Question about Kenmore 57029 Side by Side Refrigerator
Evaporator fan not working!!
I have a Kenmore refrigerator, mod 253.51392104. The evaporator fan is not working. I changed the motor but still not working. The power at the terminals is only 12 volts.
  • pepoperdomo Jul 30, 2010
    THE FAN ON THIS MODEL IS 115 VOLTS.
    Guru:
  • 1,524 Answers
The fan on this model is only 12 volts. Make sure that is what your replacement is rated.
Posted on Jul 30, 2010
  • Robert Moller
    Robert Moller Jul 30, 2010
    My bad. Forgot my glasses. Senior moment
  • Robert Moller
    Possible bad board
Iturned off a Kenmore elite side by side refrigerator for couple days,and rellaced evaporator fan motor.How long takes the fan motor starting work?
If you replaced the fan motor with a new one, it should start working as soon as you plug it in. Are the blades bent and catching on something? The fan should run with the compressor. Did you wire it properly?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dan_77d17b8918f54455
Dec 27, 2014 | Kenmore Refrigerators
I have a kenmore model # 59675522400 The fridge is
Hi and welcome to FixYa, I am Kelly. You have most likely found the problem being the evaporator fan is turning slowly. Most of the time if there is a voltage problem with and evaporator fan they just do not turn at all. I suspect that the fan bearings are dry and the armature is not turing full speed.
Sometimes you can lubricate the motor with a parrifin based oil and revive them. Most of the time on the white motors lubrication does not work as you can only lubricate one of 2 bearings due to the motor design.
Your evaporator fan motor is here: Detailed view
http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-elite-Parts/Refrigerator-Parts/12002744/0046/464/Model-59675522400/0583/0161000?keySuffixId=NA&productTypeId=0161000&searchModelNumber=59675522400&subCompDesc=Evaporator%20area%20&%20rollers&brandDesc=KENMORE%20ELITE&modelDesc=KENMORE-REFRIGERATOR&blt=11
Component location view: (item 18)
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675522400/0583/0161000/M0705003/00010?blt=06&prst=&shdMod=
All other parts:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-elite-Parts/Refrigerator-Parts/Model-59675522400/0583/0161000?pathTaken=
The Evvaporator fan motor voltage should be 120 VAC across the 2 fan motor wires.
Thanks for choosing FixYa,
Kelly
Nov 19, 2010 | Kenmore Refrigerators
Kenmore 61042 fan motor replacement
hi! you mean there is ice on the part of evaporator or some in other part? its normally cool your refrigerator inside part.If ice is present your fan have insufficient air neede to frost free your evaporator its not the same with the origina you replace,beside your thermostat is not working have check this one.
Nov 23, 2008 | Kenmore 61042 Top Freezer Refrigerator
Kenmore Mod. 795.77316600 s/n 603MRSS00142
Bad evaporator fan. Center fan behind the freezer back wall.
Sep 01, 2008 | Kenmore 73503 Stainless Steel Bottom...
Kenmore model 59675502400
if the evaporator is clogged with ice, then you have a defrost problem.
check the defrost heater and the bi-metal .
to answer your question what controls the fan then it is the module that controls the fan.
you said you have diagnostic to test the damper then there should be a procedure also to test the evaporator fan motor.
why don't you try it..
tnx 4 using fixya,
drcool
Aug 26, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore side by side
Unplug the wires from the motor and check the voltage differential cross the two wires. If you have 120 Volts or in that area the motor should run. Try moving the fan shaft up and down. If you have any play in this the motor bearing are bad. Replace the motor.
Jun 18, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Inside fan motor - evaporator
Yes if you dont hear the evap fan wprking remove rear panel in freezer let me know what you see. Is coil iced over? Is fan running? Is the motor warm? Attempt to spin the blade gently to see if the motor is bound. You can oil these.
Dec 02, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 57029 Side by Side Refrigerator Logo
203 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
