Question about Singer Quantum XL-5000 Computerized Sewing Machine
Machine keeps stopping and says to turn it off
My machine (Singer XL 5000) stops with regular straight stitching and message says to turn it off. why does this happen?? What can I do to solve this problem??
  • 1 more comment
  • nurseshor687 Sep 11, 2010
    There is no error number on the screen. it is a pictogram with a yellow exclamation mark and a finger turning the machine to off.
  • nurseshor687 Sep 12, 2010
    No, my machine is not connected to my computer. It happens when I am trying to do a straight stitch to make a seam. I turn the machine off when I get the error and then turn it back on...it will work for maybe a minute or two and then I get the same message again...what causes this??
    The machine is about 5 years old but I very seldom used it. I have not attempted to do any other stitching with it.
  • 3,083 Answers
This machine's software has been reported to have problems, and that's probably what's happening in your case. Read the following web page and you will understand:
http://www.sewingmachinereviewer.com/singer-xl5000-sewing-machine.html
It could be any loose electrical connector inside the machine, or a hardware problem.
As the blog states, get your money back and get the improved model that has corrected the problems.
This blog was also interesting:
http://www0.epinions.com/reviews/Singer_Quantum_Computerized_Sewing_Machine_XL_5000_Sewing_Machines
Good luck, and hope this helps.
Posted on Sep 13, 2010
  • Tom Carson
    Tom Carson Sep 15, 2010
    It could be a dirty switch contact somewhere or a bad power supply component- check out any electrolytic (metal or plastic or paper) capacitors, and replace them if in doubt. They can dry out and go bad in a few years.
    Sorry so late in getting back to you, and good luck.
    President:
  • 2,777 Answers
I assume this problem occurs every time you are doing regular stitching? It sounds like a module is having an issue inside the sewing machine. How old is this machine? Does it do all other stitching normally without issue?
Let me know, thanks!
Tim
Posted on Sep 12, 2010
  • 2,272 Answers
If the machine connected to computer then check the usb cable connected between machine and computer.It should be loose or the usb cable is got faulty.Reconnect the cable and check,if still same problem then replace the cable and check. Also reset all the settings.Find you serial ports and click to open. Choose the communications port. If you do not see a yellow ? mark ignore the following. If you see a yellow ? mark you need to unplug and replug the USB plug so it will see the driver again. Check to see if the yellow question mark is gone. --------- Check out.Keep updated.Thanks.
    Genius:
  • 1,035 Answers
Hi. Is there an error number on the screen? may i have the exact error message that appears on the screen.
Posted on Sep 11, 2010
SINGER XL1000 SEWING MACHINE
Hi Peggy,
I know this want be easy for you.  I need any kind of part number you can get off the LCD screen.  Is it a display and you type the different stitch stuff into a keypad?  Or , is the LCD a touch screen that you touch the screen to select a stitch?  I do not have one of these Sewing machines, but I do Electronics repair. Is your Screen Black and not displaying anything?  I believe we can work through this and get you a repair solution. The back light may have gone out on the screen only. Please reply with more info, so that we can get you a solid solution.  By the way, Singer really does not make those anymore.  They are making a more modern Screen at this time. Usually after 5 years, the manufacturers stop making parts for a model. Good news though, we can work on repairing the one you have. Go to Ebay and see if we can buy a XL1000, or other venue to rob the parts from.
Oct 13, 2007 | Singer Quantum XL-6000 Computerized Sewing...
Cxl manual
User's Manuals, including yours, are available as a free download the Singer Sewing Machine website. Actually, when you enter CXL you get the XL-50 user's manual, which is essentially the same machine, although a few of the patterns may be different. The CXL, XL-50, XL-10 and XL-1 are basically the same machine; I own a CXL and XL-50, and love them. They can sew SIDEWAYS--straight AND zigzag stitch!
Jun 12, 2014 | Singer Sewing Machines
Can I go from straight stitches to zigzag stiches and back in the same seam?
Hi Susie,
I can't tell whether you mean straight stitching and then turning your work 180 degrees to stitch atop the straight stitches in zig-zag, or continuing around the corner of your straight stitched side using zig-zag. But you can do either. You can mix up straight and zig-zag stitching at will.
Just ease up to a stop, ensuring the needle is positioned down inside the work when you stop.
Lift the foot.
Adjust to your desired stitch setting.
Lower the foot.
Turn the wheel toward you manually to ensure the stitches will be placed where you want them, and
Slowly engage the power again (via foot or thigh lever).
Hope this helps.
May 14, 2014 | Singer 3116 Simple
E7 error message Singer Patchwork
I used can air and blew out the reverse button area. Worked immediately after turning off and back on.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john-michael_38e8d20d2052609c
Mar 23, 2014 | Singer 7258 Sewing Machine
Singer sewing machine is stitching every half inch how to fix this
I had a singer machine that had a basting stitch that was like that. Make sure that you have chosen regular straight stitch.
Feb 12, 2013 | Singer 2639
Hello. I have a Singer Model 1411. I was going along, switched over to the zigzag stitch, and when I came back to the regular stitch, the machine thinks it's making a buttonhole instead.of a straight...
Well, I think you confused your machine. Go back to the zig zag and sew on a scrap piece of material. Stop sewing and carefully go back to regular stitching. Make sure your stitch length is correct and you have everything tightened up and the feed dog is raised. If this doesn't help, try doing a button hole stitch for a bit, stop sewing, go to zig zag, stitch a bit and go to the regular stitch and see if that works. If not, you may have to take it in to be reset. Good luck.
Nov 28, 2017 | Singer Sewing Machines
Almost jammed
This sounds like a bearing failure, I would take it in to a service center and ask for a free estimate.
May 25, 2010 | Singer 7442 Mechanical Sewing Machine
Machine beeps and stops sewing, no error message displayed
sounds like not through the tension plate (on top) right... rethread and make sure you hold the thread taunt toward you as you putt through top tension... you should hear a slight click and some resistance...
Apr 08, 2009 | Singer CE-200 Quantum Futura Computerized...
New Singer Futura machine stops & tries to revert to overlock.
Sorry to say but it sounds to me that you need to take your machine in to be checked.
Mar 05, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer Quantum XL-5000 Computerized Sewing Machine Logo
83 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
