Question about Bulova Watch
Nelsonic watch with no manual. how can the watch be set?
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
I have a marykate and Ashley ladies quartz watch model number MKA0132PC21 and i cannot get the backing off to replace the battery. Nelsonic is listed as the manufacturer and i would like to know if you can...
It should spin off counter clock wise, usually need a special watch tool ? Not always tho, and most jewelry departments in Myers, Walmart, etc... will open for free if your buying a new battery, really hope this helps ?
Feb 23, 2015 | Watches
How to set a casio aw817av watch
Hello Kenneth,
Here is the manual for your "st*pid" watch.. lol
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2747.pdf
Yes, you are right, it is not a simple watch to set. But with that manual, you can just follw the instructions.
The manual is in PDF format, if you can't open it download and install adobe reader (free)
You can rate my answer if this helped you.
Nov 11, 2011 | Casio AW817AV Wrist Watch for Men
CYBEAT W.R.3BAR WATCH MANUAL
i have a cybeat watch,the manual is in japenese i need it in english
Dec 29, 2009 | Watches
Nelsonic watch with no instructions
Copy and paste this link. It will take you to Bulova's service centerwhere you can download instructions for any of their watches.
http://bulova.com/service/servicecenter.aspx
If you appreciate me finding this answer for you then please rank this solution as "fixya" or at least "helpful" as what I have found for you will solve your problem. :-)
Jan 09, 2009 | Bulova Watch
I have a Nelsonic wristwatch that I bought from an AAFES and I just need to reset the time on it and have no idea how to do it. I can not find anything on the internet search engines that pertain to my...
hold the bottom right button while you are on the regular time screen. itll flash when you are in time editing mode. hold the top right button to change the minutes. push the top right again to move over to the hours. wa-la! i also got mine from AAFES! man that was frustrating! haha.. here's a more detailed instructional http://www.ehow.com/how_6620087_set-nelsonic-digital-watch.html
Oct 20, 2008 | Watches
I'm looking for a replacement stainless steel watch strap part number S961DB for my Casio G-shock 7000D. I've been told by a NZ Casio agent that there is no replacement strap. This is an expensive watch...
You can try calling Casio derectly 1-800-836-8580 If that doesn't work your out of luck unless someone has one they don't need. What is wrong with the one you have? sometimes the band can be repaired. Also some watch people or jewelers who can take a band alot like yours and cut it to fit the watch. Let me know what happens, maybe I can help you.
Apr 23, 2008 | Watches
Bulova Watch Logo
218 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
