Question about Pentair Minimax NT Heater
The fan in the heater turns on but the heater does not turn on.
The red service light stays on and the heater light will not come on. I replaced the ignition control module and it still happens. Heater will not come on.
I have had minimax heater for four years now and have had to replace the circuit board 3 times and the temp control twice these things are junk. Will not buy another pentair.
Posted on Aug 14, 2010
  • 5 Answers
Probably a bad circuit board. I have the same problem once the water gets above about 82 deg. I tried cleaning the filter and strainer, cleaning out the heat exchanger, replacing the temperature limit switches, bypassing the pressure switch, and cleaning the ashes off the burner, and none of these worked.
Posted on Aug 01, 2010
  • Charles Mashburn Aug 06, 2010
    It could also be a bad thermal fuse. This is located below and behind the gas valve, and looks like a thick wire covered in shrink tube with a spade connector at each end. You can try temporarily bypassing it with a jumper, to see if this solves the problem. If it does, then time to go get a new one.
Jandy lt250 heater has air flow message
make sure 24 volts ac on both sides of pressure switch if not replace pressure switch or copper tube is plugged if only 10 or so volts will not keep gas valve open
Nov 21, 2012 | Jandy Laars Lt 400,000 Btu Heater
I have a Sta Rite SR400 BG heater unit fan comes on service heater light . No error message and unit will not ignite. After a few minutes fan turns off unit still not firing and the service heater red...
Are any of the service lights on on the back-side of the board? There are 4 possible lights that can illuminate...if any are, I need to know which ones please. If not, there is more troubleshooting required. If you would like a copy of the owner's manual which covers all these steps in detail, please send me an email using the contact feature of our site at www.arrowpools.net and I'll reply with a copy of it.
John
Sep 18, 2011 | Sta Rite Sta-Rite Max-E-Therm High...
Why does red light on "on" button stay on?
The reason the red light on your rinnai vent free gas heater stays on simply is because it is having power on it, if it is unplugged, it will go off, or if you turn off the switch from the power outlet, then it will go off too.
As long as there is power supplied to the rinnai vent free gas heater, the power light will remain on.
Take care and good luck
Dec 01, 2010 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
I just replaced my heater/fan/light in my bathroom. The only thing that confuses me is the red wire that is attached to the unit itself. What if you do not have a red wire ran but there are still three...
I know wiring and we can solve this problem.
A better description of your wires in required.
Then 'add a comment' at bottom of page, and it e-mails me, and then I can hook up the wires for you.
The following 8 questions are key to solving the problem.
The heater-fan-light has how many wires?
Exactly what color are the fan wires?
How many cables enter the fan-light-heater box?
Does each cable have a black-and-white?
Are all these cables from the switches?
Are there other cables that enter the fan-light-heater box?
How many switches control the fan-light-heater device?
Is each switch a simple on-off switch or are there 3-way switches too (a switch at each end of a hall is example of a 3-way switch)
Oct 2010
If you 'add a comment' I'll be here for next 3-4 hours
We'll get it done
Oct 28, 2010 | Broan-NuTone FAN CONTROL SWITCH
When heater first turned on light is green then turns red
Yes this is OK. The green light is showing you that you have power. When the light goes red it means that the burner is alight.
Cheers
May 03, 2010 | Rinnai EnergySaver 556 Air Conditioner
Flame wont stay lit
Sounds like a flame sensor problem. The board is not getting the proper signal from the flame sensor so it thinks the burner did not light and shuts the gas supply off. It keeps the blower operating to ensure that no gas is accumulated in the burner area. I suggest you contact a local mechanical contractor to service your heater.
Jun 23, 2009 | Pentair Minimax NT Heater
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Pentair Minimax NT Heater Logo
295 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
