Question about Kitchen Ranges
HI, I have a Daikin Inverter split system airconditioner model No, FTXD60JVEA and the other night had it on heating mode on 21 Deg C for a while and turned it up to 24 deg and short time after it suddenly shutdown and flashed a inside unit green light that was code u4- incorrect interunit wiring(interunit). I checked all wire connectors inside/outside units unconnected/reconnected to make shaw good contact, the Led lights on outside unit dont work, checked all wire connections/plugs on all PCB boards, disconnected fan, still no good, fan turns around, not siezed. Fuses on PCB boards arent blown, PCB boards are dry/clean, no insect infestation, cant see any black puffs anywhere on boards if something has blown.
    Brigadier General:
  • 3,917 Answers
Hi
Most probably its an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
With these units it would probably be outdoor PCB fault. On the outdoor PCB there are 2 communication channels for both of the indoors. You can check on those terminals if they supply similar voltage to both indoors. If the signals are the same, it would be the indoor PCB, if not, outdoor PCB.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 30, 2010
Finding a manual for a Daikin ducted airconditioner model no. Rzp71dv1
Try Googling (daikin)(Rzp71dv1)(manual) without parens.
Jan 23, 2018 | Heating & Cooling
F8 error split air conditioner
F8 error isn't registered with my Daikin Airconditioner, though E7 showed up as a 'motor over-current' warning.
It might help if you find out the NAME and the MODEL NUMBER for your air conditioner.
Once you know this, then you can search for it like this...
Name - Model - error codes
E.g. 'Daikin Ft18k error codes'
Oct 06, 2014 | Computers & Internet
Error code e4 on daikin split system ducted air conditioner - what does it mean?
This is stating that there has been a low pressure error on the system.
This could have been caused by a blockage in the pipe work or a possible shortage of refrigerant. It could also be due to a fault with the low pressure sensor/switch.
Jan 31, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Hi, I have a Daikin Model FTXS35D with RXS 35D 3VNB outdoor unit. Until this year it was excellent, now does not cool as before. Have cleaned filters etc. Could it be a sensor problem. When I...
Your unit should cool 15 to 20 degrees. 75 return air temp should be below 60 degree supply air temp. If you are not in this range you likely have a refrigerant problem.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 14, 2017 | Cfm Daikin R410a Split System Air...
Lost manual for model R410A Daikin invertor. Where can i find a new one?
google daikin (model number) manual . what are you trying to do or just want a manual ?they really dont tell you much in them.
Nov 03, 2010 | Cfm Daikin R410a Split System Air...
How to insert oil in outdoor of split type airconditioner
You shouldn't have to add oil. The little bit that leaks out with refrigerant isn't significant. I would be more concerned about the leak itself. Has it been located and fixed. If not it will no doubt leak out again. Also do you know how much refrigerant to put in the system? Have you vacuumed the air/moisture from the system etc. Is the system totally flat or is there still some refrigerant in it? Let me know so I can advise you correctly.
Feb 23, 2009 | Cfm Daikin R410a Split System Air...
Fan coil unit won't cool or heat in room1 while room2 runs well
could be undercharged, or overcharged, or wires weren't put back on valves in unit.
Feb 16, 2009 | Cfm Daikin R410a Split System Air...
Kitchen Ranges Logo
61 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
