481-ced7-4dab-b710-09760d6b9498.jpg04f42b95-4eec-4796-8556-1ef7ab6cddbe.jpgHola amigos, tambien tengo este problema con una impresora, reinstale el firmware y no funciono, lo que note es que el motor estaba quemado, lo desarme y lo rebobine, compre el alambre me parece que fue calibre 33, aprox 25 mts, 260 vueltas con una resistencia de 10ohms por bobina. bueno despues de esto lo monte y funciono un poco mejor. pero al parecer es la tajeta logica pregunte a un proveedor de hp y su valor es de aprox 3000 pesos mx, lo que hice es hacerle un agujero al escaner.
Detalles.
viendo de frente el escaner del lado izquierdo le hice un agujero de 3mm. y le puse un cincho largo(pueden usar algun desarmador, el cincho se lo puse doble para que no se doblara, el cincho debe entrar con facilidad pero no muy olgado para que no se doble, al introducirlo no es necesario sacarlo ya que el carro lo sacar, es por eso que no debe quedar apretado). esto me permite mover el carro del escaner a lo posicion "0". posicion de partida y hubicacion de la banda indicadora(Empujarlo unos 3 cm aprox, despues solo se calibra).
La finalidad de esto es de manera manual regresar el carro, se apaga y se vuelve a encender y listo. funciona nuevamente.
Este error me aparece despues de haber utilizado el ADF, el cual el carro se mueve al lado izquierdo para poder escanear automaticamente los documentos. posteriormente no puede regresar.
Aqui pues es donde le podemos ayudar a regresar a su posicion original.
Espero que les ayude en algo.
Aug 29, 2010 | HP LaserJet M1522nf Multifunction Printer...
Necesito saber la pasword de la bios ayuda
Hola,
Esta no es mi lengua así que por favor desnuda conmigo.
1. En la placa hay una batería de reloj pequeño. Quitar la batería
junto con el cable de alimentación de la fuente de alimentación. Mantenga presionado el poder
botón para descargar completamente el sistema. Espere 2-3 minutos y luego vuelva a instalar el
batería y conectar el sistema. Su restauración se ha completado
2. Algunas placas base tienen un jumper de 3 pines de la batería. Digamos que
el puente está en las patillas 2 y 3. Quitar el puente mientras la máquina está apagada
y colóquelo en los pines 1 y 2. Encienda la máquina por un minuto. (Nota:
El sistema no POST). Apagar la máquina y colocar el puente nuevo
a los pines 2 y 3. Su restauración se ha completado
Este es un gran paso para solucionar problemas para los de usted teniendo problemas POST
o si no se POSTeando en absoluto. Como medidas de solución de problemas, esto no
siempre funciona, pero por lo general en función del problema.
Por favor, hágamelo saber si usted tiene alguna duda o inquietud.
Gracias
May 08, 2010 | HP Compaq 6735s Notebook
Me prende un bonbillito en el tablero que es un carro con una llave adentro y el carro no prende
Es el sistema de seguridad ANTI THEFT SYSTEM, que desactiva la comunicacion con el COMPUTADOR para accesos no autorizados. Es probable que hayas desconectado la bateria recientemente o usado el PANICO de la alarma.
Sugiero revisar el manual de usuario del vehiculo, en el esta la forma de desactivarlo.
Suerte.
Mar 17, 2010 | 2006 Toyota Land Cruiser
Problemapara prender el carro
Adivina, adivinanza, y mientras lo solucionamos, nos rascamos la panza.
Sugiero revisar el arrancador y compoenntes de encendido, asi como el sistema de envio de combustible, presion de bomba, asi como componentes que mantienen el minimo (ralenti) del vehiculo. Descartado eso, verfificar sensores IAC y oxigeno.
Visita autozone.com (registro gratuito), seleccionas el año, marca modelo y motor de tu vehiculo para poder acceder a guias y manuales de reparacion.
Espero haberte ayudado (recuerda valorar esta ayuda).
Oct 20, 2009 | 1994 Acura Legend
Unidad para disco duro SATA serie hitachi modelo
Sin importar el Sistema Operativo, este problema está relacionado con si el tablero principal de su sistema tiene o no los conectores necesarios para su unidad de disco SATA. La fuente de energía (en sistemas modernos) trae al menos dos cables de poder de este tipo, y dos más para IDE. Los cables SATA para la transmisión de los datos se compran por separado.
Si su sistema es de varios años de edad, es muy probable que no tenga ni los conectores SATA salientes de la fuente de poder para conectarlos a su nueva unidad, ni aquellos que se requieren para conectar el disco al tablero.
Una manera de hacer que funcione un disco SATA en un sistema que carece de sus conectores SATA es algo o muy fácil, o algo caro, pero ambos factibles.
1) Fácil: Compre un adaptador de SATA a IDE y conecte la nueva unidad de disco al adaptador, y luego éste al terminal existente IDE en el tablero. El único problema aparente es que no va a aprovechar de la velocidad mejorada del disco SATA.
2) Es posible que alguien venda un controlador SATA para estos sistemas, aunque personalmente no he visto un solo anuncio en las revistas que cubren la industria. Es muy probable entonces que esta opción no exista.
3) Una mejor solución es reemplazar el tablero por uno más moderno, aunque se corre el riesgo de que se necesite cambiar también otros componentes como la memoria, etc. lo cual no podría ser económico, pero se quedará como un equipo del último grito, dependiendo de cuánto esté dispuesto a gastar. Eso sí, si llega el momento que los componentes separados le cuestan más que un sistema nuevo, entonces esta última es su mejor opción.
Jul 12, 2009 | Computers & Internet
Problemade no prende no jala gasolina
en el baul de carro por el area del shockabsorber del lado pasajero hay un cable que le da correinte and la bomba de gasolina chq ese cable que este bien puesto ....si no es eso quisas la bomba de gasolina se daño para cambiarla tienes que levantar el asiento de atras ..
Oct 08, 2008 | 1991 Honda Accord
Problemas con el sistema de enfriamiento
Hola, mi recomendacion es antes que nada reemplazar el termostato para iniciar bajo control. el thermostat de mas Baja temp para zonas calidas. Despues de esto asegurar el termostato funciona y abre al llegar a los 90 grados o mitas de ahuja debe de verse circulacion en deposito de agua. En estos vehiculos es importante purgar el sistema por medio de un valvula /tubo loicalizada frente a motor. se afloja y sale aire. cerrar cuando ya no salga aire/vapor. Despues de esto se podran tomar mejores conclusions. Recomendacion nunca quitar termostato permanentemente ya que es necesario en tiempo de invierno/frio para calendar vehuiculo adecuadamente. FIN
Sep 26, 2017 | 1989 Pontiac Sunbird
Heating & Cooling Logo
70 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
